Old 06-08-2015, 12:14 AM   #15
Originally Posted by JS + BRZ View Post
Can you enlighten us why they are doing it? Thanks.
For most people? "because the fast guys do it". Why do the fast guys do it? So they can rotate tires.
The proven formula is high end coilovers, unbalanced front/rear aero, and square tires.
Old 06-08-2015, 12:53 AM   #16
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
I've seen s2ks w/o aero be successful using a squared setup on track and especially on autoX courses. U just need the right mix of suspension tuning (spring rates, shock tuning, and front sway bar) to counter the increase in front end traction. Like Mike said tho, most track guys do achieve that balance thru rear aero.
AyJay is offline   Reply With Quote
Old 06-08-2015, 02:52 AM   #17
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
no reason to stagger a non mid/rear engine'd car with stockish power levels.
Sammakko is offline   Reply With Quote
The Following User Says Thank You to Sammakko For This Useful Post:
hmong337 (06-08-2015)
Old 06-08-2015, 03:28 AM   #18
JS + BRZ
Drives: 2010 MS3
Lol thx
JS + BRZ is offline   Reply With Quote
Old 06-09-2015, 08:46 AM   #19
brn12345
brn12345's Avatar
What do you mean by "unbalanced front/rear aero".
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
The Following User Says Thank You to brn12345 For This Useful Post:
1GiantTurtle (11-02-2016)
Old 06-09-2015, 11:45 AM   #20
wparsons
wparsons's Avatar
Unbalanced aero would be more aero grip at one end than the other. I would imagine in an S2K on square tire sizes you'd shift the aero balance rearward so you have good rotation at low speeds without it trying to kill you at high speeds.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
brn12345 (06-10-2015), CSG Mike (06-09-2015)
Old 06-09-2015, 11:59 AM   #21
Racecomp Engineering
That's usually the proper way to do aero for any car (though rarely is aero done properly).
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
brn12345 (06-10-2015), CSG Mike (06-09-2015), JS + BRZ (06-09-2015), wparsons (06-09-2015)
Old 06-09-2015, 01:38 PM   #22
A disproportionate amount of rear aero is added to the point where the car heavily understeers at speed. The rear aero is adjusted to each track, so that the terminal understeer doesn't hinder the car.
Old 06-10-2015, 05:51 PM   #23
brn12345
brn12345's Avatar
.... so you have good rotation at low speeds without it trying to kill you at high speeds.
Exactly what happens to me last April. Had a nice bump in the barrier due to high speed rear looseness.
Old 06-10-2015, 06:10 PM   #24
Ouch...
Old 06-10-2015, 07:53 PM   #25
wparsons
wparsons's Avatar
Ouch is right, that's a solid hit!
flickr
Old 06-10-2015, 08:04 PM   #26
swarb
You could blame the accident on the looseness. Or you can blame the over correction.
squared vs staggered FullTuneZN6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 05-04-2014 04:05 PM
Staggered Set Andy@FA20Club Wheels and Tires 0 09-03-2013 11:57 PM
Staggered for track? SavingManuals Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-29-2013 07:05 PM
Square vs staggered kosoku Tracking / Autocross / HPDE / Drifting 60 08-20-2013 05:02 PM
Ok to have non staggered wheels but staggered tires? taimysho0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-22-2013 12:57 AM
