Old 03-14-2014, 06:38 PM   #295
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Captain Insano View Post
Just ran a log today on 1.55b stg1 with 93 octane fuel.
http://www.datazap.me/u/captain-insa...=0&data=1-8-12
How's it look? I did notice at one point IAM went down to .88, but then the rest of the time I logged it was back at 1 and later I watched the data viewer real time and it stayed at 1 anytime I was watching.
Looks fine to me. I wouldn't be concerned with IAM going down to .88 for a brief period of time and then quickly climbing back up to (and staying at) 1.00. If you see this behavior having routinely, it may be worth trying a different gas station or detuning the map slightly if that makes you feel more comfortable.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Captain Insano (03-14-2014), steve99 (03-14-2014)
Old 03-15-2014, 01:35 PM   #296
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I just did the datalogging on Stage 1 V1.56b map. with Avo Silicon inlet, Motiv Catless Front pipe, Nameless axle back
http://www.datazap.me/u/zc06kissther...4?log=0&data=1
somehow, except time and engine speed, all other fields shows as colum1~11
FIXED file!
http://www.datazap.me/u/zc06kissther...0&data=1-2-8-9
when i compare this datalog file from my previous tune, it seems very similar. i guess looks ok?
EDIT: i updated template file and shows all colums now!
Old 03-15-2014, 02:55 PM   #297
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
its odd that people are having IAM issues. ive advanced these tunes 3 more degree in some areas and adjusted fuel tables and im having 0 knock. 93 oct
IG-Joey_Soul
Old 03-16-2014, 02:05 AM   #298
transition
I'm not sure exactly how to read this brief log. Quick 3rd gear pull:
http://www.datazap.me/u/transition/b...8-9&zoom=0-212
Perrin catback, Stage 1 A01C 1.55b map
transition is offline   Reply With Quote
Old 03-17-2014, 01:03 AM   #299
Nardi330
Nardi330's Avatar
Drives: 86
did a quick log for normal city driving as requested by steve99.
http://www.datazap.me/u/nardi330/oft...4-6-7-10-11-12
i'm running 1.55 stage 1 A01G rom on Aussie spec manual 86.
it's not a 3rd gear WOT to redline pull.
any comment is appreciated.
Nardi330 is offline   Reply With Quote
Old 03-17-2014, 02:18 AM   #300
Shiv@Openflash
Drives: 2013 FRS
That log looks really great.
Old 03-17-2014, 02:20 AM   #301
Shiv@Openflash
Drives: 2013 FRS
Unfortunately, there isn't too much useful info in there. Just a bunch of partial throttle city driving. Next time, do some single gear WOT pulls (2000-7500rpm) in 3rd gear and we will be able to make a useful analysis
Old 03-17-2014, 02:24 AM   #302
Nardi330
Nardi330's Avatar
Drives: 86
Hi Shiv,
thanks for your reply. I understand I need to do a WOT pull in third which i will do this saturday on a dyno.
Steve99 asked me to assist him with data logging some normal driving for him as he has some issue with IAM dropping. so I thought i would also post my log here.
Its one of the parameters you can now log with OFT.
It never used to work with our G series ROM's but with update it now works.
The parameters toy need to log are
engine speed RPM
Engine load
IAM (ignition advance multiplier
Knock Correction
any others you like up to 12 parameters.
I had noticed my IAM dropping in generall driving due knock detection. If the IAM drops below 1 to avoid knock it pulls ignition advance from entire rev range reducing power.
Noticed this was happening driving arround in traffic when cruising around at less than 4000 rpm.
Old 03-17-2014, 03:22 AM   #303
s2d4
s2d4's Avatar
Umm, your IAM starts at 0.18 and gets up to 0.29 by the end of the drive.
You have feedback knock at 2900rpm, 0.65 load.
Did you just flash the tune or you've been driving on this for awhile?
Old 03-17-2014, 03:26 AM   #304
Nardi330
Nardi330's Avatar
Drives: 86
Flashed 2-3 weeks now, driven around 100km.
i think there are issues with my OBD2 extension cable. maybe i will just plug OFT straight into OBD2 port and try again.
Old 03-17-2014, 03:37 AM   #305
s2d4
s2d4's Avatar
I doubt that is the issue.
What mods do you have, what fuel are you running this on?
Old 03-17-2014, 03:45 AM   #306
steve99
I don't think there is any problem with the obd connection or the oft just would not log. log is fine but you look like you have been getting enough knock corrections to be dropping your IAM (ignition advance multiplier) from the normal condition of 1 to around 0.2 to 0.4.
This is not going to destroy an engine or anything but it is pointing to out aussie 98 RON is not as good as USA 93 AKI fuel for low rpm high load knock resistance.
as the engine is detecting knock at low rpm high load (city driving) is is reducing the IAM which retard the timing and robs engine of power so you don't get max benefit from tune.
When IAM drops below 1 it reduced the timing (knock correction) advance for the entire rpm range by in your case by 70 to 80 % this is probably pulling 2 to 5 degrees from you timing across the entire rev range.
Their are two options one is run higher octane fuel ie united 100 octane is about all we have in OZ or pull a bit of timing from the problem area which should keep your IAM up around 1.
I am currently running 100 octane and IAM was dropping slightly to 0.7 at worst and not very often. I modded by advance map in a few places only pulling -0.35 degrees and it solved the IAM drop now 1 when running 100 RON.
Will try on 98 once my tank runs down.
I can send you a ROM with the corrections if you want to flash it and try.
Or I can just send you the corrections and you can edit it yourself in RomRaider.
Old 03-17-2014, 03:48 AM   #307
s2d4
s2d4's Avatar
This depends on which 98RON, caltex is ridiculously bad.
The Following User Says Thank You to s2d4 For This Useful Post:
steve99 (03-17-2014)
Old 03-17-2014, 03:50 AM   #308
steve99
I have only used shell 98 (V power) or united 100 Octane, but IAM 0.2 did look pretty ordinary
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 12:12 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 01:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 10:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
