Old 04-08-2016, 06:14 AM   #15
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
Have the same code on a customer car with a kraftwerks sc and upgrade fuelpump, actually the code came after changing the pump.
today going to fix it with a new sensor hopefully part nr su003-01106
ST-A is offline   Reply With Quote
Old 04-08-2016, 11:44 PM   #16
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've gotten this code recently. Guess if it happens again I'll have to try replacing the sensors too. Lame.
Old 02-03-2017, 03:18 PM   #17
Jayfrs95
Drives: Kraftwerk c30 suchercharged frs
P0462 issue
Did anyone fix this? I am having this issue with p0462. My car turns off here and there on neutral. I change one of my fuel sender but still
Jayfrs95 is offline   Reply With Quote
Old 02-05-2017, 06:35 PM   #18
angadam
Drives: 14 BRZ Limited
For me on the third trip to the dealer(on a flatbed) they replaced both senders under warranty. I haven't had an issue since.
angadam is offline   Reply With Quote
Old 02-05-2017, 10:23 PM   #19
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I don't know about this car, but in other cars it is common for the sending unit to go just before the fuel pump goes. Jayfrs95 sounds like your fuel pump is on the way out. Start monitoring your fuel pressure and note what the pressure was at when you stall.
Old 09-11-2017, 11:25 AM   #20
DarkSunrise
DarkSunrise's Avatar
I threw a P0462 code at the track. Was full throttle down a straight when the course workers threw a red flag. Immediately went from ~100 mph to complete stop with a hot engine. About a minute later, saw the CEL pop on. First thought was another fried coilpack (happened before in this exact scenario), but when I checked codes, was surprised to see P0462.
Good news is I cleared it and it went away for the rest of the day. We'll see if it returns.
2022 BRZ Build
2013 FR-S Build
Old 05-13-2019, 09:04 PM   #21
DarkSunrise
Had this CEL pop on again. Been a while since I had this problem. Happened after I switched to e85, was on my 2nd tank. Not sure if it's related. Cleared the code and it's been fine since. On my 3rd tank of e85 now. Wonder what's causing this...
2022 BRZ Build
2013 FR-S Build
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 02:54 PM
p0462 code brady86 Issues | Warranty | Recalls / TSB 15 03-09-2017 09:25 PM
Brand new 4 Bar MAF Sensor & 700cc Deatschwerks Fuel Injectors deedz Engine, Exhaust, Bolt-Ons 7 03-26-2015 01:21 AM
Low fuel level and engine performance whatsinaname BRZ First-Gen (2012+) — General Topics 20 12-03-2013 01:55 PM
Fuel level GeeTee86 Issues | Warranty | Recalls / TSB 6 05-21-2013 06:57 AM
