Old 09-30-2015, 04:40 PM   #15
Originally Posted by chas3wba0 View Post
I meant "rubbing alcohol" as in over-the-counter isopropyl alchohol, which does not react with plastics as far as I know. It's the go-to solution for getting rid of wax, though.
Yep, I agree with ol @chas3wba0, I'd suggest you try a small spot using isopropyl alcohol. Maybe rub it in with a soft brush.
If you don't have any rubbing alcohol, you might try vodka or gin. NOT the cheap stuff, you serve your guests after they are half drunk.....
If that fails, consider ...... carefully and quickly, trying a very small spot, on the underside, with a small toothbrush ..... acetone.....
(disclaimer - humfrz is not responsible for any uses of acetone, outside the chemistry lab ........ )
OK, if none of that works, I'd go with theory "B" ...... the marks are caused by rock chips stressing (thus turning white) bits of the plastic.
If that is the case ....... "paint" the bumper with .... sorry, got to go ....it's my nap time ....ZZZZZZ
Old 09-30-2015, 04:44 PM   #16
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
my last resource if those marks does not go away is to plasti dip the damn thing.
Jfheisenberg is offline   Reply With Quote
Old 09-30-2015, 04:50 PM   #17
chas3wba0
chas3wba0's Avatar
Drives: Yes
Acetone... that stuff is vicious. Would probably leave a white mark, I bet
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 09-30-2015, 04:51 PM   #18
Shady195
Drives: '13 10 Series FRS #1203
It's wax...
Wax and black plastics/seals don't mix.
Use peanut butter to get it out.. No I'm not joking; take some peanut butter and rub it into the plastic firmly, take some dish soap and a rag and wipe clean.
DO NOT ACETONE YOUR BUMPER
Shady195 is offline   Reply With Quote
Old 09-30-2015, 07:07 PM   #19
RickyBobby
Drives: 2013 Firestorm FR-S AT
I worked as a research chemist before I retired. Yeah, I'm an old f**k.
You want to try an aliphatic solvent first. As others have already recommended, first try IPA. You can get the 91% or 70% versions at Walmart. If that doesn't work try minerals spirits, aka stoddard solvent or paint thinner, not paint remover.
You can also try bug and tar remover. They contain a large amount of aliphatic petroleum distillates and IPA. https://www.turtlewax.com/docs/defau...ug-tar-remover
And as others have stated, DO NOT use an aromatic solvent like acetone or toluene.
DO NOT wax any of your plastic trim or the black plastic part of your bumper with carnuba wax. There are products out there, i.e., Mothers Back to Black or Meguiar's Ultimate Black, for the black plastic trim.
RickyBobby is offline   Reply With Quote
Old 09-30-2015, 08:02 PM   #20
OK, who is up for a chemistry experiment ......
Take a before picture of your BRZ front pumper ........ then hit it with some acetone ....... then take an after picture.
Be sure to replicate the "hit spot" at least 4 times; use water as a control.
I'd participate ........ but, I don't have a BRZ .....
Old 09-30-2015, 08:21 PM   #21
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Its all from the STI badge.
Chen is offline   Reply With Quote
Old 09-30-2015, 11:43 PM   #22
DJCarbine
Thupercharged
DJCarbine's Avatar
Do you have a pre-wax cleaner? I have had wax buildup appear out of the blue weeks after a detail, usually a small spot on a lower rocker panel that I manage to miss every single time.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-01-2015, 12:29 AM   #23
Dish soap solution and a toothbrush. Little circles.
Old 10-01-2015, 01:10 AM   #24
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I get wax build up on my moldings too, doesn't bother me.
Instagram: stimson
Old 10-01-2015, 01:37 AM   #25
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
it's Wax
Old 10-01-2015, 06:06 PM   #26
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
hit it with a little bug/tar remover or an all purpose cleaner (make sure you dont get it on the paint, not bad for it, just will remove any wax you have on there)
Old 10-02-2015, 07:26 AM   #27
Jfheisenberg
thanks i used the spray u gave me but did not worked. Ill give the bug remover a try after all this rain mess goes away
Old 10-04-2015, 11:41 AM   #28
Jfheisenberg
I tried washing it with soap and a brush and it did not worked. I also tried using duck tape to remove this shit and no go.
WTB: South East PA BRZ front bumper, rear bumper. SterlingBrz Want-To-Buy Requests 1 06-10-2014 10:37 AM
anyone want a BRZ bumper? --Dark Grey front bumper swap Charlotte NC IroncladBRX Southeast 0 04-20-2014 09:18 PM
WTT(Midwest): MY 37j(pearl white) FR-S bumper w/fogs for YOUR BRZ limited bumper OmarGC Exterior Parts (Aero, Lighting, Etc.) 26 12-02-2013 11:44 AM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 07:34 PM
