Old 07-28-2015, 09:48 AM   #253
CSG Mike
CSG Mike's Avatar
Originally Posted by MaximeT View Post
If you disable the DTC, the readiness will stay to 0. Or do you have a way to set it to 1 ?
Contact your tuner
Old 07-28-2015, 09:51 AM   #254
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Contact your tuner
Was just a question, just curious
Edit : you don't want to work with french tuners
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 07-28-2015, 11:31 AM   #255
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by churchx View Post
Indeed, i just empirically guessed
Seriously, just stop. It's obvious you really have no idea what you're talking about.
Empirically guessed? Really?
Go look it up chief.
Old 07-28-2015, 11:47 AM   #256
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
You all need to move to Florida. Inspections? Emission testing? CARB? 91 octane? What are those?
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 07-28-2015, 11:51 AM   #257
AlexBinJackson
Drives: 2015 Brz Blue Series Pearl White
Lol people in California love to over react . It's not too bad to replace the headers before testing and reflashing back to stock. Just wait for carb (it's coming to you) and what is 91 I'm on e85 😋
AlexBinJackson is offline   Reply With Quote
Old 07-28-2015, 02:52 PM   #258
CSG Mike
CSG Mike's Avatar
If you don't need to go on the sniffer....
Old 07-28-2015, 08:59 PM   #259
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
This is so true. In the past 10 years, half the counties that didn't require testing now require testing in Utah. Diesels need testing, and chemicals were just switched over to low VOC CARB regulations.
If you don't have CARB now, you might be ok for a while. Where I'm at, CARB isn't a requirement, but it may end up being so in a couple years.
Coheed is offline   Reply With Quote
Old 07-29-2015, 10:40 AM   #260
enivid
enivid's Avatar
Drives: WRB JR BRZED
I don't know of any modified 86 in Utah that has failed emissions yet.
enivid is offline   Reply With Quote
Old 07-29-2015, 10:54 AM   #261
MaximeT
MaximeT's Avatar
If you still have one cat and 14,7 AFR, you should be fine with a warm engine.
Old 07-29-2015, 01:40 PM   #262
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Indeed, i just empirically guessed how it works...
I'm far from an expert, but my understanding is that O2 sensors read the partial pressure of oxygen in the exhaust stream, when compared to a reference air sample.
The partial pressure gets translated into a metric of combustion completeness (lambda - the normalized AFR).
The ECU begins with a target ideal AFR and "learns" the best AFR for your fuel, based on a recursive algorithm. Although you want to be near complete combustion, most ECUs try to cycle between lean and rich operation to keep the catalyst operating efficiently. The ECU spits out a target AFR at this point.
By combining the learned AFR of your fuel and the measured lambda, you get an estimate of actual AFR. The ECU compares the actual and target AFRs, which is useful feedback for the next combustion event. Correction is usually on the injector pulsewidth (since it's fast), but you can adjust the throttle or VVTI angles to manipulate the air flow (LOAD).
Regarding catalysts, the catalyst flow, health, and efficiency are modelled. Flow is simple enough, it's a fixed volume, with some flow restriction. 1st order system w. small time delay in the sensors. From a health and efficiency perspective, they estimate temperature and oxygen storage states. If you're actively storing and releasing large amounts of oxygen, the catalyst can be 90%+ efficient.
With an efficiency estimate and a time estimate... you can follow a volume of exhaust from the UEGO (upstream linear O2 sensor) to the HEGO (downstream switching-type O2). The metric for catalyst health isn't something I know much about... but going through the readiness cycle (lots of different driving situations) will help to guarantee that the models used to generate the health metric are accurate.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 07-30-2015, 12:25 AM   #263
churchx
churchx's Avatar
Drives: 2014 GT86
Thanks for actually writing info instead of having fun at my expense. It doesn't say much though how those aftermarket sensor spacers manipulate/affect readings for secondary placement or how PTuning's headers can claim no CELs when it looks normal bungs in yet another catless header, or how to affect readings to fool ecu in more precise manner.
Old 07-30-2015, 04:09 AM   #264
steve99
Drives: FT86
ptuning and ft86 speed factoy (catted header) can claim their header will not cause cel but that does not mean it wont trigger the cel in the real world.
The truth is some people might not trigger it and some will depending on luck mods and tune and fuel. The ecu will be looking for specific reading from both front and rear 02 sensors and apply some weird algorythm to the reaing over time, if the reading fall outside what the ecu algoythm is looking for over time then bingo you get cel.
its same with o2 spacers sometimes they work sometimes they dont, sometimes they just extend the time it takes cel to appear.
Ask both those manufactures if they will give you your money back if it trigger cel without disabling codes ect in tune and i doubt they will say yeah sure we will do full refund
Old 07-30-2015, 04:39 AM   #265
juliog
juliog's Avatar
Drives: 86
I have the Ptuning header, CEL comes up once a week. I usually clear it with an OBD2 bluetooth scanner. I could've disabled the CEL since I'm tuned with Ecutek, but chose not to.
juliog is offline   Reply With Quote
Old 07-30-2015, 05:51 AM   #266
churchx
churchx's Avatar
Drives: 2014 GT86
Oh, so it was just marketing claim :/. Imho they'd better remove it to not do false advertising. Reminds me of mistake in aFe header description, that initially claimed also stock header's heatshield fitment.
Another mad idea of mine was - if Ace header can get just by itself most power gains possible for NA, and rest of exhaust is stock, i wonder if 2nd O2 sensor wire extender harness + bung for it cut after second stock cat in frontpipe can work, or due it being later down exhaust path/different temperatures and other possible differences, sensor placed there will have off-readings compared to what expected anyway and this also won't work?
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
