Old 01-27-2014, 02:45 PM   #2927
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've changed all oils to fully synthetic engine 5W30, gear oils and diff oils Liqui Molly during my service at the time of installing SC.
OEM oils are good fully synthetic except for the Diff for some reason, it was semi synthetic.
I fitted the GReddy magnetic oil sump plug, was surprised what was stuck to after 7500km.
Ryan86 is offline   Reply With Quote
Old 01-27-2014, 02:58 PM   #2928
whataboutbob
AutoX-10/10ths every run
Originally Posted by xxscaxx View Post
I don't think anyone ever answered this question I brought up: You all still using the stock weight oil or have you moved to something different after supercharging?
I spoke to a Subaru tech at the autox this weekend and he said the 2014 forester with the boosted FA20 uses 5-30. That'll be what I run next. So far used 0-20 OEM and 5-20 RP.
Build thread:Here
Old 01-27-2014, 03:10 PM   #2929
Ryan86
Road Warrior
Ryan86's Avatar
My apologies we on 5w30 here in SA.
Toyota change the 0W20 to 5W30 at first service.
Old 01-27-2014, 06:01 PM   #2930
DriftEm
DriftEm's Avatar
5W30
DriftEm is offline   Reply With Quote
Old 01-27-2014, 06:28 PM   #2931
Calum
That Guy
Drives: 2013 asphalt FRS MT
Can you ask him if the bearing clearances are the same between the engines?
Old 01-27-2014, 10:09 PM   #2932
whataboutbob
I see him infrequently. I'll try to remember.
I was talking to Mike @infamousperformance today about the boosted FA20 and he told me they had lowered the compression on the motor. He or someone else who has access to the data might be able to chime in.
Build thread:Here
Old 01-27-2014, 10:29 PM   #2933
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I am going to throw in a little more of my opinion about oils here so take it for whatever it is worth. The first number in oil is some magic number that somehow relates to viscosity when the oil is somewhere near room temperature I believe. Maybe a little colder but is beside the point. Second number is the same except for when the oil is hot. The only way we get two different numbers for hot and cold is with additives. Lucky for us, they have been getting better with synthetics and have achieved a pretty large spread ie 0w-30. 0 (something) when it is cold and 30 (something) when it is hot.
Okay get to the point.
The thinnest oil we can make is still wayyy too THICK at room temperature. So we want oil that will give us what the engineers designed for at operating temperature and as thin as possible at room temperature. I don't care what number you decide to run for the hot number but you should run the smallest number "0" for the cold number.
That's my .02 (something) the internet told me all of this somewhere.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 01-28-2014, 04:52 AM   #2934
Calum
That Guy
You're talking about viscosity index. Which is the measurement of how much an oil changes it's viscosity as temperature changes. It is certainly a good point but not the whole story. Not that I know the whole story either.
Sent from my GT-S7560M using Tapatalk
Old 01-28-2014, 06:11 AM   #2935
NickFRS
Drives: 2013 Asphalt FRS
i'm still running 0-20 Mobile 1. But i'm thinking about changing to 5-30 mobile one once all my 5qt's are drained out.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 01-28-2014, 06:22 AM   #2936
NickFRS
I have not made a post in here for a while but here is an update. My car finally has 0 issues. After much time spent it seems everything has been sorted out. I'm also running a new intake/exhaust set up. Here is what changed.
Having my tuner change me from FFS/LC map to a standard map with no FFS/LC also fixed my belt sequel on hard shifts. I didn't like the features anyway with BRZedit.
Before:
RevWorks UEL header, Nameless 2.5 OP/DP combo w/High Flow Cat, Nameless insane 3in to dual 2in catback exhaust proto type, Perrin 3in Intake (proto), and stock spark plugs.
After:
Stock Header w/Cat GUTTED, Stock OP, Stock Front pipe w/Cat delete and w/Resonator delete, Nameless insane 3in to dual 2in catback exhaust proto type, Stock Air Box w/Cosworth dry filter, and Two step colder HKS spark plugs.
@DarrenDriven my current dyno ^
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 01-28-2014, 09:28 AM   #2937
swift996
swift996's Avatar
I posted this in my thread, it's a pretty lame video but I wanted to play with my gopro and windows movie maker. I plan to make a better video after I install my intercooler. Should be able to get a dyno video up here soon too:
[ame]http://youtu.be/pa5gO5gliME[/ame]
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-28-2014, 10:13 AM   #2938
xjohnx
Grip>Slip
xjohnx's Avatar
odd, my wideband was showing a little lean this morning on my way to work when flooring it (~13.2-13.5). It usually reads right around 12.0-12.3. Hopefully it was just a fluke. I'm going to take it easy on my drive home for lunch and if it's still doing it get some logs fired off to @DeliciousTuning
Old 01-28-2014, 12:58 PM   #2939
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Make sure you have no vacuum leaks after the MAF sensor. If you do this can cause the lean condition you are seeing. Otherwise send me some logs and I will review them.
Cheers,
William Knose
Old 01-28-2014, 01:23 PM   #2940
xjohnx
Grip>Slip
xjohnx's Avatar
Cheers,
William Knose
none that I could see. all the hoses on the manifold and couplers seemed to be connected securely. I'll grab some starter fluid on the way home and spray around with the car idling to see if i can locate any vacuum leaks.
I took a log and sent it your way about 5 minutes ago via the ticket i opened last night, but i don't see the ticket there anymore now.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
