| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#15 | |
If you don't have any rubbing alcohol, you might try vodka or gin. NOT the cheap stuff, you serve your guests after they are half drunk..... ![]() If that fails, consider ...... carefully and quickly, trying a very small spot, on the underside, with a small toothbrush ..... acetone..... ![]() (disclaimer - humfrz is not responsible for any uses of acetone, outside the chemistry lab ........ )humfrz OK, if none of that works, I'd go with theory "B" ...... the marks are caused by rock chips stressing (thus turning white) bits of the plastic. If that is the case ....... "paint" the bumper with .... sorry, got to go ....it's my nap time ....ZZZZZZ |
#16 | |
Drives: 2015 BRZ Series Blue WRB
#17 | |
Drives: Yes
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#18 |
Drives: '13 10 Series FRS #1203
It's wax...
Wax and black plastics/seals don't mix. Use peanut butter to get it out.. No I'm not joking; take some peanut butter and rub it into the plastic firmly, take some dish soap and a rag and wipe clean. DO NOT ACETONE YOUR BUMPER |
#19 |
Drives: 2013 Firestorm FR-S AT
I worked as a research chemist before I retired. Yeah, I'm an old f**k.
You want to try an aliphatic solvent first. As others have already recommended, first try IPA. You can get the 91% or 70% versions at Walmart. If that doesn't work try minerals spirits, aka stoddard solvent or paint thinner, not paint remover. You can also try bug and tar remover. They contain a large amount of aliphatic petroleum distillates and IPA. https://www.turtlewax.com/docs/defau...ug-tar-remover And as others have stated, DO NOT use an aromatic solvent like acetone or toluene. DO NOT wax any of your plastic trim or the black plastic part of your bumper with carnuba wax. There are products out there, i.e., Mothers Back to Black or Meguiar's Ultimate Black, for the black plastic trim. Last edited by RickyBobby; 09-30-2015 at 07:17 PM. |
#20 | |
![]() Take a before picture of your BRZ front pumper ........ then hit it with some acetone ....... then take an after picture. Be sure to replicate the "hit spot" at least 4 times; use water as a control. I'd participate ........ but, I don't have a BRZ ..... humfrz |
#21 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Its all from the STI badge.
#22 |
Thupercharged
Do you have a pre-wax cleaner? I have had wax buildup appear out of the blue weeks after a detail, usually a small spot on a lower rocker panel that I manage to miss every single time.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#23 |
not playing cards
Dish soap solution and a toothbrush. Little circles.
#25 |
The Fail Boat
Drives: CWP S.B.
it's Wax
#26 |
Drives: 2014 Scion FRS
hit it with a little bug/tar remover or an all purpose cleaner (make sure you dont get it on the paint, not bad for it, just will remove any wax you have on there)
#27 |
thanks i used the spray u gave me but did not worked. Ill give the bug remover a try after all this rain mess goes away
#28 |
I tried washing it with soap and a brush and it did not worked. I also tried using duck tape to remove this shit and no go.
| WTB: South East PA BRZ front bumper, rear bumper. | SterlingBrz | Want-To-Buy Requests | 1 | 06-10-2014 10:37 AM |
| anyone want a BRZ bumper? --Dark Grey front bumper swap Charlotte NC | IroncladBRX | Southeast | 0 | 04-20-2014 09:18 PM |
| WTT(Midwest): MY 37j(pearl white) FR-S bumper w/fogs for YOUR BRZ limited bumper | OmarGC | Exterior Parts (Aero, Lighting, Etc.) | 26 | 12-02-2013 11:44 AM |
| Worn floor mats - Covered under bumper to bumper warranty? | Philly758 | Issues | Warranty | Recalls / TSB | 45 | 08-19-2013 01:32 PM |
| Need scratches/scuff marks buffed out of bumper or cheap bumper for sale | [Cyanide] | NY / NJ / CT / PA | 12 | 12-28-2012 07:34 PM |
