#295 | |
Drives: 2020 DGM BRZ Limited
I was hoping to be able to do this too, since I already have the innovate kit installed and it re-routes these lines. After taking a closer look at the cooler though I'm inclined to just install it per the instructions in OP. http://www.ft86club.com/forums/showp...&postcount=194 Last edited by mikalem; 04-13-2014 at 09:18 PM. Reason: Link to pic didn't work |
#296 | |
Lacking brains
Drives: frz
Just seems like if the throttle body implementation could work that it would greatly simplify this whole mod. |
#297 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
The inlet pipe on the oil cooler is 1/2"... The Throttle body piping is 1/4"
That is 50% less diameter. Converting that over to volume, is over 60% less flow I.E. the throttle body coolant lines can channel only 1/3rd the amount of coolant required for the oil cooler. So no, the throttle body piping is a BAD IDEA. I wish it wasn't, it is indeed the perfect spot, but its way way too small. |
#298 | |
Lacking brains
Drives: frz
Also found this on eBay. http://www.ebay.com/itm/Coolant-Hose...cff8bf&vxp=mtr |
#299 |
Perpendicular flow isn't the issue you brought up. And if you really trust a third party aftermarket parts manufacturer more than the engineers who actually designed and built the motor in the first place, then so be it, but you might want to find another thread...
#300 | |
Lacking brains
Drives: frz
According to several posts the kit does seem to atleast have some positive affect, granted a small effect, but that's all these Subaru sandwich plates have ever been regarded as creating. http://www.ft86club.com/forums/showp...77&postcount=7 http://www.ft86club.com/forums/showp...&postcount=100 http://www.ft86club.com/forums/showp...2&postcount=82 I'm no engineer, but I'd think the restrictions of the locations the throttle body coolant hoses are sourced from are no worse than the restriction created by 2 banjos. Your initial reply acknowledged only the throttle body hose diameter and entirely neglected the restriction created by the banjos. If you follow this thread a significant portion has been discussion on various routings and sourcings or the effectiveness of such. I've decided that it's simple and cheap enough that there's no reason not to atleast give it a try since the only real thing wasted would be some cheap hose. Not sure the cooler will clear my kraftwerks kit but I'd guess the spill lip could be notched worst case. Edit: just reread this whole thread and the other one. Still going to give it a try, nobody who has used the "proper" routing has posted any sort of conclusive logs (or really any data for that matter) that show a significant increase in effectiveness over the cusco banjo method. This was the best of the data posted here using the proper method. http://www.ft86club.com/forums/showp...&postcount=181 http://www.ft86club.com/forums/showp...&postcount=184 Did a bit more digging, 21311AA140 is the part number for the 3.6r oil cooler, it costs a good bit more than the dit forester cooler. Any chance of it being a larger core? One immediate issue would be the hose routing angling downward on one tube. Last edited by Model Citizen; 04-14-2014 at 10:21 AM. |
#301 |
Tom's Racing ADDICT
Drives: 2013 Toyota 86, 1999 Toyota Corolla
Got my oil setup installed. Love it.
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers." Instagram: @simply_the_best |
#302 | |
As for the banjo bolts, I really don't care. Banjo bolts don't have restrictions like you are trying to state, they have a 90 degree curve but if they are large enough (which the Cusco ones seem to be) they won't have nearly as small of passages as coming from the throttle body. Either way, if your intent is to replicate the Cusco kit, you should start a new thread. And the 3.6L oil cooler is not worth the extra cost, its not only not designed for a top mounted application its not significantly larger. But its your money and your car, do what you want... |
#303 | |
Lacking brains
Drives: frz
I'm not looking to replicate, I am looking to sort out a path. Fact is banjo bolts are a restriction, so are the throttle body hoses for that matter. Nobody who has done this mod the "right" way has shown useful data other than one poster that i linked. At least several people using the cusco solution have posted a bit of data. I plan on trying the throttle body hoses, why? Because its only a couple $ for some hose, a few minutes of time and nobody has shown any information worth a shit that it shouldn't at least be given a try (avo kit and possibly others iirc use the tb hoses for turbo cooling). My apologies all high and mighty sir for asking questions in the one relevant active thread for the topic. Thanks for the info on the 3.6 cooler, i could not find any measurements or accurate pictures of the cooler itself this morning, i did search. The only info i could find was that its nearly 2x the cost. Considering the same oil filters are used i was hoping that maybe it basically was just a larger core, which would have been valuable. Once again my apologizes for asking questions about alternative methods in a thread that in large part has been a discussion about alternative methods from the op. |
#304 | |
But I'm not going to defend myself against someone willing to ignore the trial-and-error process the rest of us went through to come up with this DIY. |
#305 | |
Lacking brains
Drives: frz
You don't need to defend yourself against anything, unlike yourself i wasn't being aggressive, confrontational or prickish. I was asking questions in an absence of fact. To me it seems like an option that has been theory crafted against, but not actually tested in this application. Validating how stupid I am will take what; a trip to parts store, few $ and maybe 10 minutes of time. Unless you can point out where the throttle body hoses were found to be a miserable failure in actual testing. Fact is right now the throttle body method has about as much data behind it as the proper method, near 0. I'll give it a try just so you can tell me I have downs. |
#306 |
I'm trying to save you the trouble and the money... When you get that throttle body pipe off and see how small it really is and go "oh, this is way too small" like a few of us have.
To use the throttle body hoses, you will have to buy extra adapters for dealing with the change in pipe diameter, cant just use the same size hose from either side. Thats going to cost extra money. Then you might also have the issue of feeding so little coolant into and out of the cooler that it might not actually be able to cool the oil enough to make a noticable difference. The Cusco kit uses banjos, but they are the correct size to match up to the oil cooler piping even if they have restriction and are not getting coolant feeds from the ideal locations. But its your car, your wallet, do what you wish. |
#307 | |
Drives: 2005 Toyota Camry
Most of us don't use the Cusco design because considering the price, it's borderline standalone oil cooler kit pricing... the thermostat placement is only an issue when the engine is cold. -alex |
#308 |
Its still an issue. More of an issue for daily drivers in varrying environmental tempuratures. The coolant coming from the block location we are using is right after the radiator pipe just past the thermostat, so i doubt the temp difference is much if any. I'm more concerned about the water pump actually pumping coolant to the cooler at all times and not getting a stagnant feed when the thermostat is closed.
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
