#15 | |
Drives: GTS 86
The new clutch came with a new TOB. Also, they have put everything they have changed in a package to look at. The plate was on its way out. All bearing and stuff been changed with brand spanking new ones. |
#16 | |
![]() That would require major surgery. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Hawk77FT (11-12-2015) |
#17 |
Drives: GTS 86
#18 |
Drives: 2013 ScionFRS
#19 | |
If you push the clutch in ..... the engine is disconnected from the transmission, thus the input shaft would quit turning, thus a bad bearing wouldn't make any noise. Unless, I've got it backwards ...... ![]() humfrz |
#20 |
Waited 5 years for this
Drives: '18 MX-5 Club
I have this noise too. I thought it's normal. I got the throw-out bearing replaced for another reason, and that didn't get rid of this noise.
http://www.ft86club.com/forums/showthread.php?t=28296 |
#21 | |
Drives: GTS 86
#22 |
Drives: Whiteout FRS
Did you change your manual transmission fluid to motul?
#24 |
Drives: GTS 86
#25 |
| The Following User Says Thank You to shellslinger For This Useful Post: | MisterSheep (11-16-2015) |
#26 |
Drives: GTS 86
#27 |
not playing cards
Late to the party. There is always some backlash clatter in the gearbox at low rpm, especially for the light flywheel crowd.
I have heard a couple recordings of what sounds like an actual knock as the gearsets rotate in neutral. I don't know what that is but if it wasn't there before and is there now, something in the gearbox changed. Can you post up a clip?
#28 |
No, I thought this is a normal noise, so I haven't taken it to the dealer. I'm pretty sure it was making this noise since it was brand new. It just got louder after the transmission fluid was changed, but it happens to other people too. So, I'm thinking it's normal and something I don't need to worry about.
| Valvetrain chatter on KW SC FRS | nlowell | Issues | Warranty | Recalls / TSB | 4 | 05-03-2015 11:20 AM |
| Flywheel Chatter | samisons | Issues | Warranty | Recalls / TSB | 13 | 12-05-2014 09:30 AM |
| Drivetrain chatter on cold mornings? | jm1681 | Issues | Warranty | Recalls / TSB | 7 | 10-24-2014 10:48 AM |
| Diff chatter when cold? | BRZrkr | BRZ First-Gen (2012+) — General Topics | 1 | 06-23-2014 09:17 AM |
| Odd Chatter Noise? | Chrisposey | Forced Induction | 5 | 05-05-2014 09:37 PM |
