#15 |
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
For NA i recommend 4.72 or 4.88 , personally prefer 4.88 from weir
#16 | |
Drives: '15 BRZ RA
You will have actually less acceleration when you hit 100mph in 5th gear. Reason is that 5th gear is 17% slower comparing to 4th gear. You gain a bit with the shorter drive ratio, but not so much. Overall, you lose in this range of speed. This is the common thing that most people don't get it. With a shorter drive ratio (e.g. 4.56, 4.88 etc.) you are actually slower in the higher range of speeds and faster in the lower range of speeds. There isn't such a magic that will give you the "missing" engine power. By changing the drive ratios, you are just shifting your available power band in another area. |
#17 | |
Drives: Gt86
The OPs car is his DD so I doubt he will be hitting 100 mph on a regular basis. When selecting 5th you are well into the power band and the acceleration does not feel as though it looses momentum. It may do on a stop watch but in real life it doesn't. |
#18 | |
Drives: 2013 FR-S Argento
| The Following 3 Users Say Thank You to bfrank1972 For This Useful Post: |
#19 |
Drives: '15 BRZ RA
#20 |
Drives: Gt86
#21 | |
Drives: 2014 BRZ Limited
I hit 100mph pretty regularly on some of the roads to/from my work because there are no homes, no residents, and nothing around to harm from speeding. So the tldr; is that 5th will be slower than stock but 1-4 will likely be quicker?
'14 BRZ Limited | SBD500X + HRI Tuning | Tanabe Concept G Exhaust | XXR 527 18x8.75 | Hankook Ventus V12 EVO2 245/40/18
#22 | |
Drives: Gt86
Final Drive: 4.56 vs. 4.88
No way 5th is slower. I did a test run before exhaust and FD fit (otherwise stock) 2nd @30mph then through the gears to 90mph. Totally stock 13sec FD and exhaust 11sec No ecu tune. I think that answers your question. |
| The Following User Says Thank You to Foulsmell For This Useful Post: | kingkenny (12-14-2015) |
#23 |
Increasing fd ratio by 10% make you feel it response 10% better but overal acceleration from zero to 130miles will not increase over 5%
#24 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I realize that sometimes our cars feel kinda lazy to move around 2800 rpms and the engine feels kind of breathless(torqueless). How does the 4.67 combat that?
#25 | |
Drives: Gt86
Basically by multiplying the torque that the engine puts out. The breathless feeling has gone from my car now. I thought the same as you. I notice the difference more in 3rd and 4th gear where it just keeps pulling. No matter what gear I'm in I always feel like there is enough power to pull away. I liken it more to my friends 350z now but with a few more revs. |
#26 | |
86 Member
#27 |
Drives: 2013 black AT, OFT, 4.65
As a owner of a auto tranny with a 4.67, and a former owner of a manual. The biggest mistake Subaru and Toyota did was not to put the right gear ratio in this car. With the 4.67, this car rocks!! With the manual I could only wish to get to 135. But in the auto with gears, I can touch 135 with easy, offen. And the way it goes though the gears is just fantastic. This should be the first mod to the car.
Living the dream in a nightmare.
| The Following User Says Thank You to skye67 For This Useful Post: | Foulsmell (12-13-2015) |
#28 |
Drives: '15 BRZ RA
Your statement doesn't make sense. Auto tranny has bigger power losses and a much smaller top speed (130 mph vs. 140 mph of the manual tranny). You cannot get an improvement on top speed by changing the final drive to a shorter ratio. This is a well know fact valid for ages. Did you buy the car second hand? Your car should also have some other mods.
| 4.8 final drive | drift86 | Engine, Exhaust, Transmission | 29 | 11-28-2022 12:49 PM |
| WTB: 4.56 Final Drive | jaorocks1 | Want-To-Buy Requests | 0 | 11-04-2015 07:36 PM |
| 3.7 Final Drive | GsxrMe | Engine, Exhaust, Transmission | 9 | 09-28-2015 07:55 AM |
| Final Drive 4.67 | Bongertz | Engine, Exhaust, Transmission | 33 | 09-02-2015 03:11 PM |
| 3.3 Final drive? | Manji | Engine, Exhaust, Transmission | 18 | 01-01-2015 02:51 PM |
