Old 01-22-2014, 06:57 PM   #2829
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Hempo View Post
I've read some different things about this and maybe someone could shed some light on it.. What size is the pulley on the standard NON-IC kit in the states? Most are saying 75mm, what makes me wonder is that mine is 80mm..
it is 75mm standard.
Old 01-22-2014, 07:10 PM   #2830
swift996
swift996's Avatar
That would explain why i'm about 20-25hp short of most people with similar setups..
From what I've seen the US non intercooled has the 75mm and the Sprintex non intercooled has the 80mm outside of the US.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-22-2014, 07:18 PM   #2831
Raven604
Yeah but I believe they idler pulley on the sprintex kit is a different size equaling the same boost
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
The Following 2 Users Say Thank You to Raven604 For This Useful Post:
Ryan86 (01-22-2014), swift996 (01-22-2014)
Old 01-22-2014, 11:23 PM   #2832
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
A bit strange then when i ordered the kit from Titan Motorsport.. Anyhow will be getting the IC upgrade soon an then it will be E85 and 70mm all the way!
The kits with 80mm SC pulley has 60 mm idler pulley. Sprintex IC Kit comes with 75mm and 70mm idler pulley (I'm not 100% sure on the idler pulley size but you get the picture)
Before racing off and putting 70mm E85
Verify your boost on 80mm, then put 75mm check your boost.
You should be on 98Ron in Sweden and getting around 10psi .
Not sure who your tuner is , but you would need to retune for smaller pulleys.
Last thing you want to do is damage your internals.
I've gotRaceseng 72.5 and 70mm pulleys arriving tomorrow, which I have set up for dyno testing on Saturday. @DeliciousTuning new tune allows for the 75 to 70mm pulleys to be changed without retuning, awesome, so we will be able to test each pulley with the IC kit to see what boost and whp is obtained on 91OCT.
Will be interesting test.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
Ethan (01-22-2014)
Old 01-23-2014, 08:28 AM   #2833
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
The idler pulley will have no effect on the drive ratio between the pulley on the charger, and the crank pulley on the engine. It will NOT change the boost. The only thing an idler pulley will change is the length of belt required. Some guys are running a 1/2 inch smaller belt on the innovate kit with the 70mm pulley.. the other option is to run the original belt with a slightly larger idler pulley..
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following 2 Users Say Thank You to calispec For This Useful Post:
swift996 (01-23-2014), Xero-Limit (01-23-2014)
Old 01-23-2014, 09:47 AM   #2834
swift996
swift996's Avatar
My thoughts exactly.. So going from 80mm to 70mm would probably mean a shorter belt for me.
Not sure if this is the correct approach but seemed logical to me:
http://www.ft86club.com/forums/showp...postcount=2601
Old 01-23-2014, 09:52 AM   #2835
calispec
calispec's Avatar
Possibly.. I ran my 70mm for a while with the stock belt with no problems.. others have had a lot of problems with breaking belts. If you are going from an 80 to a 70.. probably..
There was a post earlier with a part number for a smaller belt you might want to check out.. I can't say what would be best because I haven't personally done it. maybe someone else can chime in..
www.GT86Mounts.com
Old 01-23-2014, 09:59 AM   #2836
xxscaxx
Drives: 2013 SWP BRZ
I've been running the blue gates belt on my 70mm pulley with no issues. Didn't run the stock belt on there though.
xxscaxx is offline   Reply With Quote
Old 01-23-2014, 10:11 AM   #2837
phloozy
phloozy's Avatar
Drives: Scion FR-S
I am still on stock and 70mm with no issues. Could you link me to the belt you are using? I want a spare in case an issue were to occur.
phloozy is offline   Reply With Quote
Old 01-23-2014, 10:14 AM   #2838
xxscaxx
Sure man, Part Number: k061015RB
[ame="http://www.amazon.com/Gates-K061015RB-Blue-Racing-Micro-V/dp/B000TTILZI"]Amazon.com: Gates K061015RB Blue Racing Micro-V Belt: Automotive[/ame]
The Following User Says Thank You to xxscaxx For This Useful Post:
phloozy (01-23-2014)
Old 01-23-2014, 10:58 AM   #2839
xxscaxx
So thats just around 6 psi for us dumb Americans
Hempo (01-23-2014)
Old 01-23-2014, 02:09 PM   #2840
xxscaxx
Theres not much else - Ryans case is a special one I think, not many other people have had to go through what he did lol.
You can replace the fittings in the back with Brass but its not necessary. I believe Innovate has recognized this issue and now makes sure these are heat cycled prior to shipping out so that they don't come loose, but you can just remove them and throw some teflon on them and tighten it back up.
I switched to the stronger belt just for the hell of it, not for an issue of any sort - my stock belt worked fine. I'd rotate the supercharger and make sure it spins without wobble prior, but I am not too sure what the cause has been for the belts breaking yet.
If you are going with the intercooled kit, you may have to buy new clamps like I did as the ones that were sent did not fit. I called Innovate and they said i'm the only one who has called about this, so I would appreciate if any other intercooled owners could check or chime in if they had this issue so I can report back to them.
Also the 3/8 line provided does NOT fit well on the plastic fitting/coolant reservoir. I managed to get mine on there but it took heating it up, and lube to get it on enough. I should have just replaced this line, so thats another thing to check.
Thats all I can think of for right now. Some others had issues with a pin missing on the extension harness for the MAP sensor but I am pretty sure thats been fixed and not of concern anymore.
normancw (01-23-2014)
Old 01-23-2014, 02:16 PM   #2841
xjohnx
Grip>Slip
xjohnx's Avatar
@civicdrivr and i noticed this too.
also, if you're installing the upgrade kit, taking off the elbow like @xxscaxx (i think it was you, anyway) suggested.
The Following 3 Users Say Thank You to xjohnx For This Useful Post:
civicdrivr (01-23-2014), normancw (01-23-2014), xxscaxx (01-23-2014)
Old 01-23-2014, 02:20 PM   #2842
xxscaxx
Yeah that line was a PITA, but I had already ran out to the store to pick up damn clamps already and I wasn't going back. But, if I ever need to remove that line, I know already I will be cutting both ends, or I will break the plastic fitting (like I did on the fitting on the back of the supercharger), and possibly the coolant bottle.
Its not a pressurized system so I am not sure why they provide a line that is so goddamn tight like that.
Did you have any issues with clamps? I received all sprung clamps, but the bigger ones did not fit over the water pump connections and nipple connections on the front/back of the supercharger (or on the heat exchanger)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
