Old 04-15-2013, 12:45 PM   #1
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Cusco Oil Cooler
Wasnt quite sure where to put this, but thought here with the FI stuff might be okay. Cusco released their oil cooler (MT only) for the FRS/BRZ last night. Instead of another radiator surface, theirs links into the normal radiator piping for the car and runs on a plate at your oil filter to cool the oil. The Japanese website can be found below.
http://www.cusco.co.jp/products/etc-parts/86brz_mt.html
What are people's thoughts on this? Is it a viable option for keeping the oil cool in hotter areas? It seems inviting with its lack of adding another system in front of the radiator.
Quoted from their website (using the translation from google chrome) -
"Benefits of water-cooled engine oil cooler
· Since the cooling based on the cooling water circulation system by the radiator with a high and stable cooling performance is provided to the original car engine oil cooling stable and reliable at all times is possible.
• Because not install the radiator core cooling before air-cooled air conditioning capacitor like, there is almost no impact on the performance of the radiator cooling and air conditioning .
-Oil line to the core without cooling air-cooled like longer, because there is almost an extension of the oil line or increase the load on the hydraulic system, there is almost no degradation of reliability, such as oil leaks . By keeping a high pressure also you can normally performed properly to ensure lubrication and cooling of the engine oil circulation .
• You can run, unlike air-cooled engine oil cooling is carried out by circulating cooling water if the engine is spinning without relying on the traveling wind . Of engine oil cooling is possible even when the vehicle is stopped or when congestion that is midsummer.
· Unlike the air-cooled engine oil cooling is possible even in the running efficiently (under high outside temperature) hot summer . On the other hand it is possible to warm the engine oil with an increase in temperature of the cooling water (ambient temperature conditions is low) (early warm-up) winter . That remain stable until early speedy suitable temperature is raised to the temperature of the engine oil at low temperatures even when I can.
• In the event of a crash at the time of the event of circuit racing, such as air-cooled oil cooler mounted in the bumper type oil would leak such as rupture of the oil lines and the oil cooler core damage even seemingly minor crash risk of being non-self-propelled entails. Water-cooled engine oil cooler Cusco is also safe when I crash the event of not mounted in the bumper. Also does not require any processing of the bumper also. It is easy to mount in the engine room .
Eliminate the disadvantages of water-cooled oil cooler!
Testing water temperature is also reduced further.
☆ though it is reasonable and easy to install water-cooled! Outstanding reliability.
⇒ and tested thoroughly studied the circular configuration of the 86 & BRZ engine and type FA20, providing the core cooling water-cooled in the engine oil filter with engine oil cooler water-cooled 86 & BRZ Cusco prevent a loss of oil pressure and less oil piping, cooling water at the same time We also provide ease of installation when installed together to achieve high reliability and low cost performance and by the shortest distance lines may also have.
Water-cooled oil cooler typical structural core complex and expensive cooling, cooling water piping oil separate dedicated more complex models to increase the price further . Also decreases reliability by desorption cumbersome and also accompanied by a significant part of mounting the minute, increase the pipe. Dazzling them I have to eliminate the disadvantages .
☆ demonstrate the effect on the test circuit, the synergistic effect also decreases water temperature more!
⇒ actual driving tests on the track by Honjo (vehicles equipped with supercharged Cusco) Cusco 86 demo car. Car not installed water-cooled engine oil cooler Cusco oil temperature rises to about 130 ° around each time laps . Vehicles equipped with water-cooled oil cooler oil temperature stable Cusco (110 ~ 115 ℃) about near constant value even laps were.
There are differences even water temperature was measured at the same time further vehicles not mounted engine oil cooler, water-cooled Cusco increases with oil temperature with each lap, stable at just before 100 ℃ although, vehicles equipped with engine oil cooler, water-cooled Cusco is not I am about 5 ℃ low temperature stable than vehicles equipped with the.
Reason and stable temperature water temperature is lower by mounting of the engine oil cooler, water-cooled Cusco, there are two air bubbles' ※ cavitation by bypassing part in front thermostat cooling water line dedicated to the oil cooler in the cooling water ( heat dissipation effect of the cooling water was bypassed by exposing the body to the outside away from the hot engine cooling water lines can be increased further since point) 'is suppressed. ※ phenomenon of cooling performance is reduced fine bubble cavitation occurs in the cooling water =. Original performance can not be exhibited absorption and heat dissipation performance of the cooling water is reduced by prone near the thermostat and water pump change is likely to occur in the water flow and pressure of the cooling water, foam is generated."
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 04-15-2013, 12:47 PM   #2
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
this will just make me need a bigger radiator
Huehuecoyotl is offline   Reply With Quote
The Following 2 Users Say Thank You to Huehuecoyotl For This Useful Post:
akuhei (04-15-2013), SkullWorks (04-15-2013)
Old 04-15-2013, 12:49 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
This and a Koyo radiator sound like a winner to me (pending actual cooling data).
BUT, still freaking expensive.
The Following 6 Users Say Thank You to Sportsguy83 For This Useful Post:
akuhei (04-15-2013), BolognaWalrus (08-30-2013), Mongo (04-15-2013), Murseman27 (04-16-2013), Nothing (05-20-2013), SkullWorks (04-15-2013)
Old 04-15-2013, 12:53 PM   #4
SkullWorks
Drives: SSM LT MT BRZ
I would prefer a system like this on a DD car, many people do not realize the danger in OVER cooling the oil in their cars. Oil needs to get hot enough to boil out the fuel and water tat accumulates, not to mention operating temp dictates viscosity...blah blah blah...
As gm... I mean Huehuecoyotl pointed out you are adding more heat to the water cooling system with this product, so make sure there is head room there....but this will obviously work well with an upgraded Radiator aswell...so plan accordingly...
SkullWorks is offline   Reply With Quote
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
Calum (04-15-2013), charged86 (04-15-2013)
Old 04-15-2013, 12:59 PM   #5
akuhei
akuhei's Avatar
Originally Posted by Sportsguy83 View Post
This and a Koyo radiator sound like a big winner to me.
I agree, definitely expensive, though the FBM cooler is $650, and Perrin is $690 (cusco is roughly $600 before shipping). But seems like it would keep clutter down. I am interested..dont know if i can justify the cost though...
Akuhei's Blog
"Inconceivable"
The Following User Says Thank You to akuhei For This Useful Post:
Sportsguy83 (04-15-2013)
Old 04-15-2013, 01:02 PM   #6
Mongo
Mongo's Avatar
I second this. A bigger radiator would seem necessary as the oem version is not designed handle that much work. But this style system does sound appealing.
As normal time will tell. I'll let someone else be the lab rat on this one.
Mongo is offline   Reply With Quote
Old 04-15-2013, 09:07 PM   #7
akuhei
akuhei's Avatar
Any thoughts from others as to how well this would work?
Akuhei's Blog
"Inconceivable"
Old 04-15-2013, 09:36 PM   #8
charged86
charged86's Avatar
This is how my 1.8t cools itself. I can build a air cooled oil cooler for loads less than 650. Setrab makes an sandwich plate. http://www.setrabusa.com/oilfilteradapters.html
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 04-15-2013, 09:53 PM   #9
wootwoot
Drives: FRS
I like the design. I think it should have come on the car stock. For DD, I think it would be great. For track days.... I'm not so sure. Water to oil coolers are much more efficient than the radiator type, but the heat exchanger on this unit is so small I am not sure it is up to the task of driving on the track. Perhaps someone who knows more will chime in soon.
wootwoot is offline   Reply With Quote
Old 04-15-2013, 10:51 PM   #10
xwd
http://www.ft86club.com/forums/showthread.php?t=32630
How hard is it to search for "cusco oil cooler"
Old 04-15-2013, 11:03 PM   #11
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Very much like the stock cooler on a K20. Why this isn't standard equipment I don't know.
Jeff86 is offline   Reply With Quote
Old 04-15-2013, 11:19 PM   #12
akuhei
akuhei's Avatar
No need to be mean about it. That thread hasn't been touched the 2nd of April, and the information I found was in a press release for the supercharger, dated 15April2013. I had no reason to attempt a search when I felt I had new information to share with everyone.
Akuhei's Blog
"Inconceivable"
Old 04-16-2013, 02:51 AM   #13
wootwoot
Drives: FRS
That other thread has no useful information in it anyway. We need someone to get one, or some data from Cusco, or something...
Old 04-16-2013, 03:18 AM   #14
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Hmm, in for more info
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 01:17 PM
New Cusco oil cooler ahaghshenas Engine, Exhaust, Transmission 11 04-02-2013 11:48 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 03:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 04:24 PM
