Old 06-19-2012, 10:34 AM   #15
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
Yep, it's backwards. It just is. : )
Jedi1 is offline   Reply With Quote
Old 06-19-2012, 10:38 AM   #16
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Originally Posted by Jedi1 View Post
I am fairly confident that someone on the development team knows pulling the shifter towards the driver should be an upshift and pushing it towards the dash should be a downshift. This makes sense because under braking it is easier to push the shifter forward to downshift and exactly the opposite is true under acceleration.
This means feedback is going the wrong way. If some poor driver depends on the inertia of his arm to shift, and if pushing forward downshifts, then a hard brake will cause a downshift, then the extra engine drag will cause a second downshift, then the over-revs will cause a third downshift (should the ECU allow it). Brake hard and this positive feedback leaves you in first.
No, they did it right. By making the driver fight against inertia (thus making inertia a negative feedback mechanism) the driver must force the downshift when braking hard. The lawyers might also like the idea of an object flying forward during a hard brake not causing a downshift.
Plus it matches the shifting in my Tundra, so I didn't need to learn anything new.
b.e is offline   Reply With Quote
Old 06-19-2012, 10:55 AM   #17
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
That would be cool if it was just like the initial d arcade game!
rcm47 is offline   Reply With Quote
The Following User Says Thank You to rcm47 For This Useful Post:
finch1750 (09-06-2012)
Old 06-19-2012, 11:09 AM   #18
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by uspspro View Post
it would be easiest to change the wiring at the ECU (or junction block), rather than make physical changes to the switches.
Cleanest way would be to have two mini jumper harnesses.
One that swaps the wires, and one that reverts it back to stock.
The cleanest way would be to unpin and swap the wires, either at the ECU, or another plug upstream. Unfortunately that's probably gonna require wiring diagrams or exploratory surgery. I'd sart by lifting the bezel around the shifter and looking for switches.
The Following User Says Thank You to Calum For This Useful Post:
Jedi1 (06-19-2012)
Old 06-19-2012, 11:43 AM   #19
UncleFester
The shift pattern doesn't seem backwards to me. It's an auto trans with paddles not a race sequential. It follows the typical gross market pattern.
Good luck on switching it over. Hopefully it's easier than it sounds.
UncleFester is offline   Reply With Quote
Old 06-19-2012, 12:07 PM   #20
Jedi1
Jedi1's Avatar
I hope its just a matter of switching the plugs and I totally understand why it doesn't bother many people. It bugs me because I have been involved with Motorsport Professionally for many years and it just feels completely wrong in my case. I shall work to fix it for myself and if I can figure it out I'll tell folks here just in case there are more out there that feel it's backwards.
Sean
The Following 2 Users Say Thank You to Jedi1 For This Useful Post:
ahausheer (09-18-2012), Dadhawk (06-19-2012)
Old 06-19-2012, 12:20 PM   #21
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
M
SUB-FT86 is offline   Reply With Quote
Old 06-19-2012, 02:43 PM   #22
Psy-q
Drives: 2014 DGM Tech-Package Manual
Originally Posted by atledreier View Post
The de'facto standard is 'backwards', sadly. I haven't seen any semi-auto box that had the stick the 'right' way. It's a pain in the butt. Looked into swapping them on my VW DSG, but the wiring down there is just overengineered to the nth degree. I skipped it and just live with it for now.
All bmws (auto, smg, DCT) have it the "right way". Mazda 3's have it "the right way". Mitsubishi has it the "right way" on their DCTs but not the regural autos...wierdly. Also Maserati Quattroporte has it the right way as well.
I belive there are some European brands that got it properly too.
So people do have the right to expect this very sporty subayota to come with "proper" shift pattern of the auto.
P.S.
Pretty much all cars from FIAT SPA come with autos the "proper way". Check out the fiat 500 and alfa romeo gullietta.
And even the Dodge dart too!
Psy-q is offline   Reply With Quote
Old 06-19-2012, 03:13 PM   #23
Dimman
Kuruma Otaku
Dimman's Avatar
Sorry, its not personal preference when every sequential box put into any modern era race car is upshift towards the driver and downshift towards the dash. If you personaly like it the other way around, that's cool. But, it is backwards when compared to track specific sequential boxes.
Yes, but race drivers are usually not complete morons (as well as having the g forces to deal with), which unfortunately make up a huge percentage of normal car buyers.
To them forward = up = upshift, most likely. Plus automatic gear selection is that way, too. (At least in the Toyota's and Subaru's that I've driven.)
Because titanium.
Old 09-05-2012, 01:26 AM   #24
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Sean
Did you ever figure this out?
@Art_Mighty is offline   Reply With Quote
Old 09-05-2012, 02:02 AM   #25
madfast
Drives: 2010 Evo X MR-T
P.S.
add suzuki to the list that have it the "right way". and who remembers the MR2 SMT? that had it the right way as well.
anyways, low gear on an AT is down, so they made it follow this convention. this is the simplest explanation. manufacturers that go against this convention have enough balls to literally flip it upside down and do what the race cars do, and not what the soccer mom expects.
also lets not forget the myriad of ways manufacturers had steering wheel activated shifting, even after ferrari came out with the F1 paddle shifters in the 355. MB and lexus had buttons, bmw and porsche had a toggle switch/"paddle", and look at the miata with a button and a paddle... only now has everyone sorta agreed to use right paddle up, left paddle down... then theres the whole wheel mounted vs column mounted paddles debate...
madfast is offline   Reply With Quote
Old 09-05-2012, 10:52 PM   #26
Jedi1
Jedi1's Avatar
Art, we bought the car and I immediately went on a three month tour. I haven't been home since July 5th! I will look into it a bit when I get home. The other side of this equation is the paddles on the wheels are correct and that's pretty much all I will ever use anyway. If the sequential is an easy fix, I'll do it. If it requires an electronics degree, I'm out!
Old 09-05-2012, 11:02 PM   #27
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Fun fact: As far as I know, Mazda does it correctly on the "6" where forwards is a downshift and backwards is an up shift. You know, the direction of momentum.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 09-07-2012, 12:19 PM   #28
86dreams
Drives: many different
They do it on the Miata's correctly as well. Tuned a turbo 2007 last night that had it.... was pretty interesting.
86dreams is offline   Reply With Quote
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Do you think FT-86 will have automatic? TRD Engine, Exhaust, Transmission 217 08-03-2013 09:36 AM
Red Automatic FRS available BRZ88 NY / NJ / CT / PA 0 06-01-2012 12:04 PM
automatic pdf :D enjoy carbonBLUE Engine, Exhaust, Transmission 4 04-26-2012 11:17 PM
Anyone Else Considering an Automatic FR-S? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 410 02-16-2012 12:41 PM
