#3053 |
Drives: 14 Ultramarine FR-S
17x9 +35
245/40 R17 1.2" Drop All Around -1.5 Camber All Around Stock Struts Will this clear the front spring perch and not rub under hard cornering? Seems like I should be okay.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#3054 |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Should be okey. Worst case you have to change the camber a bit, but thats really just worst case.
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
| The Following User Says Thank You to Killerbee For This Useful Post: | Phantobe (04-12-2016) |
#3055 |
Drives: FRS Scion 2016
Varrstoen Wheels
Varrstoen Wheels 18x9.5 offset 35 will clear on the rear of the FRS? will this fit with 225/40/18 tires with Eibach sportline drop 1.4 inch with stock struts ?![]() Please Help |
#3056 |
#3057 |
Drives: Scion FR-S
This isn't necessarily a fitment question but I did not wan't to start a dedicated thread to this.
So if we had a 17x6 +48 offset wheel and a 17x9 +48 offset wheel and put a 38mm spacer in, in theory they would stick out of the car an equal amount since they are the same offset? Or am I understanding this wrong? P.S - these are just random made up numbers and I am not actually going to replicate this setup. |
#3058 | |
http://www.frsproject.com/ |
| The Following User Says Thank You to swarb For This Useful Post: | lupindub (04-13-2016) |
#3059 |
Drives: Scion FR-S
So the wheel I just bought unbeknownst to me came in with a wheel stud hole with a 1.5cm diameter... Stock lug nut on the car is 1.25cm. So pretty much I can or cannot put these wheel's on the car?
#3060 | |
Sounds like you got the wrong bolt pattern. |
#3061 |
Drives: Scion FR-S
Okay I worded my last question incorrectly. So pretty much I am going to order some adapter's and when I am choosing the stud size, do I choose 12x1.25 or 12x1.5? I am going from 5x100 to 5x114.3
#3063 |
Drives: FRS
What wheels and off set and tires will fit Stock height FRS not really trying to go low any more since it's not my thing no more if any one can help thanks ?
#3064 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#3065 |
Drives: Black MT LMT BRZ
I might be pushing it a bit but could this work maybe?
18x9.5 +38 all around 5mm spacer for the rear ( going for a flush look ) 245/40 for tires According to the frsproject site this would work on a 1.4 in drop using coilovers unless I'm reading it wrong Would I need to drop it less? Could I drop it at all? |
#3066 | |
| The Following User Says Thank You to swarb For This Useful Post: | Kendallkab (04-15-2016) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
