Old 10-16-2015, 08:42 PM   #2885
vpt
Drives: 2015 Scion FRS RS-1
Hi Friends, I just got my 2015 FR-S Release Series 1.0. Can I use a 16" snow tires? or should I stay with 17".
Thanks in advance.
vpt is offline   Reply With Quote
Old 10-16-2015, 08:52 PM   #2886
swarb
Originally Posted by Shark_Bait88 View Post
Looking at a set of wheels right now in 17x8, and trying to decide between +35 or +40 offset. Currently on stock suspension with OEM crash bolts, producing very little camber (about -1 degree). Plans to do more suspension upgrades relatively soon for better alignment specs, and eventually springs or coilovers with a slight drop of around 1".
What will the difference be between the +35 and +40 with both stock suspension and a slight drop?
+35 would be 5mm further out. I would go with the +35 because it would look better.
Thanks in advance.
Yes 16" snow tires are fine. Many people use them. Some people use the oem wheels as the snow set, some just buy a set of 16's.
Old 10-16-2015, 08:54 PM   #2887
vpt
Thanks
Thank you for the reply swarb
Old 10-18-2015, 01:09 AM   #2888
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
That's what I ended up going with! Can't wait for them to get here.
Thand for the reply
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-22-2015, 03:51 PM   #2889
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
18x9.5 +34 lowered on Tein Lowering springs with whiteline camber bolts. What tires would be the prefered tire for fitment and grip?
Instagram: trevor.parque
Old 10-22-2015, 09:56 PM   #2890
newbrz
Drives: Limited Dark Gery Metallic BRZ
Hey guys! I bought Work Emotion Kiwamis. These are the measurements:
Front Rims: 18x8.5 +38
Rear Rims: 18x9.5 +38
Front Tires: 235/40
Rear Tires: 265/35
Lowered ~1in. (highest I could get from KW's V3)
I had these recommendations by a shop. Nevertheless the tires are rubbing at the rear. I added camber (front and rear at -2) to try and solve it with no success (I now understand I would have to buy upper control arms which are too expensive for me at the moment). But anyways, the tire is rubbing at the rear whenever I take a corner or when the car is heavy (with people or luggage). The time has come to change the tires (with no thread left and 2deg of camber you could imagine what it's like) and I want to buy tires that would fit, given stock camber and not rub at all.
Please note that the rubbing appears to be with the plastic, not the metal on the fender (the tire is not cut as in with the metal body of the car). Nevertheless, when it rubs constantly(like a lot of weight at the back) I can start smelling burning tire, so it concerns me a lot.
Any recommendations are greatly appreciated!! Thanks!!!!
newbrz is offline   Reply With Quote
Old 10-26-2015, 09:38 PM   #2891
15limited
15limited's Avatar
So I've seen a lot of people use 114.3 adapters, what about going to 120?
15' BRZ Limited 6MT Ice Silver Metalic
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 10-27-2015, 01:26 AM   #2892
churchx
churchx's Avatar
Drives: 2014 GT86
And i've seen most of people using native patterns. What about getting right bolt pattern wheels in first place?
Old 10-27-2015, 02:05 AM   #2893
Shims
Shims's Avatar
Drives: GTS86
Front: Rota Grid 18x8.5+44, 5/100
Rear: Rota Grid R 18x9.5+38, 5/100
Tyres: Hankook H452 225front, 245 rear
Eibach ProKit lowering springs
Will these fit with no problem?
Shims is offline   Reply With Quote
Old 10-27-2015, 08:04 AM   #2894
15limited
15limited's Avatar
There's a specific set of wheels that are on sale for about 1/3 of the price they usually go for, but they're 5x120. What do you mean by "native patterns"?
Old 10-27-2015, 10:45 AM   #2895
churchx
churchx's Avatar
Drives: 2014 GT86
under native pattern i mean 5x100. And what you'll gain from that sale you'll partially loose on conversion hubs/brakes to come with them and so on. Not worth it. Simpler bolt pattern changing spacers might be not that expensive, but still will limit what eg. offset wheels can be, will be a bit less reliable, under some track rules are not allowed to be used and so on.
Old 10-27-2015, 07:27 PM   #2896
15limited
15limited's Avatar
Makes sense, seemed like a bit of a stretch to change bolt sizing that much. thanks for the info!
Old 11-02-2015, 02:14 PM   #2897
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
Just a general question... To get my winter tires installed, should I bother with a shop (I already have the tires mounted / balanced via tirerack) or just suck it up and buy a new torque wrench?
And if so any recommendation on a torque wrench to purchase?
02.ACCORD.DUDE is offline   Reply With Quote
Old 11-02-2015, 06:31 PM   #2898
FR-Shred
FR-Shred's Avatar
17x10 +38
-1.5 camber front
-1 camber rear
springs, not coils
What do you think?
Also tires.. probably would be like a 285/40..
I can't really find anything on this size.. let me know! Thanks.
FR-Shred is offline   Reply With Quote
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
