#2815 | |
Drives: '13 FRS - STX
Couple different people offer this one, same concept, slightly different hardware and plubming: http://www.ft86club.com/forums/showthread.php?t=33799 http://www.ft86club.com/forums/showthread.php?t=42511 |
#2816 |
I sent a letter to Doug Gill last year about the JR radiator/cooler combo and the answer was no it wouldn't be legal. Even if the dimensions were legal it's the "no other purpose" line for both of them that ends up making it illegal, as it's packaged as an all in one item. The radiator can function without the oil cooler, but the oil cooler can't function without the radiator. I meant to write a letter to add something to the radiator rule explicitly allowing radiators with integrated oil coolers.
#2817 |
Drives: 2015 CWP BRZ
Is the G Speed gas pedal relocation kit STX legal? I won one at yesterday's 86 autocross event.
If it isn't I don't want to install right before Solo Nats. |
#2818 |
Drives: 2017 BRZ
Far as I can tell, no. I'm not even sure the Cusco pedal cover is legal since it stretches the "cover" concept...
#2819 | |
Drives: 2022 GR86
The Cusco, or any similar cover type, is fine as it simply bolts over the stock pedal. 14.2 BODYWORK A. Pedal cover kits and other interior cosmetic accessories may be added.
#2820 |
Ok thanks for the answer Justin.
#2821 |
APEXHNTR
Drives: 10 Series FR-S #1867
I just did the Whiteline rear subframe busing inserts and it feels great...what do all y'all STX guys use for the front, if anything?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#2822 | |
Drives: 2017 BRZ
#2823 |
Low-Buck Ramp Truck
Drives: 2016 Scion FR-S Release 2.0 #502
Sorry, I'm new to SCCA and trying to decipher these rules and the thought process behind the wording.
So with regards to the G Speed relocation kit. Section 13.2 BODYWORK (SOLO Street) A. Accessories, gauges, indicators, lights and other appearance, comfort and convenience modifications which have no effect on performance and/ or handling and do not materially reduce the weight of the car are permitted......... 14.1 AUTHORIZED MODIFICATIONS (SOLO Street Touring) All Solo Rules Street Category allowances, plus all allowances contained in Section 14. So from my understanding everything allowed in Section 13 is also allowed in section 14. Could you then argue that the relocation of the pedal is a "comfort and convenience" modification and does not have an effect on performance? Or am I very far in left field? |
#2824 | |
Drives: 2013 FRS, 2024 Trueno
Its would have no effect on handling or performance, in fact you would be adding weight. I don't see how its illegal. It's a comfort item to make the brake and gas pedal closer to even to make heel-toe easier in the car.
#2825 | |
Drives: 2022 GR86
However, the big difference is, "pedal cover kits" is explicitly allowed. Where as relocation kits are not. You (or Brandon, who asked) can always email Doug for his take on the rule & part. The general rule of thumb with SCCA rules is; if it is not explicitly allowed, then it's not. Comfort & convenience is really broad.
#2826 |
Drives: 2022 GR86
All I use are DIF steering rack bushings. Not sure what others might be using elsewhere.
#2827 |
Looks like STX runs last heat at Solo Nationals. We get to have all the OPR.
I'm looking forward to meeting everyone and seeing some familiar faces again! |
#2828 |
Drives: Many
Yeah I'm pumped for nationals.
STX 60/160, paddocked in Row 6. |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
