Old 07-18-2014, 09:32 AM   #267
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Originally Posted by plucas View Post
The window filler probably doesnt do much. Might reduce a little drag but doubting it. I would ventue and say it is cosmetic.
If you're willing to continue the functional vs. cosmetic discussions... what do you think of the Porsche 918 Spyder's fender vent?
I may be building some carbon fenders soon, and this was an interesting feature, considering it isn't placed in either of the low pressure zones that we identified earlier.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
plucas (07-18-2014)
Old 07-18-2014, 09:48 AM   #268
plucas
plucas's Avatar
Drives: Subaru
Those are functional. They are designed to bleed high pressure from the fender well to decrease lift.
plucas is offline   Reply With Quote
Old 10-28-2014, 02:26 AM   #269
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by dasklein View Post
As EarlQ pointed out, Aeromotions has 3 active aero applications that differ by either actuation type (internal/external) or single element vs. split element. We just did a BRZ fitment with our "static" wing which can be seen here: http://aeromotions.com/products/by-c...ic-subaru-brz/
This static fitment can be upgraded to active as well using our external R.Module.
We've also built the active front splitter that you are referring to. We did extensive CFD testing on it, then took it to the WindShear 180mph rolling road wind tunnel where the Nissan Delta Wing was tested. We have some info on it here: http://aeromotions.com/project-cars/...hallenge-aero/
We do implement a Drag Reduction System (DRS) like F1, so that there isn't much of a drag penalty.
One thing to note on our BRZ testing: our airfoil is very unique (even though it looks very basic), and implements a concave pressure recovery system which seems to have a huge benefit with the BRZ shape (the window rake + factory deckled specifically). In static mode, we only need 2 degrees of angle of attack (AoA) to achieve perfect balance. And because of our low drag shape and only needing 2 degrees of AoA, there isn't much of a drag/speed penalty.
The factory BRZ Limited wing is supposed to reduce the C/D by. 01, so would you recommend retaining the OEM spoiler with your R Static wing?
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 10-30-2014, 02:18 PM   #270
zdr93523
zdr93523's Avatar
What modifications or design features would the fender liner need, if anything, to make this effective?
www.makesmodels.com
www.camautomag.com
Old 10-30-2014, 07:55 PM   #271
Gunman
Drives: 2019 Mazda Miata RF
Hole, and duct to get the air out. I'd screen it too, so debris doesn't fly out.
Gunman is offline   Reply With Quote
Old 10-30-2014, 07:59 PM   #272
zdr93523
zdr93523's Avatar
I was hoping for a more technical answer.
www.makesmodels.com
www.camautomag.com
Old 10-30-2014, 08:42 PM   #273
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
I believe that is the technical answer.
dradernh is offline   Reply With Quote
Old 10-30-2014, 08:44 PM   #274
zdr93523
zdr93523's Avatar
It wasn't, it was a vague response. Not technical or informative.
www.makesmodels.com
www.camautomag.com
Old 10-30-2014, 08:59 PM   #275
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The radius of said hole should be no smaller than .23mm and no larger than 5 yards.
The ducting used should be of a plastic, rubber, carbon fiber, or aluminum construction. Please refrain from using rigatoni or crazy straws, as the airflow may become restricted.
You may use a screen of metal or plastic construction. Pantyhose is fine too, we won't judge.
I don't suggest painters tape as a fastener, as the blue finish may dictate your wardrobe, and that could turn into a thing. I do suggest duct tape, as the silver-gray color is complimentary.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following 4 Users Say Thank You to civicdrivr For This Useful Post:
BirgeyT1 (10-31-2014), Gunman (10-30-2014), NissanGuy (11-04-2014), Rosticles (10-31-2014)
Old 10-30-2014, 10:16 PM   #276
dradernh
Originally Posted by civicdrivr View Post
The radius of......the silver-gray color is complimentary.
I had to laugh - that was good.
The Following User Says Thank You to dradernh For This Useful Post:
civicdrivr (10-31-2014)
Old 10-30-2014, 10:27 PM   #277
Turdinator
Señor Member
Turdinator's Avatar
Something I have been wondering is what happens to the aero in our front wheel arches? There has been a lot of talk on the forced induction forums about how to get the hot air out of the engine bay. Could you duct some of the flow through the radiator out the wheel wells?
1974 TA22 Celica
2013 86 GT
Old 10-30-2014, 10:29 PM   #278
Gunman
How much more technical do you want?
Packaging is going to dictate how big, and where the duct goes. CFD, tunnel time, or other aero studies will let you know if it's too big, or too small.
Getting the air out is the key.
Old 10-30-2014, 11:06 PM   #279
zdr93523
zdr93523's Avatar
I need to look up what the fender liner and venting system looks like on vehicles that have functional vents. Then we'd have a good concept of how we could apply that concept to our cars.
www.makesmodels.com
www.camautomag.com
The Following User Says Thank You to zdr93523 For This Useful Post:
Old 10-30-2014, 11:28 PM   #280
plucas
plucas's Avatar
Drives: Subaru
I would do as large of a hole at the top as possible and only as big as the ducting will allow. Build ducting the narrows (decreasing cross-sectional area) to the outlet. Some sort of gurney or wicker at the outlet for added effect if needed.
I can look in our CAD of the car and see what we can do there.
The Following 2 Users Say Thank You to plucas For This Useful Post:
civicdrivr (10-31-2014), zdr93523 (10-30-2014)
Front aerodynamics... need help! TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 16 10-23-2012 10:27 PM
Interesting aerodynamics differences between USDM, JDM, etc. yargk Scion FR-S / Toyota 86 GT86 General Forum 25 09-20-2012 05:00 PM
Coefficient Drag & Aftermarket Aerodynamics FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 1 06-28-2012 02:20 AM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-26-2012 10:19 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-21-2012 01:47 PM
