#309 | |
Drives: 2013 Subaru BRZ
Sent from my Pixel 2 XL using Tapatalk |
#310 | |
not playing cards
Next time you get a CEL, make note of all the codes.
#311 | |
I also spoke to a well known Tuner and he said to just go over the TSB again. Mostly with the shimming of the sensors, as he thinks that may be the issue. |
#312 | ||
not playing cards
#313 | |
#314 | |
not playing cards
What happens leading up to the CEL? What are the codes? P0016 is bank-1 intake. Look again at the first screenshot you posted. Bank-1 intake is fine. Bank-1 exhaust is jacked. The other side is just off/disabled. Almost forgot to wrap up by saying that I'm no expert with this system. We're all learning here. Right now I think bank-1 exhaust sensor either needs shimmed or is failing in some other way.
#315 |
Seems like a line graph would paint a clearer picture than dials. For example here is a log of my car showing target and actual.
https://datazap.me/u/ermax/log-15078...zoom=7794-9068 I generated this log with Techstream btw. |
#316 |
#317 | |
not playing cards
#318 |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
CEL has continued to come on at least once a week lately. As of today it's been on for almost 24 hours straight and hasn't reset itself yet like usual.
I'm going to e-mail Subaru Canada, as this did not happen until after my P0018 repair last summer. Will update with findings. Car acts normally with the CEL on but I'm getting sick and tired of it popping up every damn week.
@bpennerz
#319 | |
I cleared codes and monitored the VVT values. Everything looked like it was following the Target values. Was, also, monitoring as the CEL kicked in and I noticed all the guages just stopped displaying values. So maybe that one time I saw 'some' values with the CEL present wasn't accurate. As per TechStream... I had in installed but whenever I went to look at the Data List, the program would crash. Do you by chance have the program that I could install? If not, I'll try to contact the buyer again. Just difficult to communicate with them due to time zone (China). |
| The Following User Says Thank You to TheStig85 For This Useful Post: | Ultramaroon (06-15-2018) |
#320 | |
| The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (06-15-2018) |
#321 | |
not playing cards
There is one other possibility that hasn't been discussed here. The manual does mention the VVT filters possibly being clogged. I doubt that is your issue but it's worth considering. When everything is working, (codes cleared) does your bank-1 intake seem to respond more slowly than the others? Graphs of the logs like @ermax suggested would show this.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | TheStig85 (06-15-2018) |
#322 | |
Drives: Track preped NA FRS
Edit: I think this doesnt help you much. but what I wanted to get across is that all gauges stopping the reading might not be an error, but that they are indeed reading "0". |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Ultramaroon (06-15-2018) |
| P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 06:15 AM |
| P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-17-2021 12:09 AM |
| P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 03:31 PM |
| p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 04:49 PM |
| OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 10:24 AM |
