Old 10-01-2015, 01:33 PM   #2969
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Pat View Post
So what do you think happens to the car when the "temps go crazy"? Would the average driver even know anything is different/not right? Do you think the engine would blow up or something?
Lots of talk about it, oil temps have been recorded at 270F on the street, oil pressures drop significantly with temperature and rpm and it's thought that this is the cause of the FA20 eating the #4 bearing.
Big long thread from element tuning:
http://www.ft86club.com/forums/showthread.php?t=63723
Specific scary post about temp/pressure/bearing damage:
http://www.ft86club.com/forums/showp...&postcount=578
Gotta take it with a grain of salt those guys are running very hard way above what 99.99% of 86's will see due to their power levels and speed, but there have been a not insignificant amount of bearing failures attributed to lack of oiling even on street-only stock powered cars.
Different posts:
http://www.ft86club.com/forums/showthread.php?t=76760
http://www.ft86club.com/forums/showthread.php?t=64835
Consensus seems to be if you're a casual track user on a stock engine an oil cooler isn't required, but reccommended. 5W-30 is reccommended to maintain pressure and show a bit of temperature resistance. The average person is unlikely to notice anything until it goes "pop", I haven't heard anybody experiencing limp mode or any outward heat issues on stock power, but I'm sure CSG would know.
ineedyourdiddly
Pat (10-01-2015)
Old 10-01-2015, 01:47 PM   #2970
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Not 86 related: Honda S2000 what's your opinion on stock S2000 rotors with HP+ pads and RBF 660 fluid for lapping. 225 wide 200 treadwear tires, front sway bar and cat-back exhaust are my only mods (built for B Street auto x). Will I have problems? Intermediate driver skill level.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-01-2015, 04:52 PM   #2971
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by LOLS2K View Post
The OEM oil cooler conversion seems pretty enticing. Would you recommend skipping that option and going with an aftermarket oil cooler setup, if the car will see occasional track use?
My understanding is that the OEM cooler is far from useless, but that an aftermarket cooler will do a much better job. If you're tracking in 70 degree heat, you'll probably be OK stock. If you're tracking in 110 degree heat, you probably need an aftermarket oil cooler.
Old 10-01-2015, 05:03 PM   #2972
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Just to clarify (I'm the confused one), talking about the Forester OEM oil cooler conversion vs Aftermarket
LOLS2K is offline   Reply With Quote
Old 10-01-2015, 08:28 PM   #2973
CSG Mike
CSG Mike's Avatar
What I *know* happens is the oil thins out, and once it thins out enough, friction surfaces stop getting lubricated...
Old 10-01-2015, 08:29 PM   #2974
CSG Mike
CSG Mike's Avatar
You're gonna have major issues on track.
Old 10-01-2015, 10:17 PM   #2975
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
I'm confused - why?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 10-01-2015, 10:40 PM   #2976
RandomDeception
Drives: Stock FR-S
Without an oil cooler? Maybe a minute before oil temps go crazy. Try watching oil temps at 3rd gear at 70mph.
With an oil cooler? Forever as far as engine and oil temps go.
Would the thinning of oil due to overheating still be an issue if the outdoor temperature is below 10 degrees Celsius (below 50 degrees Fahrenheit)?
My tires would be warm long before going continuously at high speeds of course.
RandomDeception is offline   Reply With Quote
Old 10-01-2015, 10:52 PM   #2977
CSG Mike
CSG Mike's Avatar
Originally Posted by Frost View Post
I'm confused - why?
HP+ pads... have about half the temperature capacity of the XP10 you got @Frost
Old 10-01-2015, 10:53 PM   #2978
CSG Mike
CSG Mike's Avatar
Absolutely. Without an oil cooler, the oil has no direct contact with the outside world, and the only cooling it will get is whatever is conducted through the engine itself, and a minimal amount of radiation through the oil pan.
RandomDeception (10-01-2015)
Old 10-02-2015, 03:24 AM   #2979
EAGLE5
Dismember
EAGLE5's Avatar
Yup. OEM Forester cooler is meh. Aftermarket cooler is yeah!
The Following User Says Thank You to EAGLE5 For This Useful Post:
LOLS2K (10-02-2015)
Old 10-02-2015, 08:26 AM   #2980
BRZZZZZZZZZZ
Car Nut
That's what I thought. I better pick up some more pads in the next 7 months before the next track day.
Damn you winter!!!
Old 10-02-2015, 08:50 AM   #2981
Frost
Frost's Avatar
Oh ok, I keep mixing up the Hawk names - I forget which ones are the track ones and which ones are the performance street ones.
Nice thing about the Carbotechs is that there is only one naming convention and the higher the number, the crazier it is!
The Following User Says Thank You to Frost For This Useful Post:
strat61caster (10-02-2015)
Old 10-05-2015, 04:09 PM   #2982
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Not a question per se, but I did pull the trigger on some RE71Rs thanks to this thread (and others). I'm going to pair with some PMU Club Racers for SOW CW next month. I'll be pretty happy if I can go 1:31.XX or quicker.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
