Old 08-18-2015, 05:41 PM   #15
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
dammmm..made me sad
Old 08-18-2015, 06:15 PM   #16
jamies31
jamies31's Avatar
Drives: 2014 Scion Frs (Argento)
I thought I had smacked my rocker panel up bad...but that my friend takes the cake. I didn't get any pictures of mine because I was quite angry because I did it the day I bought the car, However it wasn't that bad and closer to the rear and I opted to repair rather than replace and it was close to $1200, And mine is silver not with the pearl paint to match...best of luck!
jamies31 is offline   Reply With Quote
The Following User Says Thank You to jamies31 For This Useful Post:
Tcoat (08-18-2015)
Old 08-18-2015, 06:19 PM   #17
Hotrodheart
Hotrodheart's Avatar
Just get a set of those "ground effect" type of rocker panel cladding. You'll never see it. Wait, that'll cost as much as the repair... nevermind.
Hotrodheart is offline   Reply With Quote
Old 08-18-2015, 06:23 PM   #18
Not gonna sugar coat it. That will cost you big! There is no easy/cheap way to fix that.
Light metals yes but anything short of 1/4 inch steel would have taken damage by the looks of that.
Just for reference this cost $1,200:
Originally Posted by spitfire481 View Post
by looking at that pic, id write it around $800ish. 10hrs body, 4.5hrs paint. pulling the metal, finishing out the body work. removing the quarter glass, tail light. re-undercoating the rocker, then paint the rocker/blend quarter/sail panel (no break off point). then you can remove one of the rubber caps under the rocker and spray an amber rust proofing wax back inside the rocker since the oem will burn off on the backside when you use the stud gun/dent puller.
Apparently it may be worth our while to drive to wherever Spit is located!
Old 08-18-2015, 06:49 PM   #19
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
For what it's worth, labor rates are usually lower in MD than many other states so the other guys numbers look normal as well
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 08-18-2015, 06:49 PM   #20
86Tony
Drives: 2015 AOZORA EDITION
Just bondo that and get some side skirts to finish it off you won't even know it was there, even after you sell it they won't kno LOL
86Tony is offline   Reply With Quote
Old 08-18-2015, 07:53 PM   #21
jamies31
jamies31's Avatar
im sure a couple of us, a few "colour matched" rattle cans from my parts dept, a can of bondo, a case of beer and we can get that fixed for way less than $800 on a sunday afternoon.
Tcoat (08-18-2015)
Old 08-18-2015, 10:03 PM   #22
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
Had a similar rocker panel owie on my car. Not as big of a push in but still sucked. Dented the rocker panel and pinched the metal crease line of the body work further up the car.
Had Paintless Dent Removal (PDR) cost me 400 bucks. 95% as good as new. Almost impossible to know there was anything there.
http://www.ft86club.com/forums/showthread.php?t=61229
Autocon is offline   Reply With Quote
Old 08-18-2015, 10:05 PM   #23
Jegan_V
Drives: 2023 Subaru BRZ
Tcoat is right on the money, if you want this fixed by a body shop it will cost a hefty amount. I also agree with his assessment, even in a vehicle with tougher metal, looking at that hit even a fullsize pickup truck rocker panel would exhibit a good deal of damage. I send a lot of our fleet vehicles to be repaired for rocker damage and if I saw damage of this degree I expect the repair bill to be on the higher side.
Jegan_V is offline   Reply With Quote
Old 08-18-2015, 10:07 PM   #24
Can you get rattle cans in Lava? My dealer said they could not. I have a scrap on the bottom/side of my front bumper I would love to slap some paint on.
Old 08-19-2015, 01:17 AM   #25
humfrz
Well, yes, @Tcoat.......
[ame="http://www.amazon.com/Scion-Metallic-Aerosol-Touch-Paint/dp/B00AVPIS0S"]Amazon.com: 2013 Scion FR-S H8R Hot Lava Metallic Aerosol Touch Up Paint 12 oz!: Automotive[/ame]
Just use vodka to take the old wax off; scuff it up a bit with a wire brush; make and drink two martinis, with some of the vodka; spray on paint until it drips off; have another martini; take a nap; cut dried drips off with a razor blade.
Then, just like the advice given to a tight rope walker or a man getting a XX from an old lady ....... just don't look down ......
humfrz
humfrz
Old 08-19-2015, 07:13 AM   #26
humfrz
humfrz
That is exactly my plan except for the $60 spray if I have to order from US. Would like to find some Canadian supplier for only $59.99 if I can.
Old 08-19-2015, 11:51 AM   #27
jamies31
jamies31's Avatar
They don't come from Toyota but yes I can get it. Its not my ideal suggestion when I comes to body work but if you want to get it done cheap and you have the time to do it proper. I believe they retail at about $50 a can
Old 08-19-2015, 11:59 AM   #28
Just want to slap some on since I know it will take a hit again anyway. Got to get down to see it anyway. Was thinking a lip but since it is lowered and an all season driver I don't want to play snowplow anymore that I need too.
I may just get you to order some if I can't get it through one of our U.S. plants cheaper.
Dented rocker panel daftpunk Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 49 08-15-2017 11:41 PM
Clipped my rocker panel area on a curb. Advice would be appreciated! PhysicalGraffiti Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-07-2017 09:45 PM
Deep rocker panel scrape Ryūkotsusei Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 03-29-2015 01:40 PM
Dented rear wheel side panel/rocker panel. Autocon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 12-23-2014 12:18 AM
Light side skirt for Dented Rocker Panel cmitc004 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-10-2014 07:45 PM
