#15 |
The more I have been driving it, the better it has gotten. Not sure if getting used to it, or it is being "broken in" more.
| The Following User Says Thank You to mcrane For This Useful Post: | Chrisgalactic (12-09-2015) |
#16 |
Drives: WRB Limited BRZ
Lol I did change my fluids to Motul, but other than that first and 2nd have been pretty damn clunky especially 2nd gear
#17 |
Drives: 2016 Halo FRS
Slap a hello kitty band aid on the transmission
works wonders |
| The Following 2 Users Say Thank You to Trust86 For This Useful Post: | Chrisgalactic (12-10-2015), dvasqu01 (12-09-2015) |
#18 | |
Drives: Scion FRS Whiteout
Wtf!!💁🏼 I'll give you the rice noodle😘 |
#19 | |
"The infinite monkey theorem, which states that a monkey hitting keys at random on a typewriter keyboard for an infinite amount of time will almost surely type a given text, such as the complete works of William Shakespeare." ![]() humfrz |
#20 | |
not playing cards
#21 |
Drives: Subaru BRZ Limited
#22 |
not playing cards
#23 | |
edit: I guess I had seen that thread but not tcoat's post... |
| The Following User Says Thank You to JoeC For This Useful Post: | Ultramaroon (12-10-2015) |
#24 | |
shifting from 1st to 2nd: accelerate in 1st up to 4k RPM clutch in pull down to neutral clutch out let revs fall clutch in pull into 2nd it went into 2nd just fine. admittedly it doesn't like to downshift into 1st without rev matching but when I match it goes right in. maybe I'm just lucky |
#25 | |
not playing cards
For the record, I have zero complaints about this transmission, so far. I just instinctively play around to see what technique gets me through the gears using the lightest touch possible. That knowledge, IMO, applies just as well to the more "spirited" driving. That second part was just extra opinion for whomever. You double-clutch into a rolling first so we're pretty much on the same page.
#26 |
Drives: White out Scion Frs
That "pause" works wonders never try'd it before and holy shit does it make a difference! Thanks a lot Ultramaroon
Sent from my SAMSUNG-SM-G900AZ using Tapatalk |
#27 |
Persona Non Grata
Drives: '15 BRZ (WRB)
I have fewer than 2000 miles on my Subarota. In that time, though, I've noticed it shares some transmission quirks with my '06 F150 DD. The most notable is, it does NOT like to be forced into a shift. If I'm sitting at a light with the truck in neutral and the light turns green, a quick stab on the clutch pedal and a shove of the shifter into first will yield exactly nothing. It will simply NOT shift into first. On the other hand, a gentle push of the lever leaving time for the various parts to do what they are supposed to do results in a smooth engagement of the gear.
My particular BRZ is very similar. It responds very well to a gentle, but firm, hand on the shifter. Give it a little time. Sometimes the fastest way to get something done is to slow down a little.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | Chrisgalactic (12-15-2015) |
#28 |
not playing cards
I can see how it's easy for the casual reader to misunderstand my reply to JoeC. I am not advocating for pausing between first and second. I was explaining how to create the condition that causes people to have trouble shifting into second when it's cold.
Different techniques yield different results because physics.
| First and Second gears are clunky... | mcrane | Engine, Exhaust, Transmission | 0 | 12-05-2015 12:39 PM |
| Shifter feels clunky when going into 5th | Jfheisenberg | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 04-04-2015 08:41 PM |
| Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 01:48 AM |
| Rear rattle/clunky noise | Hawk77FT | Issues | Warranty | Recalls / TSB | 8 | 08-18-2013 07:59 PM |
