Old 10-15-2011, 08:14 PM   #281
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Marrk View Post
Dude, everyone on this forum is "certain" about everything. That's why making a simple post here is like entering a fight to the death.
Well, it was already posted a few pages back that it was an air jack and PA has been know to made a couple of bold statements since he has a "insider @ SOA"...thats why I found it hilarious. This is the internetz and thats why you have to have proof with everything you say.
Speaking of simple posts, instead of searching or actually reading previous posts, folks feel like the have to start a new thread even though it's been posted before.
Originally Posted by sfwg View Post
i hope there is a way to replicate this in the production model so once i get coilovers(post warranty) i wont have to roll it up on 2x4's just to get a jack under it.
I managed to see a couple of Porsches @ Willow and this owner mentioned AP Racing. You can add it to any car once you have a cage.
http://www.apracing.com/info/index.asp?section=Air+Jacks_974
http://www.d2racing.com/content/products/air_jack
Old 10-15-2011, 08:39 PM   #282
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
No way man, I found one post in 2005 where one person wasn't certain about something, so you're completely wrong. This is the part where I make a snide comment about your mother.
Anyways... I don't think I've ever seen air lifts on a street car. They have them on race cars because they have to change the tires as quickly as possible, but unless you have a full pit crew ready to change all 4 tires every time you stop for gas, there's probably better things to spend money on. Plus they need a constant supply of air to keep the car up so they wouldn't be that useful or safe for working under your car. It would be cool though...
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 10-15-2011, 08:40 PM   #283
sfwg
Drives: 2007 saturn ion(dd)
made my day
sfwg is offline   Reply With Quote
Old 10-15-2011, 09:17 PM   #284
Nurburgring
Drives: S2000, AE86, RSV10000R, 911, EP91
Originally Posted by serialk11r View Post
Because the red bar is at the 7400 mark, I assume that means max power happens around 7000. Combine that with the upper limit of 160lb-ft and I think we won't be seeing 210hp even, which if other people's calculations are mistake free requires 157.5lb-ft at 7000rpm.
Yes, disapointing news.
The FB20 was designed with fuel efficiency and emissions as a priority, it`s a long stroke engine with a disastrous rod ratio (1.44).
Tada San mentioned that the engine has been completely modified, they may have gone as far as modifying the bore/stroke as the engine block casting is known to be different from the FB20. Aparently, the restrictions imposed by the engine architecture still stand, as the 7400rpms redline shows, this is no high-revving engine.
Calculating from the FB20 numbers, it generates 196Nm @ 4200rpms and 150hp @ 6000rpms, which means a BMEP of 179 psi at torque peak and 162.5 psi at peak power.
Assuming they manage to keep that BMEP while moving peak power to 7000rpms, the FT86 engine would have 175hp.
Now we know direct injection is being implemented, which usually means a BMEP improvement in the 8-10% range. Using a 10% improvement, BMEP 178,75 @ peak power, calculations show that the engine would have 193 SAE hp. There is NO WAY this engine is making 210hp. It will barely make it to 200.
Nurburgring is offline   Reply With Quote
Old 10-15-2011, 09:24 PM   #285
serialk11r
Drives: '06 AM V8V Coupe
FB is very economy oriented, but more aggressive cams wouldn't be able to improve the torque that much since efficiency drops pretty fast after 75% atmospheric density charge.
I think we can see more than 200Nm at peak power, which could possibly bring it over the 200hp mark. I'm saying 210 if there is some kind of surprise addition of valve lift control which probably won't happen. Judging from the Subaru shiny engine picture there is no Valvematic which allows for an even more aggressive high rpm lift characteristic than your typical stepped system, so we definitely won't be beating the 2GR-FSE (no variable lift/duration) in terms of specific torque as I pointed out.
Old 10-15-2011, 09:24 PM   #286
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
If I'm spending 20+ grand on a second vehicle to have fun with, it better not have that kind of power
KaliKev is offline   Reply With Quote
Old 10-15-2011, 09:24 PM   #287
RRnold
2 wheel member
RRnold's Avatar
It was about a minute behind the Civic Type R and it's specs are:
The drive train is largely the same as the out going model offering 201 PS (148 kW; 198 hp) at 7,500 rpm and 193 N·m (142 lb·ft) of torque at 5,600 rpm. The car has a curb weight of 1,267 kg (2,790 lb).
One of Michel's pictures, I noticed the white exhaust tips. Could it be possible that they did some minor ecu tuning with race gas to get some gain?
Old 10-15-2011, 09:37 PM   #288
RWD_only
Lurks 'n stuff
Drives: 1994 Mazda Miata
Comparing the race version of the CTR to the street version is useless. It's like saying the ST class Civic in Grand-AM only has 197HP and I can tell you with all certainty...they got a lot more than that.
RWD_only is offline   Reply With Quote
Old 10-15-2011, 10:13 PM   #289
RRnold
2 wheel member
RRnold's Avatar
Originally Posted by MatadorRacing_F1 View Post
SP3 = close to stock.
Originally Posted by Dark View Post
Which means, no power bump, but slight suspension mod?
Originally Posted by Harinjo View Post
Number 258
TEAM Gazoo Racing
DRIVERS
Kagayama, Masahiko
Takaki, Minoru
CAR
Toyota FT86
Opponents in same class - Civic Type R, S2K, Astra OPC
How so!?!
Old 10-15-2011, 11:16 PM   #290
r1vale
Drives: Celica, Yamaha R1
I think I'm gonna have to clarify a few things here.
Sp3 (like all SPecial classes) isn't a stock or even close to stock class. Far from it!
Actually you're allowed to change, tune or mod (almost) everything you want. For example you could swap the engine for another engine of the the same make, or you could modify your engine by changing the bore/stroke, the crank, the camshafts, etc. The only limitation is, that your block needs a serial number on it, that identifies it as a product of your carmaker.
If you want to take a look at the regulations, you can find them here:http://adac.24h-rennen.de/uploads/me...ng_2011_01.pdf (Sp classes start page 61, engine stuff page 64)
And because of that the Civic is a real full on Racecar and not anywhere near stock. More Info on the Civic:
http://mugeneuro.com/index.php?mact=...t01returnid=60
http://www.jasmotorsport.com/en/RaceA.aspx?Id=85&Aut=90
If you want to compare the FT to other equally stock cars, you should take a look at the V3 class as those cars will have rougly the same mods as the FT and also have 2l engines.
This chart will give you a rough idea of their abilities and specs: http://www.vln.de/includes/download...._Matritzen.pdf
r1vale is offline   Reply With Quote
Old 10-15-2011, 11:27 PM   #291
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
if you consider fun a straight line, then you should just move along to the muscle cars
VenomRush is offline   Reply With Quote
Old 10-15-2011, 11:53 PM   #292
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
Drives: 92TalonAWD, 93RX7, 11F150EcoBoost
Send a message via AIM to 82mm 4g63
I'm sorry, but I must respectfully disagree. I'm buying a car to have fun in, not only in a straight line or on twisty curves, but with every day driving. They're not building this car with ONLY curved roads in mind, they're marking it as an economical, low-budget sports car. So the thing better be fun to drive in all situations. If I want to pass my grandmother in her V6 Camry on the freeway, I shouldn't have to downshift, peg it, and pray that she takes her foot off the accelerator.
While I'm not expecting a 350hp 2-liter, 200hp here in 2011/12 isn't THAT much to ask. I'm actually pretty confident that it will be pretty damn close to 200hp with all the tech going into it and knowing Yamaha is getting their hands on it.
82mm 4g63 is offline   Reply With Quote
Old 10-16-2011, 12:07 AM   #293
Dark
Elite Padawan
Dark's Avatar
You're right, it should be close to 200hp. Maybe a few hp less on Toyota model, and a few hp more in Scion . If you want a little more HP, you can go to aftermarket for easy bolt-ons.
Dark is offline   Reply With Quote
Old 10-16-2011, 12:09 AM   #294
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
I want a lot more HP. It won't stay N/A for long.
Bad news about race gas in california. Tougerenner Southern California 15 09-13-2013 10:38 PM
OMG this is hilarious - motorcycle race bofa Other Vehicles & General Automotive Discussions 6 07-06-2011 07:37 PM
Leo Parente on Toyota Race Cars and Motor Sports (FT-86 included) Matador Scion FR-S / Toyota 86 GT86 General Forum 22 07-06-2011 09:07 AM
Mazda MX-5 GT Race Car...WOW Mouse Other Vehicles & General Automotive Discussions 9 03-31-2011 02:02 AM
what/who do you race Abflug Off-Topic Lounge [WARNING: NO POLITICS] 33 09-03-2010 02:13 PM
