#15 |
Drives: Asphalt FRS
The key to making the ride look good will be lowering it. Stock height on that size will look funky. It sucks because the stock wheels look meh but I lowered the car down then ordered my Volks. In the end it was the right move.
| The Following User Says Thank You to Jolt182 For This Useful Post: | Bakchoii (07-09-2015) |
#16 |
Choii
Drives: 2014 Firestorm Red Scion FR-S
I'll keep that in mind one step at a time
#17 |
Drives: 2015 ISM BRZ Premium
With 9.5" wide wheels and a +43 offset, you're going to get some pretty significant poke front and rear on the stock suspension. It'll get a little better if you just do lowering springs, but you're really going to need to either go to coilovers or camber plates to get the negative camber needed up front for a flush look.
#18 | |
Choii
I'm probably going to go for a 18x8.5 +42 Im still looking into other setups.
#19 | |
No rice, no life
Drives: 2013 Asphalt FR-S
Here's some pics of mine if you're curious what it'll look like. The fitment is pretty good at this offset. ![]() ![]()
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
#20 |
Drives: Asphalt FRS
Here's my current setup. No rubbing yet either. 18x9.5 +40 all around with 255/35/18 tires. In order to make it work i had to get coilovers though. Regardless you'll want them to finish the look of your car and give you the clearance you need for wider wheels and tires.
| I Need Advice About An Fr-s! | DViper0020 | Issues | Warranty | Recalls / TSB | 13 | 05-09-2014 10:15 AM |
| need advice | Blue14inTracy | Engine, Exhaust, Transmission | 13 | 03-27-2014 08:39 PM |
| Need advice!! | Black_Pearl | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 12-10-2013 12:14 PM |
| Advice | EDCOVEY | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 12-10-2012 08:16 AM |
| Need advice | FRSMAK86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-06-2012 05:39 PM |
