Old 10-03-2015, 04:35 AM   #15
strat61caster
strat61caster's Avatar
Originally Posted by ryoma View Post
btw, the -22.2 was most likely a typo. his camber is most likely -2.22. I have -1.5 already in the rear and I haven't done anything suspension-wise.
Not a typo, this is his car:
ineedyourdiddly
Old 10-03-2015, 10:53 AM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by HachiRo View Post
Can install be done by myself? I heard there's a bushing or something that's really hard to work around, or something lol I forgot.
The bolts are not bushings, its just a bolt. Remove OEM bolt, install eccentric bolt, turn bolt to achieve desired camber. But that said, given the questions you're asking, I'd say just let your alignment tech put them in. It'll only take a couple of extra minutes.
This thread is like saying "I want to get an 80 inch TV, what kind of house do I need to put it in?" And that's fine, there's nothing wrong with your goal, you just need to change your approach. If you're looking to run 10.5 inch wide wheels you're likely going to have to focus everything on that alone. Figure out the size and offset of your wheels, buy them, and then start building around them. You very well might end up at 4 degrees of camber to make it work, or a completely different spring and damper package to make room.
The Following User Says Thank You to Calum For This Useful Post:
Cole (10-03-2015)
Old 10-11-2015, 08:10 AM   #17
BasementN3k0
The Angry Brown Guy
BasementN3k0's Avatar
Drives: 2016 Tacoma & 2018 86 GT Black
that just gave me whitaker eye...
BasementN3k0 is offline   Reply With Quote
The Following User Says Thank You to BasementN3k0 For This Useful Post:
D_Thissen (10-12-2015)
RSR Superdown owners HachiRo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-04-2015 06:44 PM
WTB RSR Superdown BokChoiTV Want-To-Buy Requests 5 03-25-2015 01:46 PM
WTB: RS*R Superdown and Whiteline or SPC camber bolts sissupr Want-To-Buy Requests 0 03-15-2015 05:14 PM
wtb NEW Sportlines or barely used sportlines VakaGT Want-To-Buy Requests 1 08-19-2014 08:02 PM
AP Rear LCAs JDLAutoDesign Brakes, Suspension, Chassis 2 04-17-2014 03:43 PM
