Old 10-26-2011, 05:41 PM   #281
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by RRnold View Post
Thanks for the engine pic!
I thought it might be a breather intake but it does look more like an airbox resonator.
Is it me or does the intake looks like it's made out of plastic!?!
Sadly plastic intake manifolds are common these days (well more common). Good for some reasons (thermal) bad for becoming brittle over time and cracking
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2011, 05:48 PM   #282
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Ryephile View Post
Yes, plastic. That's a good thing as it will have excellent thermal properties to maintain cool IAT's even in traffic [good for power, bad for emissions].
From a longevity perspective, how long do you think that will last, especially with prolong exposure to heat? This is my first time seeing this, is this common with Boxer engines?
btw, what is that vertical box behind the radiator?
Old 10-26-2011, 05:49 PM   #283
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
^That intake manifold have covered w plastic. Inside still have aluminum. Recent EJ engine have been doing that
Old 10-26-2011, 05:59 PM   #284
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ah, that would be a good thing if it's like the EJ.
RRNold: I've replaced a few on Ford 4.6L mod motors and they tend to last 5-10 years before cracking and spewing coolant everywhere.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2011, 06:11 PM   #285
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
If you mean the box to the left of the filter I'm not sure that's connected to the intake at all, that looks like a guard similar to the alternator one but it's hard to tell from that pic.
Agreed on the filter. I love that location!
The box is a resonator box (left of the airbox and in front of the tube/alt).
Yup
quik1987 is offline   Reply With Quote
Old 10-26-2011, 06:14 PM   #286
ichitaka05
Site Moderator
ichitaka05's Avatar
^One thing still don't know is AC...
In that VLN pic, AC unit is missing... & from the Geneva BRZ engine layout it's one serpentine belt, so if you take AC off... well you get my point.
Old 10-26-2011, 07:55 PM   #287
madfast
Drives: 2010 Evo X MR-T
ecu? any experts out there that can tell if its a toyota ecu or subaru? yes both use denso, but is there perhaps a telltale sign that its more toyota-like or susbaru-like?
seems like the boxy looking guard between the intake pipe and oil filter is hiding it. in the frankfurt BRZ engine pics, you can see what looks like a clutched pulley.
madfast is offline   Reply With Quote
Old 10-26-2011, 08:25 PM   #288
RRnold
2 wheel member
RRnold's Avatar
If it can last 10 yrs then it has served it's purpose. As Ichi mentioned, it's more of a cover/insulator. If it was fully plastic, I was going to assume it would be molded out of a composite epoxy material to withstand the heat or be fire retardant.
I thought it was an ecu too but since it was an ackward yet convienent place, that threw me off. The wire loom sort of gives it away but I'm used to seeing the ecu behind the firewall.
Seeing the boxer layout is really intriguing; the battery angle and the position of the radiator not being centered.
Old 10-26-2011, 09:39 PM   #289
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Boy they have got some big pluming in there, that being said I have no clue what that long tube on the right is. But I think that box up front is a cold air induction box.
chulooz is offline   Reply With Quote
Old 10-26-2011, 10:11 PM   #290
ichitaka05
Site Moderator
ichitaka05's Avatar
Subie always had em on inside passenger side foot area.
No, it's AC. frankfurt BRZ you can see AC on the right, but on VLN one is missing the AC. If you see the Geneva's BRZ chrome engine and follow that serpentine belt, it's one belt. If you delete the AC, you can't really do it... Do you see what I'm saying?
Old 10-27-2011, 12:19 AM   #291
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You bolt an idler pulley in that spot. It's easy to make one, especially for Toyota/Gazoo.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-27-2011, 03:54 AM   #292
Tyandriel
Drives: Supra MkIII
the box in the front could be a fuse compartment. But the bracket (front left corner) speaks against that.
If the ECU is under the bonnet, i´d say its the small black box on the left edge in the pic. That looks like one. And it has some advantages not having the ECU behind the firewall. You save space and you have parts less needing two positions (RHD/LHD) including the damn harness.
Tyandriel is offline   Reply With Quote
Old 10-27-2011, 06:44 PM   #293
Slide
Drives: Toyota Aristo
Could be bothered searching thread but that oil filter says subaru...
Slide is offline   Reply With Quote
Old 10-27-2011, 08:34 PM   #294
Kiwi
Drives: Volkswagen Golf GTI
Well... It is basically a modified Subaru engine.
Would be weird if it was a Toyota filter.
Kiwi is offline   Reply With Quote
Pictures of Scion FRS in a different environment john FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 05-10-2011 05:46 PM
Report: Toyota FT-86 Sedan Version Coming Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 09-24-2010 10:45 PM
Report: Toyota FT-86 will move up in price and age demographic ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 201 06-02-2010 04:36 AM
Report: Baby Toyota FT-86 also in the works Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 60 05-17-2010 08:41 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 12:36 PM
