Old 09-30-2015, 01:26 PM   #1
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
WTH is this in my bumper?
I just noticed that there is something in my bumper. Its like a blue-white paint/discolor. I just noticed it today.
I tried to clean up with some cleanup product and microfiber but as soon as its clean, 10 seconds later, those paint/discolor appears again WTF.
Can somebody advise wth this is? Im freaked out
Jfheisenberg is offline   Reply With Quote
Old 09-30-2015, 01:29 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Rock pits
/thread
Old 09-30-2015, 01:31 PM   #3
Jfheisenberg
Rock pits
/thread
cant be , the marks are align with the pattern of the bumper lines. No way rock hit the pattern that many times
Old 09-30-2015, 01:33 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
True. maybe you rubbed it while it was still dirty? If you forget to wash that part then dry it you could scratch it?
Old 09-30-2015, 01:42 PM   #5
Jfheisenberg
I wash the entire car every 3 weeks, i also wash that part of the bumper and wax it.
I think it was fine yesterday, it was sunny day and i did not noticed anything.
IDK wtf this is....
Old 09-30-2015, 01:46 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
IDK wtf this is....
Yeah you got me stumped. Maybe someone else will chime in
Old 09-30-2015, 02:03 PM   #7
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
It's hard to tell what it might be from the image; it sort of looks like residue from a paper towel.
Has it rained recently where you live? Sometimes I'll experience blotches of what look like discoloration on my car from oil and road gunk if I drive on wet roads where it hasn't rained in awhile previously.
I know in the case above, washing the car hasn't always been enough to remove that - and it might be more conspicuous if that was the case and you then waxed the area.
You could try a safe adhesive remover in case it was caused by a bit of sap, insect-splats, or other gunk that dried on there.
One time I had a really obvious smudge of something on the back of my driver-side mirror (sort of a ghosted effect); quick detailer didn't remove it, nor did the regular car soap I use.
I was in a Photography class at the time, and I had the random idea to try using a bit of the solution for cleaning my camera lens as I know that was excellent at removing any grease or oil. I added a few drops of it onto the MF towel that came with the bottle, and to my surprise the "stain" came right off.
Note that my mirror back had a clear bra on it - I still have no idea if it was at all safe to do what I did. I figured for use on expensive camera lenses it shouldn't be too dangerous, but then again those are glass. Here is the exact product I had - http://i.imgur.com/cMZotl1.jpg
Again, it was probably not the safest idea, but I was frustrated and desperate after nothing that I had worked, so try it at your own risk if you go down that route - I state it more as an anecdote to get idea circulating as to what options you might have to try to correct the issue.
Are you the only person that details your car, or do you know a professional who's opinion you might be able to get? Best of luck finding a fix for it.
Ammunition is offline   Reply With Quote
Old 09-30-2015, 02:10 PM   #8
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
It is probably a build up of wax residue. It looks to be in the valleys in between the textured bumps. I would say that even though you was your car often, it isn't quite getting all the wax out of those valleys and it turns white over time.
Vampyre is offline   Reply With Quote
The Following 3 Users Say Thank You to Vampyre For This Useful Post:
chas3wba0 (09-30-2015), lupindub (10-01-2015), Sarlacc (10-04-2015)
Old 09-30-2015, 02:18 PM   #9
Jfheisenberg
Im the only person that washes and details my car.
And yes i has rain since yesterday, but i know that my car has been on the rain before and never had this issue.
Like i said i tried to clean it with a detailer spray but that discolor is still there. I noticed that is not noticeable when its wet, as soon as i dry it, it comes back
Old 09-30-2015, 02:21 PM   #10
chas3wba0
chas3wba0's Avatar
Drives: Yes
As Vampyre said: whatever it is, it's embedded into the valleys of the textured surface and will be hard to get out unless you use a really sharp point to scrape it out, but then you risk scratching it. I'd not worry about it, as it will naturally fade over time... it's just plastic, after all
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 09-30-2015, 02:22 PM   #11
Jfheisenberg
This is what i was thinking. I used california carnauba paste wax two weeks ago and wax the entire car.
But, wont this wax residue come off with a spray detailer? or do i need to use something else...
Old 09-30-2015, 02:25 PM   #12
chas3wba0
chas3wba0's Avatar
Drives: Yes
Paste wax has a reputation for leaving white stains on dark plastic trim. You could try rubbing alcohol.
The Following User Says Thank You to chas3wba0 For This Useful Post:
humfrz (09-30-2015)
Old 09-30-2015, 02:34 PM   #13
Jfheisenberg
Wont rubbing it with alcohol would make the dark plastic trim in a dark pale accent ?
Old 09-30-2015, 04:07 PM   #14
chas3wba0
chas3wba0's Avatar
Drives: Yes
I meant "rubbing alcohol" as in over-the-counter isopropyl alchohol, which does not react with plastics as far as I know. It's the go-to solution for getting rid of wax, though.
Jfheisenberg (09-30-2015)
WTB: South East PA BRZ front bumper, rear bumper. SterlingBrz Want-To-Buy Requests 1 06-10-2014 10:37 AM
anyone want a BRZ bumper? --Dark Grey front bumper swap Charlotte NC IroncladBRX Southeast 0 04-20-2014 09:18 PM
WTT(Midwest): MY 37j(pearl white) FR-S bumper w/fogs for YOUR BRZ limited bumper OmarGC Exterior Parts (Aero, Lighting, Etc.) 26 12-02-2013 11:44 AM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 07:34 PM
