#15 | |
disconnect hids and see if problem goes away. |
#16 | |
#17 |
Drives: '13 Firestorm FR-S
Ill have to give that a try then ill post the results
Club: Made Unequal (Natl. V.P.)
IG: novaft86 |
| The Following User Says Thank You to Novaft86 For This Useful Post: | Tcoat (10-14-2015) |
#18 |
Put the old lights back in and see if the light comes on. If not it's the HIDs...somehow
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#19 |
Drives: 2015 CWP BRZ Limited
It's not that mysterious. A ton of the accessories are wired via CANBUS, and a ton of the accessories are wired through the BCU. Electrical noise, differences in power consumption, differences in resistances, or shorts can do a number on these systems.
#20 |
The Fail Boat
Drives: CWP S.B.
lesson of the day : get cheap stuff but not too cheap. :P
#21 |
Lessons learned indeed
IG: novaft86 |
#22 |
Can you take photos of the ballasts and such so we can see its specs?? I recommend getting a CANBUS HID kit from diode dynamics they have quality parts that are worth the $150, if my OLMs ever have an issue that's what I'll go to
#23 |
Well after some time i think i finally figured what it was. And im pretty sure it only happens when it gets below a certain temperature outside more than likely causing a resistor pin to shrink somewhat and not be in full contact
IG: novaft86 |
#24 | |
Good fix
#25 |
Ask George Costanza about shrinkage.............
| BRZ seats installed into FRS... Airbag Light | Wpomp | Cosmetic Modification (Interior/Exterior/Lighting) | 39 | 03-27-2021 03:07 PM |
| Airbag Light | adamg | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 02-27-2015 11:21 AM |
| Airbag light on after mod install | SurfAndSand | Engine, Exhaust, Transmission | 1 | 10-23-2013 10:50 AM |
| Airbag Light Delete | Juurian | Electronics | Audio | NAV | Infotainment | 0 | 06-20-2013 08:37 PM |
| Airbag light | norcal_brz | Issues | Warranty | Recalls / TSB | 6 | 03-27-2013 02:59 PM |
