View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 08-21-2014, 04:36 AM   #295
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by cdrazic93 View Post
What does the accusump actually fix? Or is it more of a bandaid?
Sort of both. It's a band-aid/partial fix and a failsafe if you will..... Even with an amazing oiling system an accusump can be useful and provide a safety net for say long/short duration's of potential oil starvation that may occur in long high G corners. It's just an accumulator that kicks in extra oil/pressure when there is a pressure/flow drop.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 08-21-2014, 08:35 PM   #296
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
so does using heavier oil help with oil pressures to a certain temperature? As much as I hate reading these posts, its good information to prevent catastrophic failure.
When I read posts about engines blowing up just cruising and not hitting boost, is that because the weak points were at breaking point? I can understand the engine failures from tracking/dyno/racing etc, but for the engine to fail while cruising (no boost) and checking AFR levels, that is what scares me.
Engines can be replaced, but blowing up on public road on a free way doesn't sound too fun.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 08-22-2014, 12:41 AM   #297
Cal3000
Drives: Panda FR-S
Originally Posted by Astroboy View Post
What kit?
Vortech Kit :P
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Astroboy (08-30-2014)
Old 08-22-2014, 12:43 AM   #298
Cal3000
Drives: Panda FR-S
Originally Posted by raytrix View Post
That's quite a good amount boosted. Not bad.
I'm hoping to reach 100k. This will happen in probably a year. lol
Astroboy (09-24-2014)
Old 09-22-2014, 12:13 PM   #299
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Correct me if I am mistaken, but based on all this thread and numerous other ones on these forums it seems that the AVO kit is quite proven. I haven't read of anybody having issues with the kit paired with a good tune.
MokSpeed is offline   Reply With Quote
Old 09-22-2014, 12:45 PM   #300
Dipstik-sportech
Dipstik-sportech's Avatar
The less power you make the less stress on the engine. Avo kits aren't known for producing big numbers so hence the reliability.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Astroboy (09-22-2014)
Old 09-22-2014, 01:47 PM   #301
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It might not blow your motor, but there are plenty of issues with the kit.
The Following User Says Thank You to King Tut For This Useful Post:
Old 09-22-2014, 01:48 PM   #302
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Interesting. I will do more research into this. Thanks for the input.
Old 09-22-2014, 01:50 PM   #303
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Most revolve around the manifold and exhaust leaks.
Old 09-22-2014, 03:34 PM   #304
Astroboy
Astroboy's Avatar
Drives: None
Still running strong? No cel yet or strange noises?
Astroboy is offline   Reply With Quote
Old 09-26-2014, 10:10 AM   #305
Cal3000
Drives: Panda FR-S
Still going strong and sounds the same. The crickets magically went away for some reason. lol
Astroboy (09-27-2014)
Old 09-27-2014, 12:59 PM   #306
Astroboy
Astroboy's Avatar
Drives: None
That's good to hear! Very proud of you and your car, good job. I would invest in a catch can tho just in case
Old 10-17-2014, 12:11 PM   #307
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Added @romin . I am sure I have missed at least a couple more over the past months.
Old 10-17-2014, 12:15 PM   #308
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Added @TopSpeed as well.
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 03:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 07:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 11:53 AM
