Old 01-28-2014, 09:37 PM   #267
3essess
Drives: frs
I'm still liking the BIN way so...any idea when the BIN files will be released for the 1.5 version? I have a 700c ecu.
Thanks.
3essess is offline   Reply With Quote
Old 01-28-2014, 09:53 PM   #268
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Does anyone know why the car doesn't bounce off the redline anymore with the new 1.54 tune? I don't like how it just sits at 7400.
cjsporl1996 is offline   Reply With Quote
Old 01-28-2014, 09:58 PM   #269
steve99
I believe this is by design ,soft rev limiter feature. As opposed to face in the dash cut out.
Old 01-28-2014, 10:17 PM   #270
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I like this sift Rev limiter better
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-28-2014, 10:24 PM   #271
Malt
Drives: 2015 WRX
Why would you want it to bounce if the limiter? That's a good way to destabilize the car if it happens mid corner.
Malt is offline   Reply With Quote
Old 01-28-2014, 10:31 PM   #272
vynervt
Drives: GT-86
@shiv@vishnu
I having same issue like jflogerzi, which i had uploaded dev.file into the OFT. Read the ECU. OFT appeared "generate a tuning file" but the 'write' option is grayed.
I had flash my ECU back to original map before I erase all data in the OFT.
vynervt is offline   Reply With Quote
Old 01-28-2014, 10:57 PM   #273
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I love the softer rev limit, but I changed the gap to 100rpm instead of 50rpm because it is enough of a difference to know you hit it. There were times where I was on the limiter and didin't realize it because I was part throttle.
Luckrider is offline   Reply With Quote
Old 01-28-2014, 11:21 PM   #274
jflogerzi
jflogerzi's Avatar
Originally Posted by vynervt View Post
@shiv@vishnu
Flash back to stock rom. Then Read the ECU from your car. Take OFT back to your computer and save the stock rom from OFT Manager onto computer and email it to Shiv. He will add it to the database and then he will send you a new .dev file. upload this to the OFT. After this read the ECU one more time and you should now have the write option and enjoy your new tune.
The Following User Says Thank You to jflogerzi For This Useful Post:
vynervt (01-29-2014)
Old 01-29-2014, 12:53 AM   #275
akyp
Drives: 2012 86
Originally Posted by shiv@vishnu View Post
Still working on a solution to update old 700 and 900 series ROMs to the new v1.5 maps. Until then, running the v1.4 maps is the only option.
I have scheduled a dealer visit next month. Should I ask them to update to the latest stock ROM available? What is the current latest cal ID for 700G?
akyp is offline   Reply With Quote
Old 01-29-2014, 01:14 AM   #276
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
I had to print out the RPM drop TSB to get the dealer to flash my ECU.. Keep in mind I actually had the RPM drop issue. They could never recreate the issue. I had to show them the print out before they did anything.
Sent from my XT912 using Tapatalk
Terrapin77 is offline   Reply With Quote
Old 01-29-2014, 01:16 AM   #277
vynervt
Drives: GT-86
I had email my Stock Rom file to Shiv since yesterday sadly no reply from Him.
Old 01-29-2014, 01:17 AM   #278
jflogerzi
jflogerzi's Avatar
Send him a pm or mention him in this thread. He did not get my first email either. Dont worry he will take care of you. Also did this stock file come from oft or your old ecutek tuner?
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 01-29-2014, 01:38 AM   #279
vynervt
Drives: GT-86
Thanks @jflogerzi, I will PM him again. I only use OFT didnt purchase Ecutek. The Rom file I had sent to him is actual original ROM.
Old 01-29-2014, 01:53 AM   #280
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I just added your ROM to the database. I'll email you the new .dev file in a few min
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
vynervt (01-30-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 03:26 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
