Old 07-28-2015, 07:56 AM   #15
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Maybe a set of roll center adjusters?
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 07-28-2015, 08:29 AM   #16
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by glamcem View Post
Where do you guys read these recommendations?
mind sharing the link?
For mine, it's specific to the coilovers. They have a setup guide that includes setting the ride height adjustment and spring preload, which translates to various ride heights at different spring rates (or so)
Old 07-28-2015, 01:47 PM   #17
Lee
Drives: GT86
already fitted
Lee is offline   Reply With Quote
Old 07-28-2015, 07:59 PM   #18
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I thought it was in a magazine but struggling to find it, I did find these two posts here though, I'll update if I find the magazine, thought it was C&D or R&T...
http://www.ft86club.com/forums/showt...894#post538894
http://www.ft86club.com/forums/showthread.php?t=2787
(Note the second link, they have a 130mm ground clearance on the 86, many sports cars have 110mm...)
I see that's probably due to the nature of the STI pink springs and of course the OEM struts, I am pretty sure if I had 6k springs on my coilover setup my rubbing issue would be even more severe
glamcem is offline   Reply With Quote
Old 07-28-2015, 08:04 PM   #19
glamcem
glamcem's Avatar
makes sense but after a certain amount of drop rubbing becomes an issue regardless of the spring preload or the spring rate, in my case 1.25" drop is ideal (for most tracks ) but I still have some rubbing with 245s, I will try to raise about another .25"..
the only reason I didn't want to raise the car as much is because the max camber I get is about -3.0 in the front, I probably won't be able to get as much camber once it's raised again since the camber plates are already maxed out
Weathertech Trunk Liner & OEM BRZ Trunk Liner 86Tony Canada Classifieds 12 03-07-2015 04:05 AM
Compression/cylinder? Amir Ghadiri Engine, Exhaust, Transmission 4 02-21-2015 02:23 AM
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
