Old 07-30-2015, 05:39 AM   #267
juliog
juliog's Avatar
Drives: 86
I have the Ptuning header, CEL comes up once a week. I usually clear it with an OBD2 bluetooth scanner. I could've disabled the CEL since I'm tuned with Ecutek, but chose not to.
juliog is offline   Reply With Quote
Old 07-30-2015, 06:51 AM   #268
churchx
churchx's Avatar
Drives: 2014 GT86
Oh, so it was just marketing claim :/. Imho they'd better remove it to not do false advertising. Reminds me of mistake in aFe header description, that initially claimed also stock header's heatshield fitment.
Another mad idea of mine was - if Ace header can get just by itself most power gains possible for NA, and rest of exhaust is stock, i wonder if 2nd O2 sensor wire extender harness + bung for it cut after second stock cat in frontpipe can work, or due it being later down exhaust path/different temperatures and other possible differences, sensor placed there will have off-readings compared to what expected anyway and this also won't work?
Old 07-30-2015, 07:19 AM   #269
raven1231
Don't think ace cares about the cel. There is no point in getting a header without tuning it.
CSG Mike (07-31-2015)
Old 07-30-2015, 07:22 AM   #270
steve99
unless you can duplicate the same reading from the o2 sensors as would be seen if the stock cat was in stock position on the stock tune then it probably going to trigger the cel P0420 eventually unless you disable cel, then your still stuck with the failed readyness test unless able to be forced reday by some code maniplation in tune as well
Old 07-30-2015, 10:28 AM   #271
Calum
That Guy
Drives: 2013 asphalt FRS MT
Does anyone remember the good ol' days when you could get a Casper's O2 simulator. Those things worked perfectly.
http://www2.epa.gov/enforcement/casp...-clean-air-act
I had one. I even tried to pull it apart to see the circuitry inside, to try to reverse engineer it. Unfortunately there was no way that thing was coming apart without destroying it.
Old 07-30-2015, 12:07 PM   #272
OkieSnuffBox
Drives: '23 BRZ Limited
Just out of curiosity, why would you buy a $1300 header and not have it tuned?
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
raven1231 (07-30-2015)
Old 07-30-2015, 12:14 PM   #273
juliog
juliog's Avatar
Drives: 86
I *am* tuned..
The Following User Says Thank You to juliog For This Useful Post:
Old 07-30-2015, 12:42 PM   #274
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Reading is hard, brah.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 07-30-2015, 12:49 PM   #275
OkieSnuffBox
I *am* tuned..
Curious why you still get CELs
Dudebro, it is hard. It's very hard.
That and I'm hungover as fuck and didn't read the rest of the sentence. That's on me.
Old 07-30-2015, 01:53 PM   #276
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
He said he didn't have the code disabled. That's why he still gets CELs. It has nothing to do with tuning. Tuning doesn't cause the car to look for different values - when someone is tuned and they no longer get CELs it's 100% because in the tuning process the tuner turned off the CAT Efficiency codes.
I'm tuned and I don't get CELs for that specific reason.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-30-2015, 10:38 PM   #277
steve99
I think he wants the CEL P0420 active so it does not stop the readyness check from completing. That way he can clear the cel p0420 drive for a bit till readyness check completes then he can pass the emmissions OBD check, while still tuned on catless header.
If you disable the cel code the readyness check wont ever complete and you fail obd readyness check.
just guessing though :-)
Old 07-30-2015, 11:58 PM   #278
Wepeel
Drives: '13 BRZ Ltd
I'm running OFT+OFH and just passed emissions inspection in PA. The OBD test was marked 'PASS'. I believe PA allows one or two readiness parameters to be failed but the printout didn't go into any more detail other than 'PASS'.
Wepeel is offline   Reply With Quote
Old 07-31-2015, 12:02 AM   #279
Why do you care so much about the CEL? I seriously doubt anyone buying an Ace header will not be tuned.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
bedabi (07-31-2015), chaoskaze (07-31-2015), djliquidsteele (07-31-2015), Hawk77FT (07-31-2015), OkieSnuffBox (07-31-2015), The Racers Line (07-31-2015)
Old 07-31-2015, 03:20 AM   #280
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by enivid View Post
I don't know of any modified 86 in Utah that has failed emissions yet.
Testing for the 2013 model year doesn't begin until next year.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Hyper4mance2k (08-01-2015)
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 07:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 10:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 09:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 01:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 07:22 PM
