#15 |
Benched 86lb
Drives: Ultramarine FR-S
My car definitely does this, and has since new. It rolls a good inch or two, and I mean actually _rolls_. It is not related to suspension.
I've always just chalked it up to the design of the parking brake. It's also extremely grabby compared to other vehicles I've driven. |
#16 | |
![]() Which is OK. humfrz |
#17 |
Drives: 2013 Subaru BRZ MT Limited
This issue is normal operation, it has to do with the design of the parking brake on most Subaru's. The Parking/E-Brake on most Subaru's are a "Drum In Disc" type design where there is a smaller drum brake inside the hub of your rear Disc brakes.
If you have ever worked on "Self-Adjusting Drum Brakes" then you know that the entire Mechanism inside the brakes floats around a bit as a function of the self adjustment part of the brakes. This is what causes the movement when you let off the floor pedal, because you are switching from the disc brake portion of the brakes to the drum brake portion and the drum brake portion of the brakes floats a little bit inside the drum as part of the self-adjustment function of the drum brakes. Here is a useful animation on how drum brake adjusters work. http://auto.howstuffworks.com/auto-p...rum-brake2.htm
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#18 |
Drives: '15 Subaru BRZ
Thanks for the replies very helpful, I had to replace a few bits on that side and never noticed the movement until after I had done so.
I also had a squeak at the time of posting when driving which I thought was related to this but I have since got rid of that and can see it is normal and handbrake functions just fine. Jordan |
| Emergency brake button?? | Borzy | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-13-2015 08:18 PM |
| WTB: BRZ handbrake cover and handbrake boot w/ red stitching | 86tylerfrs | Want-To-Buy Requests | 4 | 01-20-2015 04:11 PM |
| Emergency brake adjustment? | F3dzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-26-2013 10:59 AM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 11:43 AM |
