Drives: '13 86
Front aerodynamics... need help!
I need some input from anyone who's got some expertise on aerodynamics.
I've been looking at various bodykits with the goal of increasing front downforce in mind. Want something functionally-minded, but as this is my daily driver I don't want something *too* race-track ready (i.e. a big front-diffuser jutting out, getting caught on curbs and speedbumps and driveways). So I was excited when I saw the Vertex Japan kit, as it seemed to be clean, not over-the-top, but still provide surface area to affect downforce. Then I noticed the middle section of the front-lip... ![]() ![]() Now, is it just me, or does it seem like that section will cause the front end to lift, rather than hunker down? That was my thinking, anyway... so I dismissed it as just another kit that was putting style ahead of substance. But then I started noticing other kits with that same sort of upturned middle section, notably the Garage Vary kit... ![]() ...and the Rocket Bunny kit... ![]() So here's my question: is there some secret to the aerodynamics on the FR-S/ 86 body that makes this upward-deflection area a good idea? And if so, can somebody explain it to me why? Best I can come up with is that it might speed up air flowing under the car, therefore creating low-pressure and drawing the entire vehicle down. But if that's the case, would our cars need the under-panels that are present on the JDM model GT-Limiteds to make this effective? ![]() Thanks in advance for any help... |
Drives: really slow...
Do some research on flat underbody panels. It may yield valuable information for you that will help you with this.
Drives: '13 86
So you're saying that these, err... plow-sections? (don't know what else to call them)... on the front-lip kits smoothen out the air flowing under the car?
Drives: TOYOTA
Garage Revolution has a functional front lip for the 86. Given their presence in the WTAC, I don't doubt their claim that it actually works.
http://revo-tune.jp/catalogue/detail.php?id=303 |
#5 | |
Drives: '13 86
Drives: '23 CWP BRZ
Just buy some canards
Drives: 2013 Scion FR-S (Hot Lava)
Your best bet is going to be getting a front splitter with some canards. After that I would recommend a flat underbody - I believe you can now get that imported from Japan. Lastly, look into getting a diffuser. For all intensive purposes, the front splitter would be your best best on getting more downforce.
Additionally, lowering the car also gives you more downforce, though it is not that substantial. |
Drives: '13 Argento FR-S
http://en.wikipedia.org/wiki/Diffuser_(automotive) ...so yes...it looks as if the part in question acts just like an upside down airplanes wing to create downforce...
Edit: http://www.rapid-racer.com/aerodynamic-upgrades.php BTW i hate this thread its 30 minutes later and im still researching this info just because...
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
Drives: Supercharged Car
As you assumed earlier, air will be moving faster underneath the car with correctly designed front lips and under body panels. Think of an airplane wing, or airfoil. Air moves faster on top of the wing and slower below. Slower air below, means higher pressure under the wing, thus causing lift. The intentions of the front lip and under panels is the exact opposite, thus creating higher pressure on top of the car which is your desired downforce.
#10 | ||
Drives: '13 86
![]() Thanks guys! A million threads on suspension and exhaust mods, but aero gets treated like some sort of voodoo black magic on here. |
#11 |
as far as ordering the under panels...i plan on getting some sintra board or similar and making my own under trays...should be cheaper and work exactly the same...
#12 | |
, BUT i'm assuming not all aftermarket companies actually test their prototypes in wind tunnels, which can mean some may be purely aesthetic.IIRC, lengthening a body behind it's leading edge reduces the separation (of air flow) and should help with creating a more slip stream body.. So, by adding under body panels this should lengthen the surface of usable area behind the lip to prevent this phenomena from occuring. The Less turbulent air under the car means lower pressure underneath the car meaning your additional downforce. |
#13 | |
First86 / boat thief
Drives: MKIV Supra
#14 |
Klaatu barada nikto
Drives: Raven FR-S MT
Air is going under there whether you like it or not. There is only so much air you can block/deflect. But, if you can speed it up you can use the air more effectively.
I'm in no way an expert, hell, I can't make a paper airplane that flies straight, but watched a great, two hour long, aerodynamics video a few years ago, fasinating and informative. James May would've loved it. Could I find it in a google search?? Nope... Grrrrr. Sorry, I tried Check out most supercars, lots of them have it too. The McLaren F1 was born in the wind tunnel. Gordon Murray wanted air to go down the middle.
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) |
| Interesting aerodynamics differences between USDM, JDM, etc. | yargk | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 09-20-2012 04:00 PM |
| FRS APR FRONT LIP | sidnacious | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-06-2012 06:50 PM |
| Coefficient Drag & Aftermarket Aerodynamics | FT-86GOD | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-28-2012 01:20 AM |
| Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained | Moshpit37 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 06-26-2012 09:19 PM |
| Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained | Moshpit37 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 06-21-2012 12:47 PM |
