Old 11-01-2015, 03:17 PM   #15
streety
streety's Avatar
Drives: TOYOTA GT86
Update: Today I've compared the play on my calipers and calipers on my friend's Toyota GT86 which has no rattle issues. There was a certain play as shown on video above on both cars. Nevertheless I noticed a little difference in effort necessary for moving the caliper and noise level, calipers on my car was moving slightly more freely and the sound was louder.
Just FYI, here are the parts which I've already replaced without any positive effect.
streety is offline   Reply With Quote
Old 11-02-2015, 01:49 AM   #16
GT86_PRAGUE
Drives: GT86
There may be a difference - did you heat them enough on track?
GT86_PRAGUE is offline   Reply With Quote
Old 11-02-2015, 05:53 AM   #17
streety
streety's Avatar
Drives: TOYOTA GT86
No on track, but pretty hard use on country road. (Conditions where stock brakes fades after several minutes)
Old 11-02-2015, 05:14 PM   #18
streety
streety's Avatar
Drives: TOYOTA GT86
So guys, I have some update. There are different part numbers for caliper bodies between models "from 2012/03" and "from 2015/04". Same for the slide pins.
I'll do some further investigation.
2012 Caliper body RH: SU003-04085
2012 Caliper body LH: SU003-04086
2015 Caliper body RH: SU003-06070
2015 Caliper body LH: SU003-06071
2012 Slide pin no. 1: SU003-00626
2012 Slide pin no. 2: SU003-00574
2015 Slide pin no. 1: SU003-05830
2015 Slide pin no. 2: SU003-05829
Other components are identical. It seems Toyota migh be aware of some problem.
The Following User Says Thank You to streety For This Useful Post:
HRTROB (11-03-2015)
Old 12-04-2015, 01:19 AM   #19
Speedy000
Drives: Raven FR-S
i almost tore half my car apart looking for this darn noise last weekend. glad im not crazy.
Nikon Squad D800
www.flickr.com/speedy000
Speedy000 is offline   Reply With Quote
Old 12-04-2015, 02:35 AM   #20
streety
streety's Avatar
Drives: TOYOTA GT86
Okay, it seems my mechanic figured out at least temporary solution. (I'm not sure how long it gonna last, I've driven my car just around 100km).
It's very easy, just pull out your slide pins, put a lot of grease which is suitable for this use on slide pins, put them back and tighten them. Then the play in the calipers should disappear, if not, just do in once again.
Worked for me, with almost no cost!
Some video found on internet for reference: [ame]http://www.youtube.com/watch?v=8IxJFoZxKaE&sns=em[/ame]
GT86_PRAGUE (12-04-2015)
Old 02-20-2016, 05:19 AM   #21
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Update: brought my car to the dealer last December 10 to have my side mirror replaced under warranty (power fold was no longer working on one side). While in the shop they also performed standard 10,000km maintenance which included cleaning of the brakes. They removed the wheels, cleaned the pads and calipers and re-greased the shims and slide pins. Lo and behold, the noise went away. A month later I had the brake fluid flushed and bled. Still no noise. But yesterday, the rattling noise came back. Cleaning and greasing the shims and pins only lasted for two months/600km.
HRTROB is offline   Reply With Quote
Old 02-21-2016, 02:11 PM   #22
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Time for a big brake kit Rob!
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
GT86_PRAGUE (03-08-2016)
Old 03-07-2016, 07:54 PM   #23
streety
streety's Avatar
Drives: TOYOTA GT86
HRTROB: Maybe you can try another kind of grease and fill it really well. I've drove my car at least 1k km (incl. really hard breaking) and still no rattling. Keep trying!
Old 04-03-2017, 10:30 PM   #24
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
mine is driving me crazy
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 08-18-2017, 09:42 PM   #25
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I got rid of the rattle by going back to the stock pads. The stock pads have an anti-rattle spring that rests on the caliper bracket, pushing itself out against the caliper to prevent the rattles. Only problem is, the stock pads suck
Old 05-30-2021, 07:53 AM   #26
Zamor86
Drives: 2013 Toyota GT 86 M/T
Hey Rob!
Do you still have your car? I've just realised I'm experiencing the exact same issue with my Ferodo DS Performance pads + stock calipers.
Did you find any brake pads other than the stock ones that had this rattle-eliminating spring? In other words: Is there a way to have sportier pads and no rattle?
Greetings from Poland
Zamor86 is offline   Reply With Quote
Old 05-30-2021, 03:25 PM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
Zamor86: have you put in from stock pads those two tin inserts (anti rattle springs pointed out in post above yours) that go over "ears" of pads? IIRC Ferodo pads come without them, and obviously stock ones should be reused with them. Also have you relubed guides and those ears of pads?
Old 05-31-2021, 12:50 PM   #28
Thefalls
Thefalls's Avatar
Drives: Corolla GT
I have used TRD blue pads the don't come with the Anti rattle springs and yet didn't have the rattle. The calliper piston puts a bit of pressure on the pads so that they are resting tightly against the brake disc.
Its not like it is loosely fitted.
There are metal shims (upper and lower) in the calliper carrier where the brake pads fit (tightly).
Do you still have them in place?
With the calliper out and both brake pads fitted in the calliper carrier, try to see if there is any play.
Thefalls is offline   Reply With Quote
DIY Brake Caliper Painting post_break DIY (Do-It-Yourself) Guides 18 07-20-2018 12:54 PM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 07:14 PM
F1 brake testing. Brake caliper porn! Captain Snooze Other Vehicles & General Automotive Discussions 11 10-16-2015 12:55 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
