Old 07-27-2017, 02:52 PM   #2815
strat61caster
strat61caster's Avatar
Originally Posted by renfield90 View Post
Is there even such a thing as a complete standalone oil to water cooler? On this count I think it's fine. So really it depends on what's considered the radiator core.
Seems to me you could add a standalone oil to water cooler, they do exist, just not as popular as oil/air or the integrated oil/water.
Couple different people offer this one, same concept, slightly different hardware and plubming:
http://www.ft86club.com/forums/showthread.php?t=33799
http://www.ft86club.com/forums/showthread.php?t=42511
ineedyourdiddly
Old 07-29-2017, 05:58 PM   #2816
xwd
I sent a letter to Doug Gill last year about the JR radiator/cooler combo and the answer was no it wouldn't be legal. Even if the dimensions were legal it's the "no other purpose" line for both of them that ends up making it illegal, as it's packaged as an all in one item. The radiator can function without the oil cooler, but the oil cooler can't function without the radiator. I meant to write a letter to add something to the radiator rule explicitly allowing radiators with integrated oil coolers.
The Following 5 Users Say Thank You to xwd For This Useful Post:
C4RBON (08-24-2017), cjd (07-30-2017), DocWalt (07-31-2017), strat61caster (07-30-2017), trvth (08-02-2017)
Old 08-06-2017, 10:53 AM   #2817
bslate3
Drives: 2015 CWP BRZ
Is the G Speed gas pedal relocation kit STX legal? I won one at yesterday's 86 autocross event.
If it isn't I don't want to install right before Solo Nats.
bslate3 is offline   Reply With Quote
Old 08-07-2017, 12:01 AM   #2818
cjd
cjd's Avatar
Drives: 2017 BRZ
Far as I can tell, no. I'm not even sure the Cusco pedal cover is legal since it stretches the "cover" concept...
Old 08-07-2017, 12:25 AM   #2819
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
The G Speed no for sure, it relocates the pedal base mount. Totally different concept than a cover type.
The Cusco, or any similar cover type, is fine as it simply bolts over the stock pedal.
14.2 BODYWORK
A. Pedal cover kits and other interior cosmetic accessories may be added.
justinco is offline   Reply With Quote
The Following 3 Users Say Thank You to justinco For This Useful Post:
bslate3 (08-07-2017), cjd (08-07-2017), smg1138 (08-16-2017)
Old 08-07-2017, 09:10 AM   #2820
bslate3
Ok thanks for the answer Justin.
Old 08-07-2017, 09:44 AM   #2821
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I just did the Whiteline rear subframe busing inserts and it feels great...what do all y'all STX guys use for the front, if anything?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
smg1138 (08-07-2017)
Old 08-07-2017, 09:49 AM   #2822
cjd
cjd's Avatar
Drives: 2017 BRZ
14.2 BODYWORK
Yeah, what has me unsure is that it is effectively a very thick cover... It moves the pedal face to be even with the brake. But I suppose a thick cover would be legal, so the Cusco would be too.
Old 08-08-2017, 08:41 PM   #2823
chickunfut
Low-Buck Ramp Truck
chickunfut's Avatar
Drives: 2016 Scion FR-S Release 2.0 #502
Sorry, I'm new to SCCA and trying to decipher these rules and the thought process behind the wording.
So with regards to the G Speed relocation kit.
Section 13.2 BODYWORK (SOLO Street)
A. Accessories, gauges, indicators, lights and other appearance, comfort and
convenience modifications which have no effect on performance and/
or handling and do not materially reduce the weight of the car are permitted.........
14.1 AUTHORIZED MODIFICATIONS (SOLO Street Touring)
All Solo Rules Street Category allowances, plus all allowances contained in Section 14.
So from my understanding everything allowed in Section 13 is also allowed in section 14.
Could you then argue that the relocation of the pedal is a "comfort and convenience" modification and does not have an effect on performance?
Or am I very far in left field?
chickunfut is offline   Reply With Quote
Old 08-08-2017, 09:09 PM   #2824
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
This was also my understanding on the rule. The GSpeed relocation kit doesn't physically change the shape or cover of the gas pedal. It simply bolts under the mount to raise it a 1/2 or less.
Its would have no effect on handling or performance, in fact you would be adding weight. I don't see how its illegal. It's a comfort item to make the brake and gas pedal closer to even to make heel-toe easier in the car.
Shneegle is offline   Reply With Quote
Old 08-08-2017, 09:22 PM   #2825
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
It probably could be! I hadn't thought of that when looking at the rules. So I take back what I said earlier.
However, the big difference is, "pedal cover kits" is explicitly allowed. Where as relocation kits are not.
You (or Brandon, who asked) can always email Doug for his take on the rule & part. The general rule of thumb with SCCA rules is; if it is not explicitly allowed, then it's not. Comfort & convenience is really broad.
Old 08-08-2017, 09:24 PM   #2826
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
All I use are DIF steering rack bushings. Not sure what others might be using elsewhere.
Old 08-16-2017, 12:17 PM   #2827
bslate3
Looks like STX runs last heat at Solo Nationals. We get to have all the OPR.
I'm looking forward to meeting everyone and seeing some familiar faces again!
Old 08-18-2017, 02:22 AM   #2828
e1_griego
e1_griego's Avatar
Drives: Many
Yeah I'm pumped for nationals.
STX 60/160, paddocked in Row 6.
e1_griego is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
