go_a_way1
Old 08-14-2015, 11:44 AM   #2815
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by blockii View Post
You guys think I'll run into any issues running 18x8.5 +33 with 245 40?
No issues with the wheel specs, but you should be running a 245/35R18 tire. 245/40 is too tall.
Slick is offline   Reply With Quote
Old 08-14-2015, 11:50 AM   #2816
Slick
Slick's Avatar
Originally Posted by Machfleury29 View Post
I was planning on putting new wheels and tires on soon.
i was looking at Avant Garde M310's 18X9 +30, TSW NURBURGRING 17X8 +35MM, or ENKEI RAIJIN 18X8 +48MM. I wanted to go with a 235/45 would there be any rubbing issues with these?? really wanted to make sure before i buy. i also plan on lowering 1inch.
Thanks
All over the map here:
  • 18x9 +30 will poke so make sure you have enough camber to make it work. Springs will likely not be enough (natural camber from drop), so crash bolts/camber bolts should do it.
  • 17x8 +35 should be fine with no issues
  • 18x8 +48 will be tucked in alot, but will fit. You will be able to lower it but will be limited to the amount of negative camber you can add. (Note: Raijin's are likely +45 offset in that size)
Tires:
Get the wheel sorted out first, then you can worry about tire sizing. All 3 of above choices should have a different tire size.
Old 08-14-2015, 11:58 AM   #2817
Slick
Slick's Avatar
Originally Posted by Pegasus_86 View Post
Appreciate thoughts on:
Front: 18x7 et35 with 225/40/18
Rear: 18x7.5 et35 with 235/40/18
TRD wheels with either Michelin PS2 or Pirelli P-Zero Rosso with stock suspension. Can't run the TRD recommended 215/40 up front due to local load rating compliance rules.
Why staggered by such a small differential? Hardly worth it for 1/2" wider in rear. Our cars can accommodate a much wider square setup.
Edit: I see that the staggered TRD option comes from Scion, which is a bit stupid if you ask me.
If you're stuck on the TRD wheels, go with the wider one and stay square (same wheel & tire all 4 corners).
Lots of room to run the same wheel up front.
You'll thank me when it comes to tire wear, rotation, etc...
Old 08-16-2015, 08:54 PM   #2818
nooserbtf
Drives: 2014 FRS
I just ordered avid.1 av52 18x8.5 +35 all around. I am lowered on fortune auto 500 coilovers with about 2 inch drop. I am unsure if I should run 225/40, 225/35, or 235/35. I would prefer to keep my current ride height if at all possible. The obvious goal is to not rub, especially the paint off my inner fenders. Also it is my daily driver. Any suggestions would be helpful. Thank you
nooserbtf is offline   Reply With Quote
Old 08-16-2015, 09:54 PM   #2819
Slick
Slick's Avatar
245/35R18 is the proper tire size for a 8.5" wheel.
Old 08-17-2015, 11:50 AM   #2820
Suparu
Drives: 2013 BRZ Limited
I want to order a set of Avid.1 AV-20's, will there be any fitment/scrubbing/etc issues with these wheels (my car has RCE Yellow springs and factory struts/shocks):
front:
18x8.5, 5x100 pcd, 73.1mm cb, 33 et/offset
rear:
18x9.5, 5x100 pcd, 73.1mm cb, 38 et/offset
I'm boosted and pushing almost 300whp so I wanted to stagger the rear. What size tires should I get? I really want to go as wide as possible without issues.
Suparu is offline   Reply With Quote
Old 08-17-2015, 12:11 PM   #2821
Slick
Slick's Avatar
front:
rear:
No issues with those wheels at all. If you find that they poke (up front), you may want to add camber or crash bolts up front to tuck the tops in a bit.
245/35 and 255/35 will fit without any problems, but going wider to a 265/35 in the rear is possible also.
How much lower than stock are you?
With a 265, you could be rubbing the outside edge of the fender and need to roll the lip a bit more than the factory bend. Inner wheel clearance should be fine. No issues up front.
The Following User Says Thank You to Slick For This Useful Post:
Suparu (08-17-2015)
Old 08-17-2015, 02:58 PM   #2822
Suparu
Thanks!
The RCE Yellow springs give approximately 0.75-0.8" drop over stock
Old 08-17-2015, 03:42 PM   #2823
Slick
Slick's Avatar
Thanks!
So you will likely need to put crash/camber bolts in if you want the wheels to tuck in a bit more.
Suparu (08-17-2015)
Old 08-17-2015, 04:30 PM   #2824
Suparu
gotcha, thanks for the reply. that's a big help!
Old 08-17-2015, 05:27 PM   #2825
mush
mush's Avatar
just wanted to make sure this would fit my car
i have bilstein b14 coilovers, the odd thing about them is that the springs are big like the stock ones
about 1.5inch drop
-1.5 camber all around
square 18x9.0 +35
what tire size would i need?
thanks!
Old 08-17-2015, 07:21 PM   #2826
Slick
Slick's Avatar
about 1.5inch drop
square 18x9.0 +35
thanks!
Wheel specs are good (it's what I run also, was on springs now on coilovers).
A 245/35R18 is the right tire, possibly fit a 255/35 but I think you'll need a bit more camber. I ran that last year with no issues but my camber was -2.2. Camber bolts will help with that though.
Keep in mind that tire sizing (nominal width) differs from one manufacturer to the next, so a 245/35R18 is the safer bet.
mush (08-17-2015)
Old 08-17-2015, 08:07 PM   #2827
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
Id like to leep my TRD springs for now on my RS1. But im also trying to learn the world of wheel fitment.... with that said...
Could I run a 18x8.5 +33 squared setup without any issues? +33 seems like it would rub on the front would it not? Also if I were to drop it on coils in the future would it have troubles then on the fender? Thanks in advance
Super Dave is offline   Reply With Quote
Old 08-18-2015, 08:05 PM   #2828
James426
Drives: 2013 FRS
Sorry noob mistake I created a whole topic when I should have posted here.
Hi guys
Looking at getting some Works D9R 18" rims
The shop has 8.5 +38 front and 9.5 +38 rear.
I usually see people with a larger offset on the rear when they do staggered.
Does having he same offset make sense in this case (staggered setup)?
Just wondering if it'll look weird.
Thanks a million for your advice all
James426 is offline   Reply With Quote
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
