Old 05-02-2018, 08:00 PM   #267
mrg666
pessimistic skeptic
mrg666's Avatar
some members in this thread remind me this
Old 05-02-2018, 08:16 PM   #268
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Originally Posted by NOHOME View Post
Went back and found the laundry list of stuff you bolted on the car. Impressive and expensive. However, what I do not see is the before and after data to show that you actually accomplished anything with all that expense. That is where most people dive into denial. I am sure that you have the data from before and after you bolted each part on but just forgot to post it.
As to envious, not so much. Betty Crocker cake from a mix is not my style no matter how much frosting and sparkles it has. I like stuff to be a bit more original and require some skills from the builder. Not saying you or your installer don't have mad skills, but all I see is a catalog of parts that go on with a wrench and a CC.
As to the denial bit? Tossing huge amounts of $$$ at any car project is pretty stupid when looked at objectively. More so when you don't have before and after data to show that it made a difference as is the case with the vast majority of people who bolt thousands of dollars of parts on their car based on fancy add copy. The stuff we buy from the best aftermarket suppliers would not qualify as more than prototypes from an OEM vendor; not near enough development and validation. The end result is not worth 50 cents on the dollar if you are lucky. There is nothing wrong with denial, it is what allows us to do the next dumb but fun car project that we dream up.
You expect everyone who modifies their car to quantify their results and post them online for some sort of social validation?
You're not impressed with his build, we get it. Lets see yours. Do you have one? Oh ok so you just sprinkle salt on others.. You miss the entire reason people tinker with their cars.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
The Following 4 Users Say Thank You to olsonpg For This Useful Post:
Deep Six (05-05-2018), humfrz (05-03-2018), Sapphireho (05-02-2018), weederr33 (05-03-2018)
Old 05-02-2018, 08:21 PM   #269
humfrz
Jordanwolf (05-02-2018), olsonpg (05-02-2018)
Old 05-02-2018, 08:30 PM   #270
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Well, now Sapphireho ....... don't overreact.
That ought to keep you busy right up to retirement .......
humfrz
Good idea, but @NOHOME IS right i didn't do most of the work myself, I had experienced specialty shops do the things I wasn't comfortable doing, or didn't have the facilities or experience. I should have bought that lift and transmission jack, and a computer, but I failed. I had the guy who does Ken Block's cars tune mine, but what a hack, not oem.
I just bolted things on with no thought. I feel so bad to waste a car, and my life.
I feel so stupid. I thought modifying cars was a good investment. i thought you always make money. I'm just now learning it isnt true. Darn.
Thanks @NOHOME FOR THE EDUCATION.
Old 05-02-2018, 08:48 PM   #271
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by mrg666 View Post
That is what a responsible citizen would do.
I never thought about it, now realizing, that car could kill someone
So true, and I should get credit for feeding the families of my prototype inferior parts.
mrg666 (05-02-2018)
Old 05-02-2018, 09:01 PM   #272
mrg666
pessimistic skeptic
mrg666's Avatar
Mine handles great. Here is what I did:
Suspension and Steering
TRD lowering springs
TRD sway bars
Yoshihara D5C 18x8 +40 rims w/Michelin Pilot Super Sport tires
Heavy Duty Steering Rack Bushings
STI Upgraded Steering Rack Bolts
Anti-Lift/Caster Bushing Kit
Front Control Arm Rear Bushings
Rear Trailing Arm Bushings
Front Toe Arm Bushings
Inner Lower Rear Control Arm Bushings
roll center adjuster set
Engine & Drivetrain
Jackson Racing Supercharger
Jackson Racing Oil Cooler
Jackson Racing Aluminum Neck Filler/Radiator Cap
DW 700CC injectors
DW 300c Fuel Pump
Delicious Tuning Flex Fuel MK1+ Kit
Custom Tune by William Knose of Delicious Tuning
TRD exhaust
South Bend Stage 2 Daily clutch
Velox Billet Shift Fork and Pivot
TRD Japan short shifter
DSS Carbon Fiber Driveshaft
Rear Sub frame Insert bushings
Rear Differential Inserts
Transmission Bushing Insert
Brakes
DBA 4000 drilled and slotted rotors
DS2500 Ferodo brake pads
Perrin master cylinder brace
Mann Engineering Stainless Steel Brake Lines
That is a ruin, right there!
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
Harey (05-08-2018), olsonpg (05-02-2018)
Old 05-02-2018, 09:08 PM   #273
Sapphireho
Famous Potatoes
Sapphireho's Avatar
RIP
Old 05-02-2018, 09:24 PM   #274
DefMunkie
Drives: 2017 86
TRD sway bars
Engine & Drivetrain
DW 700CC injectors
DW 300c Fuel Pump
TRD exhaust
Brakes
I'm going to add this mod combo to my possible upgrade list combo bucket.....so that I can ruin my car. Thanks for contributing the destruction of Toyobaru's dream.
DefMunkie is offline   Reply With Quote
Old 05-02-2018, 09:26 PM   #275
mrg666
pessimistic skeptic
mrg666's Avatar
RIP
Joke aside, that is an impressive list of mods. Enjoy!
Old 05-02-2018, 09:37 PM   #276
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
Circle jerk, - For the car's intended purpose in the marketplace it certainly has been ruined.
You have added performance, but you have probably increased the maintenance, possibly shortened the life of the engine. Increased the risk of warranty claims. Made the car harder to maintain from a dealership's standpoint. Added weight and complexity, made the ride rougher than the market may accept. And the big one.............added $8-12K.
Did you ruin the car? no, but you ruined the marketability from Toyota's & Subaru's standpoint of a vehicle that already has questionable marketability.
SCQTT is offline   Reply With Quote
The Following User Says Thank You to SCQTT For This Useful Post:
JohnJuan (05-03-2018)
Old 05-02-2018, 11:09 PM   #277
humfrz
Originally Posted by SCQTT View Post
Circle jerk, - For the car's intended purpose in the marketplace it certainly has been ruined............
Yep, we've been "ruining" cars for years ..... I'm surprised they still make em .......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Harey (05-08-2018), mrg666 (05-03-2018), Tcoat (05-03-2018)
Old 05-02-2018, 11:13 PM   #278
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Man, the stupidity on this board is reaching all time highs.
I need to go away and get some brain cells back.
SCQTT (05-02-2018)
Old 05-02-2018, 11:44 PM   #279
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
You're right. Some people get in a big hurry to go $40K deep in a car that is worth $20K. Its a fun hobby though.
Old 05-03-2018, 12:12 AM   #280
revaholic
Drives: 2016 Ablaze Scion FR-S
On my Sprintex Intercooled kit, I'm probably making about 230hp but more importantly about 200lb/ft of torque. It's not that much more power and everything else is stock in my car. But the car is just so much livelier at speed, and I can get it to drift a little easier but when the tail gets loose it is just as controllable as stock. I really like it and so when Toyota's position is that any more power would make the car less balanced, I just don't agree. It just needs a bit more power.
revaholic is offline   Reply With Quote
The Following 2 Users Say Thank You to revaholic For This Useful Post:
Harey (05-08-2018), SCQTT (05-03-2018)
CNET on 86: More power would ruin it Guru Woodman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 03-04-2017 05:19 PM
I don't want to ruin my dream car. TruthfulDeception Engine, Exhaust, Transmission 28 03-23-2016 10:40 PM
Wheels that won't ruin the ride Rudiger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-21-2012 03:40 AM
Will FI Ruin the Balance of FRS/BRZ? ZmZMWagon Other Vehicles & General Automotive Discussions 8 04-12-2012 11:19 PM
Why govt ruin everything 1660 Off-Topic Lounge [WARNING: NO POLITICS] 11 12-27-2009 03:52 PM
