Old 11-09-2015, 02:09 PM   #15
Who8myrice
Drives: Ap2
My 15 had dip before I flashed it.
I also seen 16s doing rpm dip brand new.
Who8myrice is offline   Reply With Quote
Old 11-09-2015, 02:20 PM   #16
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
My 2015 dips too But it's only once in a while. Glad OP got everything sorted out. That would have been a problem if op went FI without the fixes.
Old 11-09-2015, 03:16 PM   #17
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by mscamp02 View Post
Ended up just being the ECU reflash as my car was made after the manufacture # listed on the TSB for the shim and now the car is running perfect. To bad I'll only be on this flash for a few more days but it was definitely better to be safe then sorry.
Thanks for all the advice.
FYI all ROMs which tuners send out are going to be based on the latest ECU revisions. If using Ecutek, as long as your tuner keeps their software up to date, all base files are fully updated and a tune would've fixed the idle dip for you.
I had the same idle dip issue on my '13, and the problem went away immediately after flashing a base Ecutek rom for B01C.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Idle dip yomny Software Tuning 38 06-14-2016 05:54 PM
K&N idle dip Dominus Engine, Exhaust, Transmission 7 01-28-2015 10:17 PM
Low idle? MadeInSweden Issues | Warranty | Recalls / TSB 2 12-09-2014 03:15 AM
AFR @ Idle woode Forced Induction 12 01-19-2014 08:38 PM
Odd idle jbixel Issues | Warranty | Recalls / TSB 2 11-02-2013 08:35 AM
