#2969 | |
Big long thread from element tuning: http://www.ft86club.com/forums/showthread.php?t=63723 Specific scary post about temp/pressure/bearing damage: http://www.ft86club.com/forums/showp...&postcount=578 Gotta take it with a grain of salt those guys are running very hard way above what 99.99% of 86's will see due to their power levels and speed, but there have been a not insignificant amount of bearing failures attributed to lack of oiling even on street-only stock powered cars. Different posts: http://www.ft86club.com/forums/showthread.php?t=76760 http://www.ft86club.com/forums/showthread.php?t=64835 Consensus seems to be if you're a casual track user on a stock engine an oil cooler isn't required, but reccommended. 5W-30 is reccommended to maintain pressure and show a bit of temperature resistance. The average person is unlikely to notice anything until it goes "pop", I haven't heard anybody experiencing limp mode or any outward heat issues on stock power, but I'm sure CSG would know. |
#2970 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Not 86 related: Honda S2000 what's your opinion on stock S2000 rotors with HP+ pads and RBF 660 fluid for lapping. 225 wide 200 treadwear tires, front sway bar and cat-back exhaust are my only mods (built for B Street auto x). Will I have problems? Intermediate driver skill level.
#2971 |
Dismember
Drives: 2013 Red Scion FR-S
My understanding is that the OEM cooler is far from useless, but that an aftermarket cooler will do a much better job. If you're tracking in 70 degree heat, you'll probably be OK stock. If you're tracking in 110 degree heat, you probably need an aftermarket oil cooler.
#2972 | |
/scion
Drives: '13 86 M/T
#2973 |
What I *know* happens is the oil thins out, and once it thins out enough, friction surfaces stop getting lubricated...
#2974 | |
#2975 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#2976 | |
Drives: Stock FR-S
My tires would be warm long before going continuously at high speeds of course. |
#2978 |
Absolutely. Without an oil cooler, the oil has no direct contact with the outside world, and the only cooling it will get is whatever is conducted through the engine itself, and a minimal amount of radiation through the oil pan.
#2979 |
Dismember
Yup. OEM Forester cooler is meh. Aftermarket cooler is yeah!
#2980 |
Car Nut
#2981 | |
Nice thing about the Carbotechs is that there is only one naming convention and the higher the number, the crazier it is!
#2982 |
/scion
Drives: '13 86 M/T
Not a question per se, but I did pull the trigger on some RE71Rs thanks to this thread (and others). I'm going to pair with some PMU Club Racers for SOW CW next month. I'll be pretty happy if I can go 1:31.XX or quicker.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
