Old 07-21-2015, 09:18 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I only went the flathead route after using the spanner wrenches with all the force I could and still they lowered and a friend suggested he used to use it. I think the dirt might be the reason for them lowering.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 07-21-2015, 09:23 PM   #16
Streetthrowback
Drives: 2015 brz
Originally Posted by Bergen23 View Post
Except for the fact that companies such as Fortune Auto recommend this to be done when installing.
Think about it, do you think that's a good idea? If you have to tighten them past the keys then something else is the problem
Streetthrowback is offline   Reply With Quote
Old 07-21-2015, 09:38 PM   #17
Bergen23
Drives: '15 Halo FR-S
Check out fortune autos video on YouTube about setting up their coils. They specifically mention using a flathead and hammer to get them good and tight.
Bergen23 is offline   Reply With Quote
Old 07-21-2015, 10:00 PM   #18
Streetthrowback
Drives: 2015 brz
I guess if you see everyone jumping of the bridge, you'll just join them uh...
Old 07-21-2015, 10:11 PM   #19
Bergen23
No, but when the manufacturer says this is how you install their product, I tend to listen to that.
Old 07-21-2015, 10:40 PM   #20
Streetthrowback
Drives: 2015 brz
Not when something as obvious as jumping off a bridge it isn't and if their are telling you to do that then what does that say about them... Theirs a reason the keys are their for... Oh wait just throw them out, use your flat head and your
P.s. I'm an ASE certified mechanic and that isn't my career...
Old 07-21-2015, 10:51 PM   #21
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Do you have any sort of bearing between the spring and perch at either end? Springs torque when they compress, and if there's nothing to let the spring rotate at one end, it could be rotating the spring perch.
GSpeed is offline   Reply With Quote
Old 07-21-2015, 11:11 PM   #22
superleggera
superleggera's Avatar
Drives: BRZ / MX5 / S4
Originally Posted by Sportsguy83 View Post
I have an issue with my suspension. I've had it installed for 6 months. Twice already (let's say 3 month interval between checks), the suspension has lowered itself.
I have tightened the lower ring with all the force I could, having friends help. I've held the two upper rings with the other spanner wrench to tighten the lower ring even more without them moving.
It seems simple enough, and I don't see anyone else having that problem. It happens on both fronts.
Help???
@CSG Mike @Racecomp Engineering
I installed my Street Flex's approx 2 months ago. Today, I brought my car in to get my tires rebalanced and with all of the wheels off, I noticed the exact same problem on both sides up front. Fortunately I had the coilover wrenches in my car, so I retightened with Hulk force strength. Hopefully it wont happen again but I'll monitor it more closely now.
What actually tipped me off is that there was a lot of slack in the spring (basically not preloaded at all). I remember when I installed them, with the standard Tein preload the springs didnt have any slack.
superleggera is offline   Reply With Quote
The Following User Says Thank You to superleggera For This Useful Post:
Sportsguy83 (07-21-2015)
Old 07-21-2015, 11:12 PM   #23
babykwiss
Drives: Scion FRS
I sort of had this issue when I first installed them but only with the fronts. They lowered themselves until it maxed out. Then i realized I did not tighten them enough even thought I thought I did. I used the Tein Keys and used a socket wrench where it had that square hole to get more leverage and turned it until it would not move and now they have not moved at all even after ample track days.
babykwiss is offline   Reply With Quote
The Following User Says Thank You to babykwiss For This Useful Post:
Old 07-21-2015, 11:15 PM   #24
Sportsguy83
Drives: Limited BRZ
I noticed the socket hole today, and will use them next time I tighten them. Great input man, thanks a lot!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
CSG Mike (07-22-2015)
Old 07-21-2015, 11:17 PM   #25
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
it amazes me that Tein is considered a quality product. After seeing how quickly their springs sag, i was turned off for life.
sorry you're having this problem man. you could drill/tap your adjustment perch, and put a setscrew in to jam the nut into the thread, most other companies use this method. or a collar clamp would work (look on mcmaster.com for collar clamps)
Sammakko is offline   Reply With Quote
The Following 2 Users Say Thank You to Sammakko For This Useful Post:
a_dee (07-25-2015), Sportsguy83 (07-22-2015)
Old 07-22-2015, 12:00 AM   #26
Sportsguy83
Drives: Limited BRZ
This is my first time using them, might be the last.
superleggera (07-22-2015)
Old 07-22-2015, 12:09 AM   #27
Sammakko
Bilge monkey
Sammakko's Avatar
by the way, do you know Erick Mahle?
Old 07-22-2015, 01:10 AM   #28
e1_griego
e1_griego's Avatar
Drives: Many
Many times this.
A radial bearing setup that allows the spring to rotate independently is the fix.
Tapered threaded bodies all seem to do this, which is why you have to lock the collars down so tight.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
GSpeed (07-22-2015)
Tein Street flex JM'sFR-S562 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2015 11:04 AM
Tein Street Flex installation Help eguzman6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-08-2015 03:08 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 12:40 AM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
