#295 |
Drives: 2014 scion frs
Anyone have the finalized v3.0. Tunes for a 2014 frs? I've been trying to reach Shiv for a bit but no luck
thanks in advance!
#296 |
Drives: Stock
Well from what I can see the new tunes seem to be working pretty good so why not just release them to the public and then make changes and update after that. I know you can get it from another member but in all reality I don't know theses people on here and I'm not trying to be mean about that just real. What if some one messes with it.
| The Following 3 Users Say Thank You to -Willis-86touge For This Useful Post: |
#297 |
Drives: 2013 scion frs
Any updates on these tunes ?? Tried emailing shiv have not received a response yet. Looking for stg 2uel... dam I'm impatient !
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you. – Jeremy Clarkson
#298 |
Drives: 2017 manual BRZ
#299 | |
No unfortunately A01C
#300 |
Drives: 2013 Raven FR-S
| The Following User Says Thank You to smg1138 For This Useful Post: | Nobunnyhere.86 (09-06-2017) |
#301 |
Drives: Scion FRS
Thanks for the heads up, i also was curious on the website for the downloads it says 2.076, are those the "2.7" you speak of or are there other downloads i am not seeing? once again thanks !
#302 |
Yeah, that's it. I must have left out a decimal point.
#303 |
Drives: 2014 WRB BRZ Limited
Does this cover the openflash header specific beta rom that was released a while back, or will v3.0 eventually replace that effort? Love my beta openflash header tune, can't imagine v3 could be much better if they aren't specifically optimized for OFH.
#304 |
Drives: Toyota 86 GTS
They are exactly the same minus the optimistic timing the OFH files had above 6k. If you're not getting -3 FLKC around 7k then there's no point re-flashing.
#305 | |
WRBLUE BRZ
Drives: 2016 Subaru BRZ
My header is Gruppe-s and it is terrible when 5th gear wot pull at 7000rpm -5 FLKC but iam still 1, Should I pull timing out ? |
#306 |
Or run the older v2 less agressive tunes, asian fuel is similiar to australian fuel and not as good as even usa 91 let alone 93. Try the v2 91 tune instead
| The Following User Says Thank You to steve99 For This Useful Post: | pym19109 (09-11-2017) |
#307 |
Drives: 2017 BRZ w/PP
dumb question, i just flashed the stage 1 beta for the 2017 and was looking at my logs and i noticed my throttled didnt go above 91ish. Is there something that needs to be corrected or does my pedal just go down farther?
#308 |
Drives: frs
| OpenFlash Tablet: Multiple Data Log files! | Shiv@Openflash | Software Tuning | 95 | 11-09-2017 09:40 AM |
| OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download | Shiv@Openflash | Software Tuning | 1062 | 08-13-2017 05:13 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet v1.55b: BIN files added! | Shiv@Openflash | Software Tuning | 525 | 04-09-2014 10:42 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
