#15 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I guess a bolt on is easy stuff, where as suspension may be a gray area (not hard but a bigger project than a header or intake), engine internal mods are not bolt ons.
#16 |
Drives: BRZ - 2013 MT
Anyone able to help me out here..... i know its probably a stupid question.
If I plan on going Turbo down the line but want to install headers before then are there specific headers that are set up for the turbo install or will you need a new/go back to OEM header when I install the turbo? I know some turbo kits do not come with headers and just install on OEM parts, but if i have an aftermarket header already will the turbo still install fine? |
#17 |
Boost Creep
Drives: 2016 HyperBlue BRZ
I don't think any of the turbo setups work with any NA headers, aftermarket or stock. It would require some serious piping creativity. One way or another you're always replacing a minimum of one exhaust component. Otherwise where does the turbo go?
#18 |
Ptuning's kit "utilizes the factory catted header as standard" quoted from their link on the turbo kit. Wondering if that means aftermarket headers would work as well, I'm currently deciding between jdl and tomei
Sent from my SM-G925I using Tapatalk |
#19 |
SCBYD0
Drives: 18 BRZ (WRB)
Yes PTuning's kit will allow you to use any header including stock. WORKS is another one as both kits route after the header so you can pretty much use any NA model you want. But that's about it for active kits, any others will come with their own.
#20 |
Perfect, thank you. Now I need to figure out how to get the parts all the way to NZ
![]() Sent from my SM-G925I using Tapatalk |
#21 |
Headers that very unlikely to work with p tuning or works kits would be Nameless PLM or ACE header
| Tags |
| brz, exhaust, headers, tune, uel |
| WTT: Tomei uel headers for EL headers | 86Tony | Canada Classifieds | 6 | 07-27-2015 09:42 PM |
| What headers to buy? | Squido3J | Engine, Exhaust, Transmission | 34 | 03-05-2014 09:05 AM |
| Injen SES Headers/ Agency Power headers | Choong86 | Engine, Exhaust, Transmission | 10 | 12-27-2013 09:51 PM |
| will i need headers for this | Anthony | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 08-01-2013 08:08 AM |
| Uel vs el which headers do you have and why? | Mike86 | Engine, Exhaust, Transmission | 38 | 05-16-2013 02:50 AM |
