Old 02-03-2014, 11:34 PM   #3165
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by DarrenDriven View Post
@NickFRS -- when Bobby retuned your car did they charge you for the dyno time? He just put a new tune into my car, but they didn't throw the car on the dyno after... which seems really strange to me.
Paid for retune. He prob just reduced the timing and changed FFS values n target AFR. Can always call n ask.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 02-04-2014, 12:17 AM   #3166
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by CK_Bladesmith View Post
My tune is through delicious as well
Edit: I also found that I've got a minor leak where the lines are crimped going into the coolant bottle.
Send William, your CEL codes, he will advise.
I did not get any CEL for leaks, both boost or coolant leaks.
Boost leak you notice the idle hunts and the rev jumps up and down.
Coolant leak in manifold car is very jerking when pulling off but fine when you wot and the coolant leaks from the bottle cap.
Obviously the coolant leaking from pipe is visible and the coolant level drops, should notice white drops from dry coolant where it is leaking.
Ryan86 is offline   Reply With Quote
Old 02-04-2014, 09:47 AM   #3167
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I am tempted to buy a smaller pulley. I have been on the stock pulley now for about 6 months with no issues. I really just want to see how much of a difference the 72.5 or 70mm will make. Any impressions from anyone on this after a pulley swap?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-04-2014, 09:51 AM   #3168
xjohnx
Grip>Slip
xjohnx's Avatar
It's quite noticeable.
Old 02-04-2014, 10:01 AM   #3169
evo4g63
evo4g63's Avatar
Any dyno numbers of yours?
-2016 Subaru WRX
Old 02-04-2014, 10:02 AM   #3170
Ryan86
Road Warrior
Ryan86's Avatar
72.5 not much, the 70mm big difference awesome pull and power.
Old 02-04-2014, 10:03 AM   #3171
evo4g63
evo4g63's Avatar
I am very tempted to try it out.
-2016 Subaru WRX
Old 02-04-2014, 10:25 AM   #3172
xjohnx
Grip>Slip
xjohnx's Avatar
haven't dynod with the smaller pulleys yet, unfortunately.
Old 02-04-2014, 10:34 AM   #3173
Ryan86
Road Warrior
Ryan86's Avatar
I got dyno chart showing each pulley, although must consider the tune is still being fine tuned so don't look at the actuals gains.
Will put up in a few secs
Old 02-04-2014, 10:48 AM   #3174
swift996
swift996's Avatar
Noticeable difference going from 75 to 72.5, I'd say maybe 15hp or so worth on mine. Check the boost plot I uploaded on a page or so back.
I'm waiting on my cat-back to come (on Friday) and then plan to install on Saturday and get up to @PureAutomotive early next week for a dyno to compare apples to apples. I did 237whp on the 75mm non-intercooled last time there (although it was 101 degrees ambient temps). I'm hoping for 270whp this go around (on an ethanol blend). I will put together a video.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-04-2014, 10:56 AM   #3175
Ryan86
Road Warrior
Ryan86's Avatar
First dyno is 75mm vs 72.2mm
Second dyno 72.5 vs 70mm
As I said earlier the tune is still under development
Graph is in kw and nm
Kw = 1.34 whp
Old 02-04-2014, 11:02 AM   #3176
swift996
swift996's Avatar
@Ryan86
I'm assuming that is the boost plot in bar? Was that from the MAP sensor or a gauge?
72.5mm = 10.6psi
70mm = 11.6psi
Old 02-04-2014, 11:19 AM   #3177
evo4g63
evo4g63's Avatar
Seems worth a shot. I made 258whp on the stock 75mm pulley, non intercooled kit, axle back and e70. If i can make another 15 or so whp I'd be happy.
-2016 Subaru WRX
Old 02-04-2014, 11:25 AM   #3178
Ryan86
Road Warrior
Ryan86's Avatar
@Ryan86
72.5mm = 10.6psi
75mm = 11.6psi
The boost was measured from the boost off the SC through the dyno in bar
75mm = 0.68 bar
72.5mm = 0.73 bar
70mm = 0.8 bar
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
