#15 |
Before you do anything else, check the rear tire pressures. What tires are they? If they're significantly less grippy than the stock tires it's entirely possible it's just the amount of rear camber you're running is too much for the crappier tires.
You can get the alignment checked, but first get the pressure in check. I'll bet they're over 40psi cold after being mounted.
#16 |
Reverse Burnouts
Drives: 2013 Argento FRS
new tires always feel loose to me for about 30 miles
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#17 |
Are they the same size as the originals?
#18 |
Drives:
#19 |
Stock wheels or aftermarket? While this might sound dumb.........have you checked the lug nuts?
#20 |
The Fail Boat
Drives: CWP S.B.
New rear tires. Car floats all over the highway
When ur tire blow out it probably fuked up your BC coils or it was bad to begin with. Don't get cheap stuff for suspension.
#21 | |
Drives: 13' Scion FRS
It sounds like the tire pressure might be too high...just a guess though. Last edited by Bamsterman; 09-04-2015 at 09:55 AM. |
#22 |
Drives: Scion FR-S, Ultramarine
Different tires have different profiles, different amounts of grip. A brand new tire is usually a little slippery for a while too. tread height also plays a factor. having different tires with different tread could cause a perfectly aligned car to pull one way or another. i wouldnt worry about it. Break those tires in, and you wont feel the floatiness anymore.
| BRZ on the highway | Champster | BRZ First-Gen (2012+) — General Topics | 11 | 06-15-2015 07:32 PM |
| Put on new rear tires, now my car handles terrible! WTF? | 996garage | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 12-03-2014 01:41 PM |
| Rear Parking Brake Guard Rub (Meaty Rear Tires) | console_cowboy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-13-2013 02:39 PM |
| I saw one of you on the highway..... | Joakim3 | Mid-Atlantic | 1 | 07-20-2013 07:43 PM |
| What would make the rear tires look wider?? | Razor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 02-18-2013 11:16 PM |
