#3165 | |
Drives: 2013 Asphalt FRS
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#3166 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
I did not get any CEL for leaks, both boost or coolant leaks. Boost leak you notice the idle hunts and the rev jumps up and down. Coolant leak in manifold car is very jerking when pulling off but fine when you wot and the coolant leaks from the bottle cap. Obviously the coolant leaking from pipe is visible and the coolant level drops, should notice white drops from dry coolant where it is leaking. |
#3167 |
Drives: 2016 Subaru WRX
I am tempted to buy a smaller pulley. I have been on the stock pulley now for about 6 months with no issues. I really just want to see how much of a difference the 72.5 or 70mm will make. Any impressions from anyone on this after a pulley swap?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#3168 |
Grip>Slip
It's quite noticeable.
#3169 |
-2016 Subaru WRX
#3170 |
Road Warrior
72.5 not much, the 70mm big difference awesome pull and power.
#3171 |
I am very tempted to try it out.
-2016 Subaru WRX
#3172 |
Grip>Slip
#3173 |
Road Warrior
I got dyno chart showing each pulley, although must consider the tune is still being fine tuned so don't look at the actuals gains.
Will put up in a few secs |
#3174 | |
I'm waiting on my cat-back to come (on Friday) and then plan to install on Saturday and get up to @PureAutomotive early next week for a dyno to compare apples to apples. I did 237whp on the 75mm non-intercooled last time there (although it was 101 degrees ambient temps). I'm hoping for 270whp this go around (on an ethanol blend). I will put together a video.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#3175 |
Road Warrior
First dyno is 75mm vs 72.2mm
Second dyno 72.5 vs 70mm As I said earlier the tune is still under development Graph is in kw and nm Kw = 1.34 whp |
#3176 |
@Ryan86
I'm assuming that is the boost plot in bar? Was that from the MAP sensor or a gauge? 72.5mm = 10.6psi 70mm = 11.6psi
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() Last edited by swift996; 02-04-2014 at 11:26 AM. |
#3177 | |
Seems worth a shot. I made 258whp on the stock 75mm pulley, non intercooled kit, axle back and e70. If i can make another 15 or so whp I'd be happy.
-2016 Subaru WRX
#3178 | |
Road Warrior
75mm = 0.68 bar 72.5mm = 0.73 bar 70mm = 0.8 bar |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
