#15 | |
Drives: 2012 FR-S
Shift points are pretty good and still can drive on highway. Car is on 17" wheels with 235/40 tires. Start video at 2:15ish and check tach. Only hit 5th gear on straight and speed is approx 200kmh [ame="https://www.youtube.com/watch?v=zHM51jTFXu0"]3 22 '15 OTGP Time Attack Final - YouTube[/ame] |
| The Following 5 Users Say Thank You to AceHeader-MT For This Useful Post: | FRSBRZGT86FAN (05-10-2016), KoolBRZ (11-23-2015), makesdrivingfunagain (05-28-2016), SUB-FT86 (11-23-2015), Toyota86.ir (11-23-2015) |
#16 |
Drives: 2013 Asphalt FRS
Ok heres a quick run down on auto trans gearing. Its not like a manual where you have to gears running together to make a ratio, To change a autos gears you would need different clutch hubs, pinions, and sun gears. What is turning when you are in any certain gear is that gears clutch pack that has the "gearing" machined into the pack. basically everything would have to be machined new. Now this isn't a brz/frs trans but it will give you a idea of what Im talking about.
Go with a final drive gear 4.88 to 5.29 and you will be happy just remember the bigger the number the less top end so if you a light to light guy go 5.29 or 5.71 if you like running 140mph or more go 4.88 to 4.56. A little goes a long way in gearing. Call Mark at Spencer Fab in New Hampshire he can answer all your questions and set you up too. If your on the west coast call Weir Performance. I have done business with both and will say they are both stand up guys.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following 5 Users Say Thank You to FRS Justin For This Useful Post: | AceHeader-MT (11-23-2015), avishenoy1 (11-23-2015), Freeman (11-23-2015), KoolBRZ (11-23-2015), Toyota86.ir (11-23-2015) |
#17 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
The automatics have a theoretical top speed of over 200 mph that is almost impossible to reach so a 4.88 or 5.29 fd drops it to about 160-170 mph which most of us will never reach anyways. This is all thanks to the 2 overdrives in the 6AT.
| The Following User Says Thank You to SUB-FT86 For This Useful Post: | Toyota86.ir (11-23-2015) |
#18 | |
I had no idea an AT could be that fast
If I say yes, will that make you think I understand?
| The Following User Says Thank You to KoolBRZ For This Useful Post: | AceHeader-MT (11-23-2015) |
#19 |
86 Member
I want to do something similar with mines like in that video above. And that video made me realize it's a good thing to get a 5.something FD plus e85.
| The Following 2 Users Say Thank You to SUB-FT86 For This Useful Post: | AceHeader-MT (11-23-2015), Toyota86.ir (11-24-2015) |
#20 | |
Drives: 2012 FR-S
With a good gear ratio, good brakes (Essex) and good suspension (Racer-X) you never feel like you're on the limit. The 5.1 change was one of the most substantial differences...besides Delicious and their E85 tune/kit. |
| The Following User Says Thank You to AceHeader-MT For This Useful Post: | Toyota86.ir (11-24-2015) |
#21 | ||||
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
gear 5 and gear 6 in AT are so tall and the acceleration drop in gear 5. Quote:
i have 4.88 and i ordered it to Weir , robert at weir is responsive and nice. we installed it after working above 18 hours and there is no noise . Quote:
guys let me time i will publish an Excel file for acceleration comparison of various FD on brz. |
| The Following User Says Thank You to Toyota86.ir For This Useful Post: | FRS Justin (11-24-2015) |
#22 | |
86 Member
#24 |
86 Member
If you put a 5.29 fd in a auto you will be almost at the same revs/mph in all gears as a 4.1 6MT while having a much more torquey 1-4 gear and delivering the same mpg as a 6MT.
http://www.grimmjeeper.com/gears.html Last edited by SUB-FT86; 11-25-2015 at 11:41 AM. |
#25 |
My Summury about FD swap with AT and MT Transmission :
most street drag is between 20-110 miles and the best choice for AT is 4.88-5.29 and best choice for MT is 4.77-4.88 my choice for AT is 4.88 and for MT is 4.72 please see below, each cell number shows the percent of time reduction. for example the AT 4.88 number in table is 5.2 at 170km/s. number 5.2 means if AT 4.1 reach 170km/s in 17 seconds then AT 4.88 reach 170km/h in 16.11 seconds. 16.11 is 5.2% lower than 17 seconds. ![]() see other numbers in this excel : http://toyota86.ir/wp-content/upload...1/FD-GR-T.xlsx this is another useful excel i downloaded from this forum and uploaded again because google link was not available: http://toyota86.ir/wp-content/upload...86-Ratios.xlsx |
| The Following User Says Thank You to Toyota86.ir For This Useful Post: | SUB-FT86 (12-12-2015) |
#26 |
Yes most definitely.. For my type of driving anyway....
#27 | |
In drag racing you want to run max rpm at the end of the 1/4 in 1:1 which is 5th gear. A 5.29 will not get you there unless you run a smaller tire. A drag only no street driving car would want a 5.71 ratio in 5th gear or a 4.56 max rpm in 4th gear. SO choose tire size then get the gearing
| The Following User Says Thank You to FRS Justin For This Useful Post: | Toyota86.ir (12-01-2015) |
#28 |
86 Member
[ame="https://www.youtube.com/watch?v=XuXT5n-ds4A"]0-60 mph BRZ - YouTube[/ame]
I'm so in love with this guy's 6AT acceleration! It goes to show that 4.88 FD/Header/E85 and tune is perfect for me. I prefer a car that feels fast and revs quick vs just wanting a really fast car. |
| The Following 2 Users Say Thank You to SUB-FT86 For This Useful Post: | new2subaru (12-01-2015), Toyota86.ir (12-01-2015) |
| Change gear ratio? | Afdad120108 | Engine, Exhaust, Transmission | 61 | 08-17-2016 11:44 AM |
| 4.556 final drive with TRD gear ratio change - good or bad idea? | nzer | Engine, Exhaust, Transmission | 51 | 12-26-2015 10:15 PM |
| Gear Ratio Change | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 06-26-2014 11:20 PM |
| Change FD ratio to 4.56 by changing only pinion | peachch | Engine, Exhaust, Transmission | 1 | 08-31-2013 02:25 PM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 03:40 AM |
