Old 08-30-2015, 08:51 AM   #15
wparsons
wparsons's Avatar
Before you do anything else, check the rear tire pressures. What tires are they? If they're significantly less grippy than the stock tires it's entirely possible it's just the amount of rear camber you're running is too much for the crappier tires.
You can get the alignment checked, but first get the pressure in check. I'll bet they're over 40psi cold after being mounted.
flickr
Old 08-30-2015, 01:15 PM   #16
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
new tires always feel loose to me for about 30 miles
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 08-30-2015, 01:48 PM   #17
White64Goat
Are they the same size as the originals?
Old 08-31-2015, 10:16 AM   #18
AlexWood
Drives:
Yes, 215/45's
AlexWood is offline   Reply With Quote
Old 08-31-2015, 06:29 PM   #19
White64Goat
Stock wheels or aftermarket? While this might sound dumb.........have you checked the lug nuts?
Old 08-31-2015, 08:32 PM   #20
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
New rear tires. Car floats all over the highway
When ur tire blow out it probably fuked up your BC coils or it was bad to begin with. Don't get cheap stuff for suspension.
Old 09-01-2015, 01:19 PM   #21
Bamsterman
Drives: 13' Scion FRS
BC's aren't really "cheap". They're not high end, but they wouldn't just fall apart from a tire blowing out. I have personal experience in this. Also, the OP said that the tire didn't exactly blow out on him.
It sounds like the tire pressure might be too high...just a guess though.
Bamsterman is offline   Reply With Quote
Old 09-01-2015, 11:05 PM   #22
Estey
Drives: Scion FR-S, Ultramarine
Different tires have different profiles, different amounts of grip. A brand new tire is usually a little slippery for a while too. tread height also plays a factor. having different tires with different tread could cause a perfectly aligned car to pull one way or another. i wouldnt worry about it. Break those tires in, and you wont feel the floatiness anymore.
Estey is offline   Reply With Quote
BRZ on the highway Champster BRZ First-Gen (2012+) — General Topics 11 06-15-2015 07:32 PM
Put on new rear tires, now my car handles terrible! WTF? 996garage Scion FR-S / Toyota 86 GT86 General Forum 25 12-03-2014 01:41 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 02:39 PM
I saw one of you on the highway..... Joakim3 Mid-Atlantic 1 07-20-2013 07:43 PM
What would make the rear tires look wider?? Razor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-18-2013 11:16 PM
