Old 05-09-2020, 04:38 PM   #267
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm sure big tuner names like HKS and GEeddy will pop out some parts for the GR Yaris and Corolla. It would be nice to see some aftermarket support. Hell TOMS is doing it with the regular Corolla hatchback lol
MS, CSCS, TSAC-F, CPT
Old 05-09-2020, 04:43 PM   #268
strat61caster
strat61caster's Avatar
The "hot" Corolla will be competing with the Focus ST.. However, if Ford hadn't cancelled the next gen RS then who knows?? You may have got your AWD GR Corolla..
The US Focus was canned two years ago. There's no 2019 or 2020 models in the US and so far no inkling of a 2021 model.
ineedyourdiddly
Old 05-09-2020, 07:14 PM   #269
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It probably got canned when I lighter and cheaper Civic Type R bested the RS, proving AWD just isn't always better, especially on the street.
That, and the dealer markups destroyed sales.
Old 05-09-2020, 07:18 PM   #270
JD001
JD001's Avatar
Drives: Subaru BRZ
We have tuning houses in the UK turning out RS's with circa 520bhp.. you can't do that with a front wheel drive..
The Following User Says Thank You to JD001 For This Useful Post:
why? (05-09-2020)
Old 05-09-2020, 09:04 PM   #271
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
300 bhp (at the crank), I agree, should be possible with some bolt ons and e85.
300 whp I'll bet against, that's almost what the wrc car puts out, someone will try and I bet it blows.
They can't make a profit overbuilding the engine compared to the wrc version. I guarantee it has cheaper pistons and rods and a less aggressive cam, I wouldn't be surprised if the wrc cars have intakes/exhausts sculpted by hand and checked on flow benches while the consumer products will make sacrifices for mass production.
Please show me the +20hp header without a tune, I must have missed that one.
There will be so few of these made that the aftermarket will be weak aside from stuff that can be easily brought over like coilovers due to shared tnga components.
the wrc version has a massive restrictor. They made it 3 mm bigger and it added 70 hp. Unrestricted it could put out stupid power.
The wrc version is hand built and I am sure they use every trick in the world to strengthen everything. It will not be anything near that. I mean compared to a normal street engine.
There is a lot they cannot change because of homologation rules, so that helps in a lot of different ways. You are also assuming the rating they are advertising now is what the car actually has at the crank. Who knows if that is true, but it seems most turbocharged cars understate their actual power.
Old 05-09-2020, 09:22 PM   #272
Irace86.2.0
Well you can. You just probably won't be getting much traction on the street, but then again, 520hp in most light weight cars will have a problem. I'm in the 300's, and I have problems in my 86, but yeah, AWD could be nice then,
https://www.motor1.com/news/129113/h...r-mile-record/
Good read:
https://jalopnik.com/how-to-be-fast-...lai-1795906825
The other thing was the K20C1 engine is pretty bad ass, but the RS engine was known for head gasket problems, among others, which probably hurt some sales.
https://www.enginebuildermag.com/201...-k20c1-engine/
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
JD001 (05-10-2020)
Old 05-09-2020, 09:50 PM   #273
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
We also have to understand the physics behind making power. Torque production is directly correlated to in-cylinder dynamic pressure. Meaning for a 3 cylinder to make the same torque as a 4 cylinder, the in-cylinder pressures are much much higher.
So what we really need to know before assuming there's a lot of power left on the table is whether is has forged internals, because the rods will be subjected to a lot of force.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 05-09-2020, 10:08 PM   #274
Irace86.2.0
Just fyi, that 3mm is a lot, but I get your point. When looking at laminar flow, the flow rate is proportional to the radius to the 4th power, meaning a 3mm change from 33mm to 36mm can be big. As it is, 36mm is a 9% improvement over 33mm, but with the ^4 there is a 42% increase in flow.
This makes more sense when we look at the area of the pipe, which without the laminar flow dynamics discussed above, we see 3mm results in a decent bump in the opening:
{[pi(36mm^2) - pi(33mm^2)] / pi(33mm^2)} x 100 = 19% increase
Old 05-09-2020, 10:19 PM   #275
Irace86.2.0
As I previously posted, it seems like they can change the internals, but they have to use the same materials and the same block and head. This means weight will increase with the reciprocating masses if they strengthen them unless the GR Yaris comes with forged piston and rods to begin with.
I kind of mentioned that before in post #265. Power is distributed over 3 cylinders and 3 rods than 4, which means the internals will likely be strengthened over the predecessor.
See above about my comments about the forged internals. I seems likely switching from a 4 cylinder to a 3 cylinder and based on the rules for materials.
Old 05-09-2020, 10:31 PM   #276
Goingnowherefast
Considering half of the US production based car time attack records are held by two FWD cars, I'd say this is demonstrably false. They are globally competitive and hold many global track records for production based cars as well.
James Houghton (K tuned Integra)
William Au-Yeung (Vibrant Civic)
Also the Civic Type R is already making way above 500 whp despite being out for 1/2 the time as the Focus RS...
The Following User Says Thank You to Goingnowherefast For This Useful Post:
Irace86.2.0 (05-09-2020)
Old 05-09-2020, 11:11 PM   #277
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I know someone who recently bought a Kia Sportage, I asked whether it was the AWD version, he didn't know resulting in call to the dealer.... People buy because they like the shape/size and the message it portrays..
People buy the Kia Sportage for the utility, low price, and ease of getting in and out. AWD is an afterthought.
Originally Posted by DarkSunrise View Post
They don't want hot hatches (RIP Speed 3, STI hatch, Fiesta ST, Focus ST/RS, dying Golf R). Hell they don't even want lightweight roadsters (RIP S2000, Sky/Solstice, dying ND Miata) or lightweight coupes (RIP RX-7, RX-8, dying Twins).
Speed 3 - FWD
STI hatch - heavy - ~3500 lbs
Fiesta ST - FWD
Focus ST - Somewhat heavy >3200lbs - horrible to drive
RS - Heavy >3400 lbs - brutal suspension
Golf R - somewhat heavy >3300lbs - expensive - not that fun.
S2000, Sky/Solstice, RX-7, ND Miata - only 2-seats
RX-8 - insanely unreliable, horrible fuel economy, burns oil
Also Type R - FWD
Twins - amazing in pretty much every way. 2nd gen coming. still have mine.
I like this hot yaris because it's a revival of the 323GTX.
Often the AWD unlimited cars beat the FWD unlimited by several seconds. Rarely the other way around, and seemingly always with a lesser AWD car. Being able to accelerate out of a corner actually matters.
I would love this Yaris and buy it in a second.
The Following User Says Thank You to EAGLE5 For This Useful Post:
why? (05-10-2020)
Old 05-09-2020, 11:46 PM   #278
Goingnowherefast
Yet, in the real world depending on the conditions, that is simply not always the case. People forget, FWD has the advantage of being the lightest drivetrain configuration with (usually) the least drivetrain loss. I shouldn't have to explain the importance of lightness in motorsports haha.
Some examples from the last two seasons:
GTA2019 @ Road Atlanta - Who won? James Houghton FWD (also a track record)
GTA2019 @ NJMP - Who won? James Houghton FWD (Literally beat the 2nd place unlimited (AWD) car by 5 seconds)
Gridlife 2019 @ Mid-Ohio - Who won? James Houghton FWD
Gridlife 2019 @ Road Atlanta - Willl Au-Yeung FWD
Gridlife 2018 @ Gingerman - Who won? Willl Au-Yeung FWD
Just a few examples with a crowded field including many globally competitive AWD cars with professional drivers. No doubt FWD has some obvious disadvantages too, but it's 2020 and the proof is in the pudding. FWD can be very quick, and depending on the track conditions and environment even record breaking.
x2
Irace86.2.0 (05-10-2020)
Old 05-10-2020, 02:28 AM   #279
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Speed 3 - FWD
Fiesta ST - FWD
Also Type R - FWD
You are making an example of a class being more important than individual cars.
Let's try rwd. Are you suggesting all rwd are equally fun to drive?
My father's Volvo was rwd; it was a classic example of a barge. It had no steering feel, slow off the line, rolled like a metric shitload of lard.
My slightly warm Pug 206, fwd, had beautiful lift off over-steer and was a joy to drive.
The Fiesta ST is very highly regarded despite it being fwd.
Fun > driven wheels.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Goingnowherefast (05-10-2020), Irace86.2.0 (05-10-2020)
Old 05-10-2020, 10:42 AM   #280
DarkSunrise
DarkSunrise's Avatar
Speed 3 - FWD
Fiesta ST - FWD
Also Type R - FWD
You want a sub-3000 lbs, 4-seat AWD turbo sub-compact hatch, I get it. I think it'd be a cool car too. But that's different from saying there's actually a market for that kind of car in the US. A lot of Americans seem to associate compact/sub-compact hatches with cheap cars. I don't think you'll find a lot of buyers willing to pay north of $30 grand for one.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
strat61caster (05-10-2020)
Toyota Yaris GR Sport revealed ahead of Paris debut gymratter Other Vehicles & General Automotive Discussions 8 09-16-2018 03:04 PM
Toyota Yaris WRC announced vh_supra26 Other Vehicles & General Automotive Discussions 55 08-12-2017 06:59 AM
My Review of 2011 Toyota Yaris (Loaner Car) danthedirt Other Vehicles & General Automotive Discussions 19 07-13-2012 03:42 PM
2012 Toyota Yaris Dark Other Vehicles & General Automotive Discussions 13 10-10-2010 12:57 PM
