Old 04-06-2016, 02:43 AM   #295
CxG
Drives: Pearl White '13 ZN6
Originally Posted by pitstops View Post
alright here is my contribution to the thread.
Tuned at Drift Office with Ecutek 92 octane
Hks Version 2 9 psi
Tomei Uel Headers
Ark Performance Exhaust
A unsafe no restrictor plate dyno run. 16psi, Nice numbers but was losing fuel up top maxing out stock injectors.
my current tune at 9 psi compared to a stock frs
Looks good, great numbers, Why V2?
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 04-06-2016, 09:36 AM   #296
Andew727
Drives: Scion FR-S
Hks Version 2 9 psi
Tomei Uel Headers
just removing the restritor gave you 16 psi??? or are you using different pulleys?
Andew727 is offline   Reply With Quote
Old 04-06-2016, 11:12 AM   #297
pitstops
Drives: SC RB FRS
i bought this kit awhile back like dec 2014 before the v3 came out and just delayed installing it. plus i drive like 3000 miles a year so wasn't in a big hurry to put it on
yeah, same pulley 16 psi, i was surprised of how much this supercharger can boost.
pitstops is offline   Reply With Quote
Old 04-06-2016, 01:50 PM   #298
CxG
Those numbers all on 93?
Old 04-06-2016, 03:45 PM   #299
pitstops
Drives: SC RB FRS
on 92 gas
Old 04-07-2016, 04:08 AM   #300
snk828
snk828's Avatar
Drives: raven FRS
Noob question:Can I still pass smog check after install the supercharger?I'm in Nevada state.
snk828 is offline   Reply With Quote
Old 04-07-2016, 08:46 AM   #301
Andew727
Drives: Scion FR-S
well now im very excited to see what numbers i lay down after this build. i was thinking i could only achieve 13-14 psi. i think my 400 whp goal may be reachable with 16!
Old 04-07-2016, 11:14 AM   #302
CxG
Does anyone know why he made more power at 14psi than at 16? was it because of fuel loss up top or because of heat soak? I just don't get why the power would drop.
Old 04-29-2016, 04:09 PM   #303
BadLuckZN6
BadLuckZN6's Avatar
Drives: GT86
can someone tell me what parts do I need to get to revert back to stock? What parts are cut during install?
BadLuckZN6 is offline   Reply With Quote
Old 05-02-2016, 11:26 AM   #304
jimmyw86
Drives: 2015 Subaru Brz Limited
I've been having some rough starts in the morning on my vehicle. I have the v3 running e85. Temperature this morning was 62 degrees. Also notice that when I start the car first thing in the morning, it will idle a little rough for the first minute or so. I did put a k&n air filter in and recently sprayed the maf sensor with maf sensor cleaner and it ran much better. Now it's doing it again. Wonder if more oil got onto the sensor.
jimmyw86 is offline   Reply With Quote
Old 05-02-2016, 07:18 PM   #305
Kazuya
Kazuya's Avatar
Drives: Takumi
What kind of injectors and fuel pump do you guys reccomend? I heard Hks has their own injectors for v3?
Kazuya is offline   Reply With Quote
Old 05-03-2016, 03:28 AM   #306
Apex-Apex
Apex-Apex's Avatar
I ended up with their brand injectors and purchased an AEM 320 e85 pump. However, I only did this because I purchased my v3 with HKS Flash Editor that has the e85 map on it. If you are doing a custom tune, Injector Dynamics is the way to go.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 05-05-2016, 12:21 AM   #307
craigpitts7
craigpitts7's Avatar
Drives: 2013 WRB BRZ
Alternator bracket will get you back operational.
Sent from my HTC6435LVW using Tapatalk
craigpitts7 is offline   Reply With Quote
Old 05-08-2016, 10:25 PM   #308
zeal86
zeal86's Avatar
Drives:
Ok... so I had taken the bypass valve apart a while back... finally got around to polishing it...
I should have taken a picture but I didn't so now I have to put it back together and I'm not sure if my memory is playing tricks on me.
Do any of y'all know if this is the correct way to install the internals to the bypass valve? I put it together this way and it felt right but I need to make sure. Btw, I have the v3 kit.
Edit: I've been looking around on the net and it seems that the little spring goes inside the bigger one... Can anyone confirm?
On another note... I have to modify my air box... but for now... this is where I'm at with the install.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
