#295 | |
Drives: Pearl White '13 ZN6
Sent from my D5803 using Tapatalk |
#296 | |
Drives: Scion FR-S
#297 |
Drives: SC RB FRS
i bought this kit awhile back like dec 2014 before the v3 came out and just delayed installing it. plus i drive like 3000 miles a year so wasn't in a big hurry to put it on
yeah, same pulley 16 psi, i was surprised of how much this supercharger can boost. |
#298 | |
#299 |
Drives: SC RB FRS
#300 |
Drives: raven FRS
Noob question:Can I still pass smog check after install the supercharger?I'm in Nevada state.
#301 | |
Drives: Scion FR-S
#302 |
Does anyone know why he made more power at 14psi than at 16? was it because of fuel loss up top or because of heat soak? I just don't get why the power would drop.
#303 |
Drives: GT86
can someone tell me what parts do I need to get to revert back to stock? What parts are cut during install?
www.facebook.com/badluckteam
my HKS Supercharged, Varis kitted ZN6 build http://www.ft86club.com/forums/showthread.php?t=26368 |
#304 |
Drives: 2015 Subaru Brz Limited
I've been having some rough starts in the morning on my vehicle. I have the v3 running e85. Temperature this morning was 62 degrees. Also notice that when I start the car first thing in the morning, it will idle a little rough for the first minute or so. I did put a k&n air filter in and recently sprayed the maf sensor with maf sensor cleaner and it ran much better. Now it's doing it again. Wonder if more oil got onto the sensor.
#305 |
Drives: Takumi
What kind of injectors and fuel pump do you guys reccomend? I heard Hks has their own injectors for v3?
#306 |
I ended up with their brand injectors and purchased an AEM 320 e85 pump. However, I only did this because I purchased my v3 with HKS Flash Editor that has the e85 map on it. If you are doing a custom tune, Injector Dynamics is the way to go.
#307 | |
Drives: 2013 WRB BRZ
Sent from my HTC6435LVW using Tapatalk
#308 |
Drives:
Ok... so I had taken the bypass valve apart a while back... finally got around to polishing it...
I should have taken a picture but I didn't so now I have to put it back together and I'm not sure if my memory is playing tricks on me. Do any of y'all know if this is the correct way to install the internals to the bypass valve? I put it together this way and it felt right but I need to make sure. Btw, I have the v3 kit. Edit: I've been looking around on the net and it seems that the little spring goes inside the bigger one... Can anyone confirm? ![]() On another note... I have to modify my air box... but for now... this is where I'm at with the install. ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix Last edited by zeal86; 05-08-2016 at 11:58 PM. |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 09:22 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
| Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 09:37 AM |
